How to - Detailed 4" LED flush mount tail lights - Page 2 - JeepForum.com
post #16 of 61 Old 03-14-2010, 06:56 PM
littlejohn411
Great job,I really like this mod but i'm scared to screw up my tub.
GOT GUNS?
littlejohn411 is offline
post #17 of 61 Old 06-08-2010, 12:02 AM
8nine-sahara
great job as always max!
ill be doing this soon and this is exactly wheat i needed
89 yj
06 lj
8nine-sahara is offline
post #18 of 61 Old 06-08-2010, 06:43 AM
ZeroGravity
I also suggest soldering the connections, but at least it's in a somewhat accessible spot. Butt splicers; working 100% of the time, 50% of the time.
I like the LED lights and I'm considering doing them myself, great right up.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #19 of 61 Old 06-15-2011, 09:47 AM
southworth
Did you ever do a write up on the installation of the side markers and reverse lights? Thanks
southworth is offline
post #20 of 61 Old 06-15-2011, 09:53 AM
Andywear
I'm still running no reverse lights. What am I to do Max, I cant do it with out your how-to's
Used to have a good sig but Mod threated to ban me...
Errrrrrr, Will complain else where - &y
Andywear is offline
post #21 of 61 Old 06-15-2011, 09:55 AM
southworth
Found the LED side markers write-up by Mean Max.
Here is the link to that thread loaded with great info.
http://www.jeepforum.com/forum/f12/l...ite-up-861894/
post #22 of 61 Old 06-15-2011, 10:02 AM
giggityjeeper
I use butts sometimes, but usually shrink wrap them after as well
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #23 of 61 Old 06-15-2011, 10:03 AM
Andywear
thanks
Andywear is offline
post #24 of 61 Old 11-02-2011, 12:40 AM
Rollbar
1984 CJ8
Here are my side marker lights. Military NOS.
I plan on doing the LED upgrade (thanks for the write up) for the build to help make it look old school w/the OD/black etc.
Question, when doing the LED and the upgraded flasher, will the stock bulbs still work, or do I need to change out the bulb. If so then what bulb would fit? I see the ones at AZone but they look long for the front housing.
Thanks,
Jim
<----Click
<---- Click
Rollbar is offline
post #25 of 61 Old 11-02-2011, 02:03 PM
Rollbar
1984 CJ8
I just looked at the Scrambler and the top bolt for the stock light protrudes into the bed of the Jeep.
Just above that bend or shelf is where the top bolt comes out. I could go in that space (would have to measure to make sure) but then the wires will be in the bed.
See the left/right side/top hole where the light is shining through. That is just inside the bed and the housing is right there. I guess my only option is to get the ones that mount on the outside.
<----Click
<---- Click
Rollbar is offline
post #26 of 61 Old 11-02-2011, 02:25 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Have you considered using a side mount gas filler (like the '97-'06 TJ) and then mounting the LED lights lower? I'm just throwing an idea out there.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #27 of 61 Old 11-02-2011, 02:32 PM
Rollbar
1984 CJ8
Thanks for the idea, but I can't bring myself to do that.
Maybe I can find some exterior ones that are thin and not 180 bucks.
<----Click
<---- Click
Rollbar is offline
post #28 of 61 Old 11-02-2011, 03:37 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
I understand.
I guess I should avoid ever owning a rare, or older Jeep in excellent condition. I have no reservations in carving one up like a Thanksgiving turkey, which is fine for Jeep models that are plentiful, or ones in questionable condition. The problem is with me, I could roll a "one-of-a-kind" Jeep out of a museum & go at it in the parking lot with a plasma cutter. Comp cuts, boatsides, hi-line fenders, etc.
Max
Mean Max is offline
post #29 of 61 Old 11-02-2011, 03:49 PM
iced98lx
Jeeze I need to do this, but I just don't have the heart.
iced98lx is offline
post #30 of 61 Old 11-02-2011, 04:09 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Meh, it's just sheetmetal. Hack away!
Max
Mean Max is offline
Flush Mount Tail Lights ?!?!?!? usmctadpole YJ Wrangler Technical Forum 15 05-06-2010 06:30 AM
LED flush mount tail lights Harkins TJ Wrangler Technical Forum 8 10-10-2008 07:28 AM
Flush Mount Tail Lights tjSport06 TJ Wrangler Technical Forum 3 07-25-2008 03:45 PM
Flush Mount Tail Lights Black Hills TJ TJ Wrangler Technical Forum 19 03-19-2008 11:51 AM
Flush Mount LED Tail Lights Wheels4186 TJ Wrangler Technical Forum 23 05-28-2005 09:49 PM
