Hot running transmission solution? - JeepForum.com
post #1 of 1 Old 08-25-2012, 04:11 PM Thread Starter
YJames90
YJames90's Avatar
700R4 runs hot at around 240 using the engine coolant and trans combo radiator. Measurement is taken from the pan
(260 when crawling)
Engine coolant runs around 170-180
Seperated the 2 and am using this dedicated trans cooler thats mounted behind the front grill
Now trans runs around 210.
If I run the line to the combo radiator then the aux cooler will the trans temp drop because the coolant temp is lower then the trans temp?
Heres the2 coolers in the YJ
And some flex shots
My 2.5 to 4.3 swap thread
YJames90 is offline
Best water-proof.. differential, transmission, and transfer case vent solution? awalp TJ Wrangler Technical Forum 30 10-30-2014 10:53 AM
Are you running a transmission cooler and which one??? GEM1N1 JK Wrangler Technical Forum 38 09-17-2013 03:43 PM
Transmission running too cool? chadsmeltzer TJ Wrangler Technical Forum 3 01-18-2011 05:01 PM
running without transmission? brundz YJ Wrangler Technical Forum 6 02-22-2007 10:02 PM
Transmission inspection results, (After running in mud) pwcracer TJ Wrangler Technical Forum 4 08-30-2006 10:45 AM
