Hot Passenger!... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Hot Passenger!...
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Poly Door Hinge BushingsStainless Steel Door Hinge Pins
Unread 12-19-2005, 11:17 PM   #1
PsychoRNGD
Hot Passenger!...
...side floor board.
I'm pretty sure its my cat but why would it be heating up the floor enough to melt my carpet
It ruined my carpet and a monster cable! (i don't really care about the carpet )
1992 Islander 4.0L I-6 5-Speed
A Lifted heep
Next Modifications[list][*]Custom Bumpers[*]On-board air[*]New marine sound system[/list]
PsychoRNGD is offline   Reply With Quote
Unread 12-20-2005, 12:06 AM   #2
CanadianJeep86
defective heat sheild? too much back pressure in the cat combined with the engine burning too hot?
1984 Suzuki SJ410, 1.3L 5speed, soft top, spoa, shackles, bodylift, 6 offroad lights.
1988 Dakota, 318, 5 speed, 4.10's, rollbar, lowered 3".
1986 2dr XJ, 2.8, 5 speed, Bushbar,
1989 XJ, 4.0, AW4, NP231, D44, 3.73's, *Stolen*
1987 MJ Sportruck, 2.5, AX5, Rollbar, *Jeep Heaven*
1986 MJ, 2.5, T-5, bushbar, Longbox, *Jeep Heaven*
CanadianJeep86 is offline   Reply With Quote
Unread 12-20-2005, 06:15 AM   #3
EABiker
Also, if you are running rich, the excess fuel will burn in the cat causing it to overheat.
EABiker is offline   Reply With Quote
Unread 12-20-2005, 06:34 AM   #4
Brown Dog
Vendor
Brown Dog's Avatar
I've seen this a couple of times. The heat shield is often the culprit, as mentioned by others. I would really suspect the back pressure problem caused by a clogged muffler, or a dead or dying cat.
Brown Dog Offroad
http://www.browndogoffroad.com
The Jeep Forum Discount is ON!!
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
3.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline   Reply With Quote
Unread 12-20-2005, 09:23 AM   #5
JJorda
Jeep. Jeep? Jeep! Jeep.
JJorda's Avatar
I had the same problem, turned out that the exhaust leak I was ignoring was pointing straight up to the floorboard, and directly at one of the drain plug holes. Melted out a drain plug and put a hole in the carpet before I noticed. It only did it on long uphill runs, so I couldn't find anything in my driveway at idle.
1989 Jeep Wrangler - Daily Driver and project - Red Jeep Club #216, NRA Jeep Club #5
1967 Chevelle SS396 - Main Project <--454, TH400, 4.10's, FAST
1982 Caprice Classic - Another project <-- 350/700R4, 4 wheel discs
1979 Honda Civic CVCC - Yet another project <--goal of 60 mpg
JJorda is offline   Reply With Quote
