How to - Detailed 4" LED flush mount tail lights - Page 4 - JeepForum.com
post #46 of 61 Old 02-21-2012, 11:26 PM
SunDevilJeeper
This is almost exactly how I did it. Only difference is that I soldered the wires.
1991 YJ: Daily Driver
1992 YJ: Pile of crap sitting in the garage.
SunDevilJeeper is offline
post #47 of 61 Old 02-22-2012, 03:46 AM
roadyrob
1987 YJ Wrangler
thanks for the write up max just did the install yesterday, really looks cool. I also got the leds from amazon, 12 leds per light and super bright. didn't need a flasher.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #48 of 61 Old 03-12-2012, 05:23 PM
Jared24knapp
1987 YJ Wrangler
nice write up and awsome finish look
Jared24knapp is offline
post #49 of 61 Old 09-07-2012, 07:42 AM
sxi4evr
not to bring up an old thread or anything....... but i'd just like to make sure i have this straight. not replacing the flasher will make the LED lights blink fast, right? replacing the flasher will slow it back down but what about the front blinkers? wouldn't it slow those down way too much? also, the EL-12 flasher relay... what car is that found in? the auto zone guys always have to ask what make/model/year car that i need the part for lol thanks!
Check out my YJ!!!! http://www.jeepforum.com/forum/f22/first-timer-yj-build-1373716/
sxi4evr is offline
post #50 of 61 Old 09-07-2012, 08:07 AM
roadyrob
1987 YJ Wrangler
front and rear lights are controled by one fhasher, they both flash at the same speed. I would try the lights first, not all jeeps need the flasher, mine didn't.
roadyrob is offline
post #51 of 61 Old 03-27-2013, 04:25 PM
ziloh22
nice writeup im going nuts trying to figure this out now, im going to try this.. so the passenger side only needs to hook up the 2 wires from the LED light and then which wire gets grounded on this pass side?
2012- Gecko JK Rubicon Unlimited- building...
2007 JK Rubicon Unlimited- 3.5 RK X Factor 37s-SOLD
1995 Gecko YJ with a TJ Front- 35s
ziloh22 is offline
post #52 of 61 Old 03-27-2013, 06:42 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
The wiring is completely covered in the 2nd post of this thread.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #53 of 61 Old 03-27-2013, 06:47 PM
ziloh22
You are the man. Thanks for posting this man!!!
ziloh22 is offline
post #54 of 61 Old 06-16-2014, 12:57 AM
gtg413i
2003 WJ
Thanks for the help. Here's mine.
Brian's Black Betty Build:
gtg413i is offline
post #55 of 61 Old 07-16-2014, 08:48 AM
deogsxr
I followed this thread to the T a few months ago and was successful in installing my flush mounts. now need to wire in reverse lights.
*1995 YJ, 4.0l 5 speed.
*2006 Dodge 2500 5.9l Cummins Twin Turbo
*2010 Infiniti G37xS (SOLD)
deogsxr is offline
post #56 of 61 Old 07-17-2014, 01:06 AM
gtg413i
2003 WJ
Can you reverify on reverse wiring when you do, i cant seem to get mine working. Probably a bad connection, but i am only reading 8 volts from my reverse, so may e kts not strong enough to turn on the light. I can manually turn it on for now.
gtg413i is offline
post #57 of 61 Old 07-22-2014, 05:00 AM
Louie4
I use 4 LED bolt lights. They were cheap small and produce more light than stock. My build thread has the install.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #58 of 61 Old 10-10-2014, 01:30 PM
xlTravislx
Getting ready to try this out. I went with the Harbor Freight Lights. Ill post a picture of the end result when completed.
Thanks for the write up max!!
-White Jeep Club Member 231-
Replacing random parts on hunches spurred from other vehicles and peoples experiences with them is the safest bet.
xlTravislx is offline
post #59 of 61 Old 12-29-2014, 03:24 PM
92yjcoosbay
I put small reverse lights and a LED license plate light.
92yjcoosbay is offline
post #60 of 61 Old 01-03-2017, 07:45 AM
rollywrangler
Nice writeup!
rollywrangler is offline
Flush Mount Tail Lights ?!?!?!? usmctadpole YJ Wrangler Technical Forum 15 05-06-2010 06:30 AM
LED flush mount tail lights Harkins TJ Wrangler Technical Forum 8 10-10-2008 07:28 AM
Flush Mount Tail Lights tjSport06 TJ Wrangler Technical Forum 3 07-25-2008 03:45 PM
Flush Mount Tail Lights Black Hills TJ TJ Wrangler Technical Forum 19 03-19-2008 11:51 AM
Flush Mount LED Tail Lights Wheels4186 TJ Wrangler Technical Forum 23 05-28-2005 09:49 PM
