Horn not working - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Horn not working
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep parts, deals and more at JeepHut.comTJ BDS 2" suspension lift!! FINALLY a GREAT 2" l
Unread 07-15-2010, 11:14 AM   #1
Wrangler11
Horn not working
My horn is not working. It's a 95 YJ 4.0. I don't even know where to start trouble shooting. I cannot live without a horn.
1991 Jeep Wrangler 4.0l auto
1995 Ford F350 Crew cab 7.5l
Previous Jeeps
2002 TJ, 1995 YJ, 2 1994 YJ, 1978 CJ7, 1970 CJ1, 2008 Grand Cherokee, 1997 Grand Cherokee, 1994 Cherokee, 1988 Comanchee
Wrangler11 is offline   Reply With Quote Quick reply to this message
Unread 07-15-2010, 11:38 AM   #2
DaleC
A common problem. Often the the contact ring under the horn button is rusty so good contact can't be made. Pull the horn button off the steering wheel and check. If rusty you can just wire brush it off and coat it with WD40 or any other anti rust liquid. I f this isn't it check your fuses and grounds. But I'd guess it's just a little rust.
Heres a quote from another thread on the subject.
Originally Posted by Low_2_Lifted View Post
just went throught this, it was the actuall horn button.
there are metal pieces inside that corode and rust over time.
To get to them pull off the "horn button" (the center piece in the steering wheel- it should pop right off) once inside you'll see round metal piece that had held the center cap in place.
Within that there are three phillips head screws. Unscrew those and pull it off with the plastic green ring (it's there to align everything in there correctly)
under all of that there will be a thin metal ring. This is the actuall contact plate that completes the circut for the horn.
If either of these pieces is rusted thats your problem. clean off any rust and put it all back together.
Oh yeah before you do anyof this make sure to unplug your horn or else it will be going off randomly throughout this process.
DaleC is offline   Reply With Quote Quick reply to this message
Unread 07-15-2010, 11:42 AM   #3
Wrangler11
That would be a quick fix if it's the rust. I'll have to check that once I get home. Thanks!
Previous Jeeps
Unread 07-15-2010, 11:44 AM   #4
Roadyy
When you pull the cap off there are 3 phillip head screws holding the center push on then 3 small screws holding the insulator to the wheel. Theres a pin and spring under the round slotted thin plate so be careful when you take the first 3 screws out it will go flying. Ask me how I know lol.
To make sure the problem is in the steering wheel push the pin and screw to the side to make contact with the metal and the sleeve that the spring sits in, if the horn blares then you know its do to the rust there.
Roadyy is offline   Reply With Quote Quick reply to this message
Unread 07-15-2010, 11:50 AM   #5
Wrangler11
I can do this without pulling the steering wheel?
Previous Jeeps
Unread 07-15-2010, 12:01 PM   #6
Roadyy
yes the horn contacts are all above the nut.
Unread 07-15-2010, 12:02 PM   #7
Wrangler11
Ok good. Thanks again.
Previous Jeeps
Unread 07-15-2010, 12:54 PM   #8
pasinbuy
Stupid question but did you check the fuse.. If I am not mistaken the horn and brake lights are on the same fuse.I did not confirm this but instead I am going off of memory.
pasinbuy is offline   Reply With Quote Quick reply to this message
Unread 07-15-2010, 01:03 PM   #9
Berniebikes
Also, suggest you check the wire connection to the horn in the engine compartment. It may have slipped loose like mine did, or it may have corrosion on it and not make contact. My horn is on the fender well below the hood, driver side.
Berniebikes is offline   Reply With Quote Quick reply to this message
Unread 07-15-2010, 01:08 PM   #10
Wrangler11
Mines in the same spot. I will have to check that too. Thanks for the heads up.
Previous Jeeps
Unread 07-15-2010, 07:34 PM   #11
Firedad
Check for a good ground to the horn. A weak or inconsistent ground will give a non-effective or weak horn.
Firedad is offline   Reply With Quote Quick reply to this message
Unread 07-15-2010, 07:46 PM   #12
hallsofstone
Is it bad that this simple fix has not been looked into by me yet? I've been using my loud pipes as a horn since I bought the heep...
I'll be looking into this when I make it home tonight.
[B][SIZE="3"][COLOR="Blue"] Jeeping Ohio Every Day[/COLOR][/SIZE][/B]
00 TJ Sport - Ever evolving DD/Rig [url]http://www.jeepforum.com/forum/f22/jeeping-ohio-hallsofstones-tj-build-1392513/[/url]
85 Suzuki GS700 - ugly
K.C.C.O. [url]www.thechive.com[/url]
hallsofstone is offline   Reply With Quote Quick reply to this message
Unread 07-16-2010, 05:26 AM   #13
Roadyy
I will also note that when I was repairing mine that once I had it all apart and cleaned put back together it still wouldn't work. I took it back apart and with the pin pushed against the spring touched the pin to the metal slot in sits in and it would work. Put it all back together and again not working. Bump the steering wheel real hard side ways and it started working,,lol Yea the old saying if it doesn't work with a gentle touch break out a BFH.. there was a loose connection below the wheel to the contact and guess it needed a lil wake up call. Worked fine since..
Unread 07-16-2010, 10:27 AM   #14
Wrangler11
You my friend are a very wise man.
Previous Jeeps
Unread 07-16-2010, 10:36 AM   #15
Roadyy
Don't know about the very wise part but a lil inginuity will go along ways toward figuring things out.....or hitting the wheel cause it's pissing you off for not working..lol
