How to check transmission fluid? - JeepForum.com
post #1 of 3 Old 10-02-2009, 08:09 AM Thread Starter
Fhajad
Alright, AX-15, how do I check/fill the tranny fluid?
I know there's a bolt to undo somewhere, but I'm not sure on the location of the bolt itself.
And what's the best way to fill it up? Grab the bottle you need and a little hand pump?
Fhajad is offline
post #2 of 3 Old 10-02-2009, 08:13 AM
Louie4
Mean Max has some pics but I'll try to describe it. There is a fill plug midway up the tranny on the drivers side. I think its a 13/16". I used some vise grips though because mine was rounded. Take the plug out and stick your finger in and see if the fluid is at the bottom of the plug hole or 1/4" below. When I fill my tranny up, I put fluid in until it comes out of the hole.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 3 Old 10-02-2009, 08:14 AM
Reverb
Did a quick search for AX-15 fluid
http://www.jeepforum.com/forum/f12/b...ml#post7998950
Reverb is offline
Where do I check the fluid in my Transmission Mikey1234 YJ Wrangler Technical Forum 11 02-04-2010 07:18 AM
New to Jeeps How do you check the transmission fluid. Cranthor YJ Wrangler Technical Forum 7 04-01-2009 01:27 PM
How to check transmission fluid Wrangler_91 TJ Wrangler Technical Forum 3 07-17-2008 01:01 PM
How do I check my manual transmission fluid/grease? the2040 TJ Wrangler Technical Forum 5 06-30-2008 12:33 PM
How to check transmission fluid level? Ford4Now TJ Wrangler Technical Forum 19 04-09-2007 05:36 AM
