How deep is too deep - JeepForum.com
post #1 of 7 Old 01-20-2002, 06:30 PM Thread Starter
shea324@aol.com
So Friday I was messing around where I houldnt have been, and when I told myself - maybe its not too deep, I was wrong. What I thought wa 5" turned out to be more like 15". which instantly got me stuck seeing how the bottom was soft. And the more I struggled, the deeper I sank. So to make a long story short, I was over my hubs in water for about 10 minutes, then pulled out by a backhoe (don't ask) So now im wondering, could I have done any damage to my engine? I know I'm supposed to grease the wheel bearings, but I heard that they aren't serviceable or something like that?
90' YJ Four Banger, 2" Lift, 31" Tires, Many Mods to come
shea324@aol.com is offline
post #2 of 7 Old 01-20-2002, 08:29 PM
jpwranglr9
no they are not servicable. you probably didnt do any damage. a good thing would to be drain the diff fluids front and rear. thats about all you realy need to do. as long as water doesnt get to over your front signal lights on the grill you should be ok (if stock airbox).
Its not what you buy...its what you BUILD!!!
1995 YJ ,SOA with 4" procomp front 3.5" BDS rear 1" shackle rear, custom stearing, 35x12.50x15 pro-comp MTs, warn xd9000i, on-board air from A/C, dana 44 rear and 30 front with 4.56, powertrax no-spin rear, custom disks rear/trutrac front, warn front shafts, HD SYE kit, HD front and rear driveshafts, Warn 4X flairs, PIAA 520 ligts and on and on and on :)
jpwranglr9 is offline
post #3 of 7 Old 01-21-2002, 12:58 AM
Billy Badass
As long as you did not suck mud, water, or any other kind of crap into your engine you should be fine, but i do agree with changing the diff fluid.
As long as it runs you should be fine.
"Nothing like the feeling of braking something important and exspensive"
88' YJ 3" body, 32x11.50 ProComp Mud Terrain. JKBII Carb Mod. Nutter Bypass and a new ignition. White Faced Gauges with blue backlighting. Sone to come 4.10 gears and lockers.
Billy Badass is offline
post #4 of 7 Old 01-21-2002, 01:46 PM
AJ
I've been in mud/water over my headlights (temporarily) and blew my TPS and soaked my K&N. No other damage. Took about 5 hours to clean all the mud out of the interior tho'. Mental note, put the top up for mud runs.
AJ is offline
post #5 of 7 Old 01-21-2002, 02:29 PM
GothicJeep
GothicJeep's Avatar
On that note, anybody got any good ideas about snorkels for the yj? I've sucked water into my airbox twice and, thankfully, there's been no damage. It just kinda sucks (forgive the pun!)...
Goth...
JeepGeek Offroad Member v4.0
'Blue Zombie' (My 2002 TJ SE)
30x9.5 Hi-Tec Muds, Olympic Dave's Rack, and a BUTTLOAD of tow hooks...
My blog!
GothicJeep is offline
post #6 of 7 Old 01-21-2002, 07:44 PM
Darko
This guy I know went into water going too fast, he sucked water in his intake and broke his camshaft and 1st connecting rod, and also put a hole in the block.
Found a 85 CJ7 tub in good shape with
minimal rust. The resto continues....
Darko is offline
post #7 of 7 Old 01-21-2002, 07:56 PM
iamthemellowman
ahh, i was thinking the same thing gothicjeep. Maybe an attachment to one of those k&n pipes to allow easy removal when it is not needed and when you want some intake noise...
hmm, maybe i should see whats out there. i imagine that a cannister airbox for a normal cylinder typefilter should be able to be sourced....hmmm 30 minutes later,, maybe that would be harder than it seems.
'92 YJ, 4.0L, rs5000, bds 2", 30" for now.
iamthemellowman is offline
How deep I can go? sportman JK Wrangler Technical Forum 55 07-29-2009 11:37 AM
How deep is too deep? ggrodregez TJ Wrangler Technical Forum 70 08-01-2007 10:09 AM
How deep is too deep? sccabrian TJ Wrangler Technical Forum 23 06-14-2007 03:12 AM
WATER : How deep is too deep? msavard TJ Wrangler Technical Forum 39 06-23-2006 07:37 PM
Water crossings: How deep is too deep? Dirty Backroads TJ Wrangler Technical Forum 32 11-27-2005 06:18 AM
