How can I tell if my ECU is shot? - JeepForum.com
post #1 of 37 Old 03-28-2010, 01:30 PM Thread Starter
lexinator02
How can I tell if my ECU is shot? SHE STARTED!!!
I have a 90 yj with a 2.5L and a 5 speed and I am pretty sure my ECU is shot. Is there any ways I can use a mulitmeter to see if it is shot or do I just have to bite the bullet and buy a new one to see?
Dave
Low Output 4 Cylinder Jeep Club Member # 187
1995 YJ
lexinator02 is offline
post #2 of 37 Old 03-28-2010, 04:35 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Dave
When you turn your ignition to the ON (not START) position and your various dash gauges light, up does your CEL come on also? If it does it is probably OK.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #3 of 37 Old 03-28-2010, 04:57 PM
Que89YJ
Its a 1990 so it predates the SMEC or the SBEC so the CEL light isnt a good indicator. I guess the better question is why do you think the Engine controller is bad? Whats wrong with your jeep?
Que89YJ is offline
post #4 of 37 Old 03-28-2010, 06:20 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Since it was a 2.5 I thought it was since it has TB injection. But you are right that all started in '91 didn't it? But the good question is what you asked the OP..why do you think it needs to be replaced?
post #5 of 37 Old 03-29-2010, 06:03 AM Thread Starter
lexinator02
http://www.jeepforum.com/forum/f12/a...st-lol-991642/
I have this thread going I just wanted an individual question about the ECU. I would love an answer like take a multimeter at all these plugs on the ecu harness and you should get this value. That way I would know if the inputs and outputs are normal.
Dave
1995 YJ
post #6 of 37 Old 03-29-2010, 11:13 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
Dave
You would need to know the electrical values of all the pinouts on the brain whether they be input OR out put voltages. A FSM is the best place for that information.
post #7 of 37 Old 03-29-2010, 11:21 AM Thread Starter
lexinator02
well for the heck of it I decided to open up the ECU and check it out. I found a capacitor/resister completely burnt and cracked and the backside of the board was burnt in that spot as well so I think its safe to say my ECU is shot lol
Dave
1995 YJ
post #8 of 37 Old 03-29-2010, 02:24 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Dave
This link goes to one of several fixes for bad capacitors in a brain;
http://www.jeepforum.com/forum/f12/c...rs-ecu-492597/
post #9 of 37 Old 03-29-2010, 03:03 PM
Que89YJ
He has the renix controller on the Renix controller on the inside of the vehicle. Its the first time I heard of this happening. Pics would be appreciated. I agree though. It should be similar in the issues as the Sbec and it should be repairable. The cao should be on the input pin for power and should be easily replaced. A resistor would be a new one for me too.
Que89YJ is offline
post #10 of 37 Old 03-29-2010, 03:13 PM Thread Starter
lexinator02
Here are some pics of what I found. I could not tell if it was a resistor or capacitor...
Dave
1995 YJ
post #11 of 37 Old 03-29-2010, 03:39 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Dave
I think it is a big resistor. What you need to know is what was it's value. Can you see the stripes on it? That gives you the value.
Resistor Color Code Table And Calculator
post #12 of 37 Old 03-29-2010, 04:15 PM Thread Starter
lexinator02
no its solid black from being burnt. It does look a lot like the resistor in the 2nd pic though...
1995 YJ
post #13 of 37 Old 03-29-2010, 04:26 PM
wrangler76
Does the "R125" on the board specify anything useful?
wrangler76 is offline
post #14 of 37 Old 03-29-2010, 04:32 PM
JOExFROMxNY
R=resistor
D=diode
C=capacitor
Look for a number underneath it. That "R" might be for the resistor next to it.
JOExFROMxNY is offline
post #15 of 37 Old 03-29-2010, 04:33 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
That was my thought also it does look quite similar. I wouuld look inder the burntt one also and see if you can see any hint of the stripe(s) on it OR find one that is the same size and see what it's value is. Then buy one and swap out the bad one for the new one....What have you got to lose at this point?
Are my springs shot? GilpinTJ TJ Wrangler Technical Forum 4 06-14-2009 11:25 AM
Shot BJs AROSETO TJ Wrangler Technical Forum 4 10-23-2008 06:25 PM
my new JK shot by a BB Gun! etownjay8 JK Wrangler Technical Forum 31 09-26-2007 02:35 PM
a long shot but mudluva TJ Wrangler Technical Forum 2 01-07-2007 06:43 PM
D35 shot? prossett YJ Wrangler Technical Forum 5 09-26-2005 01:29 PM
