How to adjust TPS - JeepForum.com
post #1 of 9 Old 08-09-2005, 10:01 AM Thread Starter
Why J?
Why J?'s Avatar
How to adjust TPS
I made the mistake 5 yrs ago when i was stupid to take my jeep to pepboys to have it checked out before i bought it. Knowing better now. i am still trying to fix a problem that they caused. When they were checking it they decided that it was ideling to high so they adjusted the tps to lower the idel. Little did they know that it was ideling to high because of a leaking exhaust manifold. Anyhow. I need to get this thing into proper adjustment. Anyone know how to?
Why J? is offline
post #2 of 9 Old 08-09-2005, 10:10 AM
paintguy
year and engine? either way -- it is MPI -- I would take the TPS off the throttle body and there should be a shaft that slides into the throttle body (connected to the TPS) -- I believe by rotating the shaft it will either increase or decrease the idle -- which way does what, I don't know.
paintguy is offline
post #3 of 9 Old 08-09-2005, 11:08 AM Thread Starter
Why J?
Why J?'s Avatar
Sorry, it's a 90' 2.5l.
There is a bolt in the top of the shaft that can be turned up or down.
From my understanding it is adjusted at the plant and you are not suppost to touch it. So i'm sure there is a specific point it is supposed to be at so that the computer "knows" where the throttle is. If it is moved the computer no longer "knows" where the throttle is. I think?
Why J? is offline
post #4 of 9 Old 08-09-2005, 11:37 AM
SimonTuffGuy
[I'm That Good]
SimonTuffGuy's Avatar
I believe there are 2 ways of adjusting the idle (or that I know of - someone can/will correct me if I'm wrong)
TPS - which should be a little black box on the throttle body. It will probably have several bolts (I know my Festiva has 2, havent looked at the Jeeps yet) that will loosen it and allow that to turn. Turning it will turn the adjustment screw that paintguy was talking about.
Idle screw itself - which should also be located on the throttle body. There is probably a plastic cap over it and that will again turn either way with a screwdriver to adjust the idle.
These were the ways that I was able to adjust the idle on my Festiva.
SimonTuffGuy is offline
post #5 of 9 Old 08-09-2005, 11:39 AM Thread Starter
Why J?
Why J?'s Avatar
i'm not trying to adjust teh idel i'm trying to correct a start up problem with te engine reveingto high. I think it is being caused by an improberly adjusted tps.
Why J? is offline
post #6 of 9 Old 08-09-2005, 11:44 AM
SimonTuffGuy
[I'm That Good]
So once the engine is started and running, it idles normal?
post #7 of 9 Old 08-09-2005, 11:47 AM Thread Starter
Why J?
Why J?'s Avatar
When i start it it will rev up to 2000 rpm's and it sometimes stay there for 5-10 minutes. Sometimes it will come back down to 1000 - 800.
Why J? is offline
post #8 of 9 Old 08-09-2005, 11:51 AM
ncjeepinyj
ncjeepinyj's Avatar
Im not familar with how a 90 model is set up but it sounds like it might be the ISA (idle speed actuator you need to adjust or replace. I know when i swapped out the throttle body on my 95 it would idle high because i didnt swap out the idle speed stepper motor on mine. I believe that is what they started calling it in the MPI motors.
ncjeepinyj is offline
post #9 of 9 Old 08-09-2005, 11:52 AM Thread Starter
Why J?
Why J?'s Avatar
is that i the throttle body? Any other sensors it could be?
Why J? is offline
how to adjust linkage Hailchief TJ Wrangler Technical Forum 3 05-11-2008 10:48 AM
How do i adjust my headlights?? swsscb TJ Wrangler Technical Forum 1 04-09-2008 08:11 PM
How do I adjust the IAC on 1993 4.0? asw613 YJ Wrangler Technical Forum 4 04-04-2008 04:06 PM
Adjust the doors? Fierdon JK Wrangler Technical Forum 4 02-28-2008 03:02 PM
TC pinion too low -- how to adjust? paintguy YJ Wrangler Technical Forum 6 02-20-2006 04:10 PM
