How did you fix your rusted floor pan? - JeepForum.com
post #1 of 26 Old 03-05-2012, 02:42 PM Thread Starter
PLHamp
First off I do not know how to weld, I can solder pretty well by welding is another story. I have cut out the rusted portion of the floor and have a replacement pan/floor that actually welds or can be attached all the way around if I trim the rust and all the good metal back. I have trimmed all the rust areas back plus about 2-3 inches all around. Now my dilemma, should I pay for welding or is seam sealer and rivets good enough? Sheet metal screws and seam sealer or should I get it welded and then do seam sealer. I intend to spray the underside with undercoating to control any more rust. Seems the previous owner went to slammer and the Jeep sat for two years with out the plugs pulled and water pooled up just on the drivers side, rest of inside is fine.
Thanks for any suggestions!
Pat
PLHamp is offline
post #2 of 26 Old 03-05-2012, 02:54 PM
YJSteveD
In my YJ, some plates were riveted in
YJSteveD is offline
post #3 of 26 Old 03-05-2012, 02:55 PM
itsonlyatruck
i would have made sure the ned pan overlaps the hole and just rivete it in with some silicone around the edges to seal it up.
itsonlyatruck is offline
post #4 of 26 Old 03-05-2012, 03:02 PM
MegaCabMan
If your not concerned about beauty then just use some body panel adhesive and glue the panel in place. Then I'd cote the floor, inside and out with truck bed liner. the adhesive available at auto paint supply stores or online.
http://www.eastwood.com/no-weld-pane...FWJgTAodhDMR6A
They call me the King of Fun! Everwhere I go I hear "Here comes that Fun King MegaCabMan"
MegaCabMan is offline
post #5 of 26 Old 03-05-2012, 03:05 PM
MegaCabMan
Iv seen this done and the silicone will hold water and cause the area to rust...the best bet is to use the epoxy panel adhesive.
post #6 of 26 Old 03-05-2012, 03:15 PM
roadyrob
1987 YJ Wrangler
I did mine with rivets, has held up good
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #7 of 26 Old 03-05-2012, 05:57 PM
castorriver
I didn't know rivets was an option. i guess how it looks on the floorboard doesn't matter.
Registered Nurse Jeep Club Member #1 (I think...)
Verse 36: And He said to them, "But now, whoever has a money belt is to take it along, likewise also a bag, and whoever has no sword is to sell his coat and buy one.
castorriver is offline
post #8 of 26 Old 03-05-2012, 09:50 PM
Dixierambler
Roll Tide
Dixierambler's Avatar
Mine was rusted out just like yours. I took the replacement panel and riveted to what good material was left. Then came from underneath with another piece of sheet metal and sort of doubled it up. Seem to strenghten it as well. Used a marine adhesive and sealed it up. So far so good.
Dixierambler is offline
post #9 of 26 Old 03-08-2012, 10:51 PM
Jared24knapp
1987 YJ Wrangler
I just did drivers side floor pan bent my own sheet metal and riveted down and then patched
The ocward edges with fiberglass and the rhino lined over the top and looks
As good as new to me
Jared24knapp is offline
post #10 of 26 Old 03-09-2012, 08:33 AM
Que89YJ
What did you use to cut the floor with? Really nice clean looking cut!
Que89YJ is offline
post #11 of 26 Old 03-10-2012, 05:47 AM Thread Starter
PLHamp
I used a Sawsall, with a really high end metal blade from Bosch. I need to cut a little more then, based on the concesus, I am going use the newer style stainless steel body panel rivets, 1/4" and Seamsealer. I probably will leave punch outs on the corners for welds for later just in case. I bought a can of bedliner and intend to both front floors and underneath.
I really appreciate everybodys responses.
Pat
PLHamp is offline
post #12 of 26 Old 03-22-2012, 03:19 PM Thread Starter
PLHamp
Just an update, the floor is trimmed and fits almost flush all the way around. I did have rust through on the rocker just below the JEEP logo. I trimmed a peice of sheet steel from Home Depot and got a punch and offset tool on line. That peice is in and I think I need to weld that unless someone has a better idea. I am going to put the diamond plate rocker panel protectors on and they cover the repaired area completely. I guess I could use riviets for that and then just bondo the rough spots. Ideas, suggestions. I came within an inch of buying a weleder from Northern Tool for $150. But never welded before and am not I want to start now, although this is a Jeep.
PLH
PLHamp is offline
post #13 of 26 Old 03-22-2012, 05:53 PM
animal0307
The OP of my jeep used sheet metal screws i believe. If I ever have to do it I will be welding them in.
animal0307 is offline
post #14 of 26 Old 03-22-2012, 06:58 PM
ldso
I just left it rusty and put a big square piece of plate steel down, and secured it with sheet metal screws. If I ever need a base for my Hi-lift, I can take it off
But since you have the new pan, in the past I have used rivets and it worked fine. I have drilled a few extra drain holes in my tub because if you leave the windows and doors off you get standing water pretty often around here.
1995 YJ "Mabel", 2.5L Muncie SM465 np231j 4.88's HP30 Lockright JK 44 Detroit 33s CJ clip
Actually, it's pronounced "mill-e-wah-que" which is Algonquin for "the good land."
ldso is offline
post #15 of 26 Old 03-22-2012, 07:27 PM
deermjd
PLHamp,
I was in your shoes about 3 months ago trying to decide what to do about my floor pans. I really considered using some automotive body panel adhesive or even some sheet metal screws. I had the same replacement panels as you. I was going to have the inside of the tub bedlined but I still wanted it to look good. I ended up paying someone to weld in the new floor panels and I haven't looked back. To me it was worth every penny. My$0.02
Not the best picture but it's all I could find.
94 ZJ Laredo (sold)
98 ZJ TSI (sold)
92 YJ 4.0
deermjd is offline
Hello!/ Rusted floor pan advice?! DirtyWhlr TJ Wrangler Technical Forum 6 04-25-2008 07:21 AM
rusted floor pans.... nj scott YJ Wrangler Technical Forum 5 08-27-2007 07:47 AM
What to do with RUSTED out floor.. rlacey YJ Wrangler Technical Forum 26 04-09-2005 09:08 AM
rusted floor pan solution?? 94jpwrangler YJ Wrangler Technical Forum 3 12-07-2004 11:19 PM
Rotted Rusted Holes in Floor of my 87 YJ Chekdalaypa YJ Wrangler Technical Forum 1 09-13-2004 01:50 AM
