How to check for vacuum leak and Idle air control valve - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > How to check for vacuum leak and Idle air control valve
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!NEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WDRough Country Jeep Suspension Deals at Rockridge 4WD!
Unread 01-05-2015, 05:12 AM   #1
Rangor
So my jeep has a very rough idle at start, where it will surge and then drop low to the point of the engine dying. Then when starting to drive, the engine will jerk and stutter. I've read on here that it could be a vacuum leak, fuel pump, or idle air control valve. My problem is A) I don't know how to test for vacuum leaks B) I don't know where the IAC is. Any help would be appreciated.
Rangor is offline   Reply With Quote Quick reply to this message
Unread 01-05-2015, 05:34 AM   #2
Chrisnvegas
Chrisnvegas's Avatar
I use an unlit propane torch around vacuum connections at idle. Follow the vac hoses for cracks or splits that are tough to see. Run it around the air intakes. (Throttle body and intake manifold)
If there's a leak, the idle will smooth out or raise up. Don't forget about the CAD vac lines.
People use carb cleaner the same way. I don't because it's flammable. If you use carb cleaner, have a fire extinguisher handy. carb cleaner works well and it's normally safe.
What happens in my Jeep, stays in my Jeep
Chrisnvegas is online now   Reply With Quote Quick reply to this message
