Horn and steering issues - JeepForum.com
post #1 of 1 Old 08-09-2010, 04:35 PM Thread Starter
monkeyhouse
My steering wheel has been off 45 degrees since I got the jeep. Since it's sitting I decided to work on a few miscellaneous items, the horn not working being one. I tore the cover off my steering wheel last night and cleaned up the metal a bit with a wire brush, then I noticed the horn is rusted to the fender, so I pulled that off and cleaned it up. After I put everything back together, I noticed that the horn cover on the steering wheel really doesn't push in very far, but after reading a few posts from others trying to get their horn working, I decided to try beeping while jerking around on the steering wheel a bit. That's when I noticed that the steering wheel will actually push in if I push hard enough....and sure enough when that happens the horn does beep. So, what is hooked up wrong? I stopped short last night of pulling the nut off and seeing if the steering wheel would come off because I was running out of time before the first football game(and beers) and because I doubted that I would be able to just pull the nut off and the steering wheel would magically come off without a puller(nothing else has come off that simply, lol). So, I was just wondering if anybody had run into this before? Is the steering wheel supposed to push in like that? Or did somebody maybe take it apart and put it back together incorrectly? I'll know for sure this week, but figured I'd look for a head's up here first. Thanks!
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
87 Horn issues Bedlam_YJ YJ Wrangler Technical Forum 1 02-16-2010 04:34 AM
Horn does not have 12v at steering wheel Floppy YJ Wrangler Technical Forum 34 06-13-2009 10:29 AM
Steering Wheel/Horn Assembly ??'s danheit TJ Wrangler Technical Forum 8 12-06-2008 08:52 PM
Custom steering wheel & horn BlueDevil YJ Wrangler Technical Forum 6 06-05-2008 10:22 AM
Horn and Steering Column Collin369 YJ Wrangler Technical Forum 0 03-19-2005 12:15 PM
