horn not working (short circuit) - JeepForum.com
post #1 of 8 Old 06-09-2005, 02:54 PM Thread Starter
neil03
I recently removed my steering wheel in order to put a new dash in on a 92 yj. When i put the steering wheel back on the horn worked for a second then blew. It would work but only for a second. I checked the reinstallation of the parts i took off with another jeep and it was the same, however I figure i have a short circuit somewhere, but i am unable to access the electrical components of the steering column. please help
neil03 is offline
post #2 of 8 Old 06-09-2005, 03:26 PM
mYJ
When I changed my steering wheel I accidently popped the horn fuse under the hood. Its in the relay box next to the battery, check there too.
-Jeffrey-
92 YJ 2.5, OME, Flat Fendered, 31" Big O XTs, Crager Soft 8s, Posi-Lok, no sway/track bars, Exide Orbital, K&N, 4.0 TB & TBS, Mopar Performance Cam, Glass pack & Hi-Flow cat, Grant GT Removable Wheel, Tuffy Console, Other Stuff.
Black JeepClub V2.0 #33 - Me & Roy
mYJ is offline
post #3 of 8 Old 06-09-2005, 04:01 PM Thread Starter
neil03
horn fuse
I checked the fuse and it was blown. however whenever i put a new fuse in it keeps blowing. i checked the circuit with an ammeter and there is 17 amps of current running through it.
i looked at the wiring and beneath the fuse box but i have no idea what to look for.
neil03 is offline
post #4 of 8 Old 06-09-2005, 04:21 PM
bcshepard
go out and get a horn from a bus or MAC truck and wire yourself a pull wire across your roll cage.
bcshepard is offline
post #5 of 8 Old 06-09-2005, 05:59 PM
ecvjohn
If it was working good before you worked on it, it would almost have to be something you did.
Pull the wheel and check all visible wiring for pinches, bare spots and such.
Do you have 17 amps all the time or just when the button is pressed?
95 Wrangler- Stock for now
99 Ram quad cab
ecvjohn is offline
post #6 of 8 Old 06-11-2005, 08:37 PM Thread Starter
neil03
Yeah i keep getting 17 amps of current running through the fuse, but its a 10amp fuse. have you seen this before?
neil03 is offline
post #7 of 8 Old 06-11-2005, 09:16 PM
j-man
j-man's Avatar
thats because it's shorted. youre getting current from somewhere other than its intended source. this is the exact reason my dash lights dont work when i put my lights on. if i put the 10 amp fuse in the dash fuse slot, it blows. 20 amp fuse and it blows the next fuse in line for some reason. jeeps are freakin weird.
1988 Red Wrangler
2.5L 4 banger
soft top, half doors
pioneer cd deck, sony xplode speakers
cragar rims/30" continental
soon to come:
2.5 spring lift
1" body
31" tires (i like fender clearance :) )
Red Jeep Club #297
j-man is offline
post #8 of 8 Old 06-13-2005, 01:38 PM Thread Starter
neil03
how did you fix it then????
i checked the wiring to the firewall and it seems fine, but i can't get access to the steering column to check the wiring in there.
neil03 is offline
air bag/horn short? jake92321 TJ Wrangler Technical Forum 10 08-07-2009 01:22 AM
97 Horn not working? RyanBum TJ Wrangler Technical Forum 3 03-24-2009 01:37 PM
horn not working obsessedjeeper YJ Wrangler Technical Forum 7 11-08-2007 02:13 PM
I need help, I think I may have a short circuit boriqua97 TJ Wrangler Technical Forum 3 07-25-2007 01:56 PM
Horn not working! Iceman97tj TJ Wrangler Technical Forum 12 01-24-2003 02:20 PM
