-   -   How To Clean Cloudy Turn-Signal Lenses (http://www.jeepforum.com/forum/f12/how-clean-cloudy-turn-signal-lenses-505495/)
Mr.B 01-09-2008 03:06 PM
This will work on all plastic lenses, but I'll pick the turn-signal lenses since they are the hardest to do. All those little bumps are hard to get into. Here is what my lenses looked like when I bought my Jeep back in '05. Sorry for the bad pic, but it's the only one I have of them back then.
http://i44.photobucket.com/albums/f1...loudylight.jpg
All you need is some car polish, an old toothbrush (two would be better), some rags, and water.
http://i44.photobucket.com/albums/f1...P1010021-1.jpg
Removing the lens from the Jeep wil make it easier. Dab some water on it, then put some car polish on the toothbrush, and brush away. You'll need to keep adding polish as you go. When your done, rinse it off, and wipe it with a cloth. After it dries for while, you will notice little spots where the polish is stuck in the bumps, Clean your toothbrush ( or use a second toothbrush) and brush that stuff out of there. This is the hardest part of the job. The second brush being dry will do a better job. Here is what that exact same lens looks like over two years later. It sits in the garage now if it isn't on the road, which helps alot.
http://i44.photobucket.com/albums/f1...P1010020-1.jpg
Richmond88yj 01-09-2008 05:53 PM
Great idea! Mine look almost white.
pat8942 01-09-2008 06:18 PM
It works very well I have done the same thing to cars with the plastic headlights and they come out like new.
Mr.B 01-09-2008 09:12 PM
Your's may take more elbow grease.
newtjrjrjr 01-09-2008 09:27 PM
thats a good idea to use a tooth brush, I normally use brake fluid to clean my lenses
wildchild 01-09-2008 09:47 PM
Try a compound called Plastex and a buffing wheel. I have used it on headlights and it works great too. But you have to be careful that you don't overheat the plastic.
RockWoRM 01-09-2008 11:01 PM
yeah... couple years ago, I used that same turtle wax pc to buff out the dash gauge's inside... oil, fuel, ect. Worked great. Got out all the scratch's. Now I can read the dumb things, again! :D
WRM :cheers:
Lumpymayo 01-14-2008 10:44 AM
Okay, well after reading this I really wanted to give it a go.
I took pictures so I could have a nice before/after.
BEFORE:
http://img.photobucket.com/albums/v3...p/IM000914.jpg
http://img.photobucket.com/albums/v3...p/IM000915.jpg
DURING:
http://img.photobucket.com/albums/v3...p/IM000916.jpg
http://img.photobucket.com/albums/v3...p/IM000917.jpg
Now the hard part about this was getting the yellow cover off. It seems like there was glue or adhesive on it to hold it to the white part. I was hesitant at first to pry it off but I realized that even with out the glue holding it anymore, it wouldn't make any difference because of the screws that would secure it to the grill.
AFTER:
http://img.photobucket.com/albums/v3...p/IM000918.jpg
http://img.photobucket.com/albums/v3...p/IM000919.jpg
http://img.photobucket.com/albums/v3...p/IM000921.jpg
I really recommend doing this, takes about 10 minutes and makes it look so much nicer.
Jeepkiddo 01-14-2008 10:45 AM
BEFORE:
DURING:
AFTER:
click free!
RedMountainYJ 01-14-2008 11:38 AM
a little off topic but any know how to clean up soft top windows? i had a friend that said to buff them like that but im a little sceptical about it.
Jeepkiddo 01-14-2008 01:02 PM
go on eBay and search soft top, there are plenty of things to clean it. If they are selling that good i guess they have to work.
GBogner 01-14-2008 01:25 PM
My daughter has a Subaru with cloudy head lights covers and I was wondering what I could do, short of replacing them! This forum is GREAT; Thanks for the tip!
The time now is 08:10 AM.
