How to diagnose between starter problem or bad flywheel - JeepForum.com
post #1 of 10 Old 09-11-2011, 03:28 PM Thread Starter
weerwolv
Hi all,
My 1993 YJ 4.0 with AX15 is not starting well . Sometimes it will catch, other times it will not and their is a hell of a grinding sound.
How would one diagnose between chewed flywheel vs bad starter?
One way I guess would be visual by dropping the starter.
Any recommendations on how to go about step by step?
weerwolv is offline
post #2 of 10 Old 09-11-2011, 03:45 PM
SpikesHD
1987 YJ Wrangler
I recently had to replace my starter and flex disk. It would make an awful grinding noise and then start on the next try. The engine only stops in certain places (seems like there were three bad spots on mine) and once a bad starter chips those teeth everything goes South.
Unfortunately the new starter has already chipped a few teeth on the new plate. it's REALLY LOUD too! Scared the pants of bystanders when I start it.
A new starter would likely help for a while but I suspect your flywheel will need to be replaced.
Si vis pacem, para bellum.
SpikesHD is offline
post #3 of 10 Old 09-11-2011, 04:29 PM
moonshinefuel
Whatever you do, disconnect the battery before dropping the starter. Then get a visual.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #4 of 10 Old 09-11-2011, 08:01 PM
burnout189
its uncommon for the flywheel to need replaced.
9 times out of 10 you just need a starter. but yes the only real way to know is remove the starter and take a look.
BARNHART'S AUTO REPAIR
burnout189 is offline
post #5 of 10 Old 10-31-2013, 03:11 PM
95yj0645
Ok not trying to dig up an old thread but my ol POS is doing the same thing. I had a spare NEW starter so I put it in and it seemed to help for a few weeks but now its every single time I start my jeep it grinds. Itll run horrible for a minute or so and then its like a switch gets flipped and it runs fine. its an autozone flywheel (put in when I built my 4.6)
95yj0645 is offline
post #6 of 10 Old 11-01-2013, 05:35 AM
kloppk
If you find the ring gear is badly worn you can flip the ring gear and put it back on the flywheel so that the good side of the ring gear teeth now towards the starter.
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #7 of 10 Old 11-01-2013, 09:51 AM
superj
If you keep eating starters and flywheels, it might be the wrong starter on the vehicle. Two came on our jeeps, a ford type and a Mitsubishi type. One has a solenoid on the firewall and one has a solenoid on the starter and they have different lengths on the nose because the gears pop out a different distance
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #8 of 10 Old 11-01-2013, 09:52 AM
superj
What decides which starter to use is the year flywheel you have in the trans
superj is offline
post #9 of 10 Old 11-04-2013, 06:13 AM
vadslram
Step one, disconnect ground wire from battery
step two, remove starter.
Step three, Look at pinion gear on starter
Step four, take to AP store and have them put it on testor. It will tell you if the bendix is fully extending and if it has enough torque to engage.
Step five, look at teeth on ring gear while turning the engine using ratchet on vibration damper.
At any point if you see a problem feel free to stop and fix it
vadslram is offline
post #10 of 10 Old 04-10-2017, 10:50 AM
Kittels
The same thing is happening to my 1997 Jeep Cherokee Sport 4.0L I6 Automatic 386### miles . The starting problem started to occur after I replaced the distributor (because the part that holds the rotor had a decent amount of wiggle to it), the spark plugs, and wires which was done since i had a misfire in 1 and 5 according to an OBD. While that was being replaced, my ******* friend first replaced the cap, rotor, wires and plugs, which he put the cap on backwards and just threw the wires on in whatever order (*******) while no one was around who was mechanically inclined to make sure he was doing things right. In 2 weeks, I have time to drop the starter and see if its bad or plenty of time to fix the fly. And no, that isnt too many miles
Kittels is offline
New Starter New Flywheel....Help! jgowen YJ Wrangler Technical Forum 7 12-19-2010 04:56 PM
flywheel or starter? cmandes13 TJ Wrangler Technical Forum 5 11-08-2010 01:14 AM
Flywheel/Starter Problem HELP! Leia7987 YJ Wrangler Technical Forum 6 09-16-2009 06:55 AM
starter flywheel? newjeeper369 YJ Wrangler Technical Forum 0 05-01-2009 12:27 PM
Flywheel or starter???????? CanukYJ YJ Wrangler Technical Forum 7 09-30-2003 03:18 PM
