How To Check Fault Codes - Page 2 - JeepForum.com
post #16 of 25 Old 05-22-2012, 11:37 PM
pete1991YJ
Yeah, what ever happened to OldtimeIronman?
Meh. He's prolly "paying it forward" under an alias or something.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #17 of 25 Old 05-23-2012, 12:48 AM
MurtleDaTurtle
ecu
Originally Posted by monsteryjjeep View Post
no start 95 wrangler 2.5 4cyl. cut off going down the road will not start bad its getting fuel just no spark replaced the coil twice and still no good. Checked everythings getting power but the tps, map sen 5v with key in on position. Codes 22,23,24 show up when I checked it. I know what they are but dunno why they would stop it from starting or getting spark they just control the fuel lean,rich part. Any ideas? Would greatly appreciate any.
Ecu had the same prob with my 95 yj 4.0. before I replace it i would get three diffrent codes also when it would rain heavy for days it wouldn't start.I would let it sit with the key on for 20 min before it would prime. I replace the fuel pump because i didn;t hear it prime, come to find out you ecu tells the pump to prime and turn your ignition on. I found company out of davie florida paid 120 bucks for rebuilt ECU they are called Auto computer exchange direct. The owner told me it is common the resister start to leak acid and short the board out.It will send you false codes. Since that I haven't had a prob for two years now.
MurtleDaTurtle is offline
post #18 of 25 Old 05-23-2012, 10:11 AM Thread Starter
Que89YJ
Thanks.......Pete.
I heard that Oldtime had a sense of humor and well the moderators did appreciate it. Then again it might have gone just a bit too far......
I am sure he is still around helping out where and when he can.
Que89YJ is online now
post #19 of 25 Old 08-15-2013, 09:47 AM
CJ5_Fan
CJ5_Fan's Avatar
1980 CJ5
Apologies for reviving an old thread but I just got an 89 YJ with the 4.2 and I don't seem to have a 'check engine' light on my dash. (at least it isn't illuminating with my key turned on ) Is there a alternate way to pull the codes with the key method or is the only option thru the diagnostics ports? If so, can a light be attached to any pins in the ports that will read out the codes visually?
1980 CJ5 Renegade with 304 v8
CJ5_Fan is offline
post #20 of 25 Old 08-15-2013, 10:36 AM Thread Starter
Que89YJ
No diagnostics for the 87-90. You have to do it old school and use a meter, factory service manual, and common sense. You will find all the help you need if you post up a thread with the problem on the YJ.
post #21 of 25 Old 08-15-2013, 01:22 PM
CJ5_Fan
CJ5_Fan's Avatar
1980 CJ5
thanks. guess it is time to go 'old school' on it!
CJ5_Fan is offline
post #22 of 25 Old 12-09-2014, 08:23 AM
Sunshine1
I have a 1993 Jeep wrangler 4.0L 6cyl , automatic .
I have put new plugs, wire, distributor cap and rotor, new coil pack. Hears the issue I will be driving and all of a sudden it acts like its running out of gas, i have plenty of fuel in it, when you push the accelerator it will bog down and back fire a little , i can hear the fuel pump whining constantly, all of my gauges are fine, I'm not sure if you can hook a computer to a 93 to check whats wrong , should i go ahead and replace the fuel pump or o2 censor or both? I appreciate any and all help.
Thanks , Amy
Sunshine1 is offline
post #23 of 25 Old 12-09-2014, 04:27 PM
pete1991YJ
Thanks , Amy
Welcome to Jeep Forum, you've just found one of the best jeep sites anywhere!
Nope, there is no need to hook a computer to a 1993 jeep, in fact I don't think there is any way to do so. You can read the codes yourself directly off the check engine light.
Its easy and free, all you need is the ignition key. here's the updated video link that shows how:
In your case I would question the fule pump and or filter first - put a fuel pressure gauge on the fuel rail and see. It should be about 31 PSI.
post #24 of 25 Old 12-11-2014, 12:40 PM
TennesseeYJ
YJ's are real simple .. Video at the bottom of this link. Get DTC - Click here
Just turn the key on .. off .. on .. off .. on (not trying to start it). The trouble light will spill the beans!
1991 Jeep Wrangler YJ, <-- My Jeep is a pickpocket!!
1984 Mustang GT Top 5-Speed <-- Running soon hopefully
2003 Honda Shadow Spirit 750, 1994 Suzuki Katana 600, 1980 Yamaha XS650 <-- Ripped apart and under the knife .. Chopped, bobbed & mono shocked. I got too many toy$$$!!!
TennesseeYJ is offline
post #25 of 25 Old 05-23-2016, 05:32 PM Thread Starter
Que89YJ
Originally Posted by Bhynes17 View Post
Ok so I don't know how to use this sit lol but I have a 94 wrangler getting spark on and off could someone help please with the jeep problem and how to use this site lol thanks
Are you on a cell? Put up a new thread and fill.out your profile
Fault codes:
Mean Max pics of everything:
No Start:
fault codes BadApple1403 YJ Wrangler Technical Forum 6 06-20-2009 12:21 PM
FAQ - Check Engine Light and Diagnostic Trouble Codes (Error Codes, Problem Codes) Wheelin98TJ TJ Wrangler Technical Forum 6 05-15-2009 05:05 PM
Gas Cap and Fault Codes AferVentus TJ Wrangler Technical Forum 11 05-19-2008 03:35 PM
Fault Codes? SEMO 95 YJ YJ Wrangler Technical Forum 0 02-14-2008 04:41 PM
Check Engine Light - No Fault codes !! jreuscher TJ Wrangler Technical Forum 0 06-21-2005 08:29 PM
