how do I change my rear differential bearings? - JeepForum.com
post #1 of 7 Old 10-29-2010, 11:00 AM Thread Starter
95yj0645
not my wheel bearings, the bearings in the pumkin .. I changed my wheel bearings and I still have a bad bearing grind/whine coming from my rear end at low speed .. almost sounds like a brake dragging but I know for a fact it is not.. if someone can give me steps on changing these that would be awesome.. I just dont wanna mess my gears up or have my spiders fall out or something. so the proper way would be appreciated
95yj0645 is offline
post #2 of 7 Old 10-29-2010, 11:12 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Have you opened up the differential and taken a close look inside at things?
If not, you very well may discover that if the pinion bearing is toast - the ring & pinion gears, plus the spider & side gears could be worn or chipped as well.
If this is the case - a complete rebuild including a new ring & pinion, spider & side gears, plus a new master install kit will be in order to "fix" it.
This will require pressing bearing, specific specialty tools & knowledge, & if a shop does it $$$.
If it were my Jeep & the D35 needed repair, I would toss it in the nearest dumpster & install a better axle for far less than it cost to rebuild the factory axle.
Joe Dillard is offline
post #3 of 7 Old 10-29-2010, 11:16 AM
Joe Dillard
This should give you some idea as to what's involved:
http://www.jeepforum.com/forum/f12/g...-101-a-623694/
post #4 of 7 Old 10-29-2010, 11:47 AM
planedog
It may be easier to install an 8.8 than replace those bearings and much more worth the time!
planedog is offline
post #5 of 7 Old 10-29-2010, 10:25 PM Thread Starter
95yj0645
alright thanks guys
95yj0645 is offline
post #6 of 7 Old 10-29-2010, 11:15 PM
1998zj
Where in Indiana are you?
"Our lady of blessed acceleration don't fail me now"
1998zj is offline
post #7 of 7 Old 11-04-2010, 09:28 PM Thread Starter
95yj0645
well already go the diff bearings changed and back in and my bearing grind is still there .. gotta be the pinion .. granted carriers were SCREWED
95yj0645 is offline
Anyone experience bad bearings in front differential? chickenhawk7 JK Wrangler Technical Forum 20 06-24-2010 06:37 AM
Advice needed: should I change unit bearings? china-clipper YJ Wrangler Technical Forum 4 04-19-2009 10:55 AM
Limited Slip Rear Differential or Electronic Locking Rear Differential danw2 JK Wrangler Technical Forum 23 01-13-2008 12:38 PM
Differential oil change... Straight Six TJ Wrangler Technical Forum 5 11-09-2007 06:39 AM
How hard to change out bearings in front axle? Jim Shanks TJ Wrangler Technical Forum 13 04-08-2004 12:51 PM
