How did you run your light bar wiring? - JeepForum.com
post #1 of 25 Old 10-09-2014, 06:54 PM Thread Starter
voz
I did a quick search but found nothing..
how did you run your wire from overhead light bar?
My wire is on the left side of bar...
Thank You!
VOZ™
voz is offline
post #2 of 25 Old 10-09-2014, 08:01 PM
superj
I am going to follow this because I have always wondered if people are drilling a hole in their windshield frame and running the wires up the inside, or what?
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 25 Old 10-10-2014, 06:41 AM
Que89YJ
I never thought about it either. Subd for responses too.
Que89YJ is offline
post #4 of 25 Old 10-13-2014, 05:23 PM Thread Starter
voz
Still searching,
I have heard folks drilling also, I'm not fond of that...
I've been out of town since Thursday, Hopefully I can try a few things later this week..
VOZ™
voz is offline
post #5 of 25 Old 10-13-2014, 05:27 PM
superj
I am not a fan of drilling either
superj is offline
post #6 of 25 Old 10-13-2014, 05:43 PM
Chrisnvegas
Chrisnvegas's Avatar
Drilled and snaked the wires through the windshield. Sealed with black silicone.
I don't like drilling either, but wires have to go somewhere.
"Can you count, suckers? I say the future is ours, if you can count!"
Chrisnvegas is online now
post #7 of 25 Old 10-13-2014, 07:21 PM
DirtKar
I pledge allegiance.
DirtKar's Avatar
You can drill the bottom of the windshield frame and fish the wires thru the top front face and use rubber grommets with a bit of sealer for good measure. The important part here is to make sure that there is no opportunity for the wires to short to ground thus the grommets.
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #8 of 25 Old 10-13-2014, 07:30 PM
Chrisnvegas
Last year a friends wiring shorted. The grommet actually wore through. So I now use both. The silicone keeps the wire from rubbing through the grommet and locks everything in place.
I snaked the wires through with that automotive grade sheathing. It was a pain. But think there are bolts protruding into the inside of the frame
Bolts from the rollbar extensions, windshield channel, sun visors ect.
Didn't want wire insulation rubbing on those either.
post #9 of 25 Old 10-13-2014, 07:42 PM
DirtKar
DirtKar's Avatar
Good call on the sheathing, Chris. You can use heat shrink on the pass throughs too. Makes multiple wire bundles a bit more round for sealing as well as offering a smidge more insulating protection.
YJOTM JULY 2014
DirtKar is offline
post #10 of 25 Old 10-13-2014, 08:22 PM
Polonius
Well, I'm surprised we haven't seen more answers..... My Jeep had it in the wire sheathing stuff (can't remember what it's called at the moment....) and just tucked into the channel on the side. The windshield mounts help hide and keep things in place, though. It sneaks out from the bottom corner of the hood, does a lazy loop to the windshield mount by way of the antenna, just ziptied where available. The black doesn't stand out too much on the dark green of the jeep, and it's the passenger side so I don't see it much.
Polonius is offline
post #11 of 25 Old 10-13-2014, 10:54 PM
Hoxie
Hoxie's Avatar
1987 YJ Wrangler
Sub'd up to see some pictures of the drilling into the windshield frame. Im planing on a light bar soon and I hate looking at wires.
YJOTM January 2017
Hoxie is offline
post #12 of 25 Old 10-13-2014, 11:53 PM
lwow
This worked for me... did not want to get the drill out or pinch it under the hood. I used 10 gauge wire just in case I go with more than the 240 watt light bar (10w x 24) 50" oal ( 300 watt was bar 52" oal). The lip edge of the half door was slightly bent down just to make me feel better. even though it cleared perfectly.
95 YJ 4.0 5spd
98 Ram 2500 4x 24v CTD
78 Scout II SD33T
70 Scout 800 SR2 sv304
lwow is offline
post #13 of 25 Old 10-14-2014, 01:02 AM
Gausswave
I was thinking of drilling and using water tight pass troughs.
some thing like this...
http://www.westmarine.com/buy/ancor-...09_275_003_512
However getting the inside piece set could be a challenge.
Gausswave is offline
post #14 of 25 Old 10-14-2014, 06:39 AM
Que89YJ
It is always better to seal it. The cowl leaks are bad enough.
Que89YJ is offline
post #15 of 25 Old 10-14-2014, 08:45 AM
Reno72
I'm on the road a couple more days, I'll send photos when I'm home. My wire comes out the driver side light bar, I tucked the wire under the soft top snap and behind the plastic door molding, there is a channel behind the molding so no crimping, I then ran the wire from the inside bottom molding above the speaker grates and behind the dash. There is no wire visible except for the short run from door to dash, I put black gorilla tape over that so it really doesn't show up. If I felt like extra work I could have ran it from the inside door molding to behind the dash, but that would have required pulling the dash.
Reno72 is offline
