How difficult is doing ..... -
Go Back > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > How difficult is doing .....
All Bilstein shocks & struts - Lowest Prices Ever and Iron Rock Offroad products - get them from Kolak!SWAG Off Road Knock Out Punch Set (7) Pieces (Tube Sizes)
Unread 11-28-2015, 10:01 PM   #1
1973 CJ5
....a spring over the axle lift on a 1995 YJ? It doesn't look to be as easy as the old CJs. Thanks for any advice you can offer. We plan on doing some fairly serious wheelin'.
to YJs
1973 CJ-5, AMC 390, Holley Projection-4, Mallory Unilite Distr, Crane FireBall Cam, Aluminum Roller Rocker Arms, Roller Timing chain, Rear Main Bearing Oiling Tube, Ceramic Headers, K&N Filter, 60,000 volt coil, SplitFire Plugs, Dual Batteries, 100amp alternator, two electric aux. cooling fans, Warn MX8000 winch, T-18, 4.27:1 gear sets with PowerLocs in both diffs.
AMC390CJ5 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 01:00 AM   #2
I overtighten stuff
paulhead's Avatar
AT the top of the page
paulhead is offline   Reply With Quote Quick reply to this message
In order to be able to post messages on the forums, you must first register.
Jeep, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. is not in any way associated with Jeep or the Chrysler Corp.
