Horn relay in 92 yj - JeepForum.com
post #1 of 17 Old 02-02-2009, 08:08 AM Thread Starter
Jay_NH92
Horn relay in 92 yj
I've looked under the dash in and around the fuse box. Where is it??
Black 92YJ 4.0 5 speed
Jay_NH92 is offline
post #2 of 17 Old 02-02-2009, 09:00 AM
Greg Phillips
Greg Phillips's Avatar
in the power distribution box...black rectangular box mounted in front of the battery...schematic should be printed inside cover to the box
1992 YJ , 2.5L 4 Cyl., 5 Speed Manual Tranny, 2.5" RE Standard, 31 x10.50/15 Bridgestone Dueler H/T's on Stock Wheels...for now!
Greg Phillips is offline
post #3 of 17 Old 02-02-2009, 09:09 AM Thread Starter
Jay_NH92
When i got the jeep, it didnt come with a cover on the box. I got one off of ebay and there is no mention of the horn relay
Jay_NH92 is offline
post #4 of 17 Old 02-02-2009, 09:15 AM
RJW95
if you are looking at the jeep from the front towards the rear im pretty sure that it is the relay in the back left corner of the box
RED 1995 YJ, 2.5L, 5-spd
RJW95 is offline
post #5 of 17 Old 02-02-2009, 09:23 AM
Greg Phillips
k...if it's oriented like mine ( standing by front wheel passenger side, facing driver side...narrow side of box being left to right) the topmost relay counting down goes...Horn, Fuel Pump, ABS Pump,AC, AutoShutdown,Starter, ABS SYS.Pwr.
post #6 of 17 Old 02-02-2009, 10:24 AM Thread Starter
Jay_NH92
I have the part to replace it and nothing matches up with whats inside the distribution box. Is it suppose to be 3 prongs??
Jay_NH92 is offline
post #7 of 17 Old 02-02-2009, 10:40 AM
bigsquat
here is a pic of whats what. all the relays are the same , so see if what you have matches the one you bought. i would think it would be a 4 pole , 2 poles for the relay coil and two for the dry contact , but i dont remember.
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #8 of 17 Old 02-02-2009, 10:49 AM Thread Starter
Jay_NH92
Looks like I'm going back to the advance auto parts. Thanks for the visual
Jay_NH92 is offline
post #9 of 17 Old 02-02-2009, 11:59 AM Thread Starter
Jay_NH92
I put the new horn relay. Tested it when the jeep was off. it worked. When i turned the jeep on it stopped working.
Jay_NH92 is offline
post #10 of 17 Old 02-02-2009, 01:26 PM
bigsquat
mine was acting wierd and so was some of my other relays. the problem wasnt the relays ,it was corrosion where the little blades go into the sockets. i put some conductive grease on the blades and pushed the relays in and out a few times and its now working fine. and the relays have 5 blades,In went and looked.
bigsquat is offline
post #11 of 17 Old 02-02-2009, 02:47 PM
Alfons
See if the relay is getting power when you have the jeep running. You'll need a multi-meter (or at least a circuit test light) and the following diagram - the pin numbers are on the bottom of the relay. First, set the multi-meter to OHMS, then remove the horn relay. Now, connect one probe to ground (negative battery terminal will be OK) and stick the other into the pin 85 or 86 slot and see which one causes the meter to show 0 (zero) ohms - this will be the pin that goes to ground. Now, change the multi-meter selection to DC Volts in a range that will include 12 (it'll probably be 20 VDC), and do the following:
  • Start the jeep
  • Stick the black (negative) probe into the slot that indicated it went to ground
  • Stick the red (positive) probe into the other slot (85 or 86)
  • Have someone press the horn button
  • You should read 12 volts if there's power coming to the relay with the jeep running.
If you use the circuit test lamp, do the following - this one is easier since you don't need to find the polarity of each pin on the low amp side of the relay:
  • Start the jeep
  • Stick one lead into the pin 85 slot
  • Stick the other into pin 86 slot
  • The light should come on if there's power.
Here's the pic of a typical auto relay:
Alfons is offline
post #12 of 17 Old 02-02-2009, 03:24 PM Thread Starter
Jay_NH92
I have to wait to mess around with it some more on wednesday or thursday. Once in a while I also do get the horn to work when its on. Its a mystery
Jay_NH92 is offline
post #13 of 17 Old 06-16-2010, 09:43 PM
juangolf
too much physics..had enough already
juangolf is offline
post #14 of 17 Old 06-16-2010, 10:51 PM
bigsquat
well it took you a year and a half to have enuff?
bigsquat is offline
post #15 of 17 Old 01-22-2011, 12:13 PM
Slicknickjames
Test
Slicknickjames is offline
Horn wont work, relay and fuse ok and horn works if direct wired Redskin TJ Wrangler Technical Forum 5 01-02-2010 04:24 PM
Where is the '92 horn relay? czjeeper YJ Wrangler Technical Forum 0 03-22-2009 12:39 PM
Where in hell is the horn relay???????? rustywrangler YJ Wrangler Technical Forum 11 10-08-2008 11:57 PM
Horn Relay yarosig YJ Wrangler Technical Forum 7 11-27-2006 08:00 PM
Horn relay sandman'sjeep YJ Wrangler Technical Forum 8 10-21-2005 01:34 PM
