How come the Jeep turns over soooo slooow? - JeepForum.com
post #1 of 12 Old 02-17-2008, 12:16 PM Thread Starter
Char250r
I have an 89 and a 91. They are both 4 poppers. Why do they seem to turn over so slow? My friend has a 95 with a 4 popper, and it doesn't like to turn over either. Once all 3 of them start, they're fine. My 96 4.0 Cherokee turns over quickly, and fires up almost instantly. Any body elses 4 bangers start like this? Or is it something I need to get used to?
Char250r is offline
post #2 of 12 Old 02-17-2008, 12:29 PM
tuckinauster
tuckinauster's Avatar
probably time for a new battery, or possibly starter. have both tested and see what comes up.
Originally Posted by P.J. O'rouke
"The Jeep is a manly device. And a womanly device. An American device. Itís a fitting instrument to transport the free people of a free nation with the respect to which we are entitled and the dignity that we deserve."
tuckinauster is offline
post #3 of 12 Old 02-17-2008, 12:32 PM Thread Starter
Char250r
I put my new optima in the 89. Turns over the same. Could very well be the starter. I find it weird that all 3 turn over the same... slooooooooooooooowwwww
Char250r is offline
post #4 of 12 Old 02-17-2008, 12:35 PM
WCoon
WCoon's Avatar
Add another 4ga wire from the battery to the starter. That sped my 4.0 starter up a lot! Also check your grounds, or add another ground from the engine block to the tub.
WCoon is offline
post #5 of 12 Old 02-17-2008, 12:36 PM
WCoon
WCoon's Avatar
If you're careful you can also test this with a set of jumper cables.
WCoon is offline
post #6 of 12 Old 02-17-2008, 01:00 PM
GatorsUF
if its turning over slow just hit the rock face a lil faster...she'll topple right over.
GatorsUF is offline
post #7 of 12 Old 02-17-2008, 01:58 PM Thread Starter
Char250r
She's all stock, so far. I'll be happy if she can climb the curb!!!
I have a ground from the block to the tub. I'm going to clean all the connections and see what happens.
Char250r is offline
post #8 of 12 Old 02-17-2008, 02:00 PM Thread Starter
Char250r
Do you mean put the positive cable right to the starter lug?
Char250r is offline
post #9 of 12 Old 02-17-2008, 02:28 PM
YJames90
YJames90's Avatar
I have the same problem. Im going to check this out when it gets warmer
My 2.5 to 4.3 swap thread
YJames90 is offline
post #10 of 12 Old 02-17-2008, 04:10 PM
WCoon
WCoon's Avatar
Yes. There is already a wire running straight from the battery to the starter terminal. Then there is a small 12V that is the turn-on lead that tells the starter to go. Basically you are just adding another way for the current to get there.
WCoon is offline
post #11 of 12 Old 02-17-2008, 05:51 PM
GatorsUF
My first guess would be a starter, of course I am an novice and that is a typical novice theory but if the current it getting there it shouldn't matter how directly, voltage drop could be an issue with bad connections but i guess your direct method should cancel that theory out.
GatorsUF is offline
post #12 of 12 Old 02-17-2008, 06:03 PM
RedneckYJ
Mine did the same thing until I put my optima in there. That cleared mine right up.Turns over just as quick as my truck and its a 350. Check your starter. Like was said before you can check this with a set of jumper cables.
Robbie
RedneckYJ is offline
My 95 YJ SLOOOW Build HanksRide YJ Wrangler Technical Forum 262 05-12-2013 05:48 PM
Soooo... Where to stash a pistola? AuburnTiger92 Wrangler General Discussion 18 07-10-2009 10:32 AM
Starter Turns, Motor Turns, Have Spark Still No Start greenerob YJ Wrangler Technical Forum 7 11-14-2008 03:33 PM
I'm soooo unsure on what to do first!!! NivekTJ03 TJ Wrangler Technical Forum 5 04-16-2008 08:12 PM
Heater not working, its soooo cold! youngjeeper11 YJ Wrangler Technical Forum 16 02-05-2007 11:04 AM
