How To Clean Cloudy Turn-Signal Lenses - JeepForum.com
post #1 of 12 Old 01-09-2008, 02:06 PM Thread Starter
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
This will work on all plastic lenses, but I'll pick the turn-signal lenses since they are the hardest to do. All those little bumps are hard to get into. Here is what my lenses looked like when I bought my Jeep back in '05. Sorry for the bad pic, but it's the only one I have of them back then.
All you need is some car polish, an old toothbrush (two would be better), some rags, and water.
Removing the lens from the Jeep wil make it easier. Dab some water on it, then put some car polish on the toothbrush, and brush away. You'll need to keep adding polish as you go. When your done, rinse it off, and wipe it with a cloth. After it dries for while, you will notice little spots where the polish is stuck in the bumps, Clean your toothbrush ( or use a second toothbrush) and brush that stuff out of there. This is the hardest part of the job. The second brush being dry will do a better job. Here is what that exact same lens looks like over two years later. It sits in the garage now if it isn't on the road, which helps alot.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is online now
post #2 of 12 Old 01-09-2008, 04:53 PM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
Great idea! Mine look almost white.
- Ernie
Richmond88yj is offline
post #3 of 12 Old 01-09-2008, 05:18 PM
pat8942
pat8942's Avatar
It works very well I have done the same thing to cars with the plastic headlights and they come out like new.
pat8942 is offline
post #4 of 12 Old 01-09-2008, 08:12 PM Thread Starter
Mr.B
Mr.B's Avatar
Your's may take more elbow grease.
Ham license:
Everyone is Welcome
Mr.B is online now
post #5 of 12 Old 01-09-2008, 08:27 PM
newtjrjrjr
thats a good idea to use a tooth brush, I normally use brake fluid to clean my lenses
newtjrjrjr is offline
post #6 of 12 Old 01-09-2008, 08:47 PM
wildchild
Try a compound called Plastex and a buffing wheel. I have used it on headlights and it works great too. But you have to be careful that you don't overheat the plastic.
wildchild is offline
post #7 of 12 Old 01-09-2008, 10:01 PM
RockWoRM
RockWoRM's Avatar
yeah... couple years ago, I used that same turtle wax pc to buff out the dash gauge's inside... oil, fuel, ect. Worked great. Got out all the scratch's. Now I can read the dumb things, again!
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #8 of 12 Old 01-14-2008, 09:44 AM
Lumpymayo
Okay, well after reading this I really wanted to give it a go.
I took pictures so I could have a nice before/after.
BEFORE:
DURING:
Now the hard part about this was getting the yellow cover off. It seems like there was glue or adhesive on it to hold it to the white part. I was hesitant at first to pry it off but I realized that even with out the glue holding it anymore, it wouldn't make any difference because of the screws that would secure it to the grill.
AFTER:
I really recommend doing this, takes about 10 minutes and makes it look so much nicer.
Lumpymayo is offline
post #9 of 12 Old 01-14-2008, 09:45 AM
Jeepkiddo
BEFORE:
DURING:
AFTER:
click free!
'89 YJ Islander
Originally Posted by MLJeeper View Post
The Dana 35 was a cruel joke.
Jeepkiddo is offline
post #10 of 12 Old 01-14-2008, 10:38 AM
RedMountainYJ
a little off topic but any know how to clean up soft top windows? i had a friend that said to buff them like that but im a little sceptical about it.
'95 YJ
RedMountainYJ is offline
post #11 of 12 Old 01-14-2008, 12:02 PM
Jeepkiddo
go on eBay and search soft top, there are plenty of things to clean it. If they are selling that good i guess they have to work.
'89 YJ Islander
post #12 of 12 Old 01-14-2008, 12:25 PM
GBogner
My daughter has a Subaru with cloudy head lights covers and I was wondering what I could do, short of replacing them! This forum is GREAT; Thanks for the tip!
93 ZJ Laredo 205,000
I-6 4.0L, 225/75/R15
GBogner is offline
Clear Turn Signal and Marker Lenses. Ferret TJ Wrangler Technical Forum 2 04-23-2009 10:03 PM
Turn Signal Lenses propped1 JK Wrangler Technical Forum 6 03-19-2009 01:47 PM
Driver side rear turn signal -- no signal --chris-- YJ Wrangler Technical Forum 5 02-23-2008 07:43 PM
Clear Lenses for Park Signal and Side Marker Erik T. TJ Wrangler Technical Forum 15 05-02-2006 07:02 PM
Clear Turn Signals and Parking lenses MC Sleek TJ Wrangler Technical Forum 7 01-16-2002 10:47 PM
