Horn blows when it wants - JeepForum.com
post #1 of 11 Old 06-07-2010, 07:49 PM Thread Starter
johnboy68
HIP2BSQR
johnboy68's Avatar
I searched 6 pages of threads with the word "horn" it them and couldn't find anything close to my new problem.
My daughter came home and said "dad, my horn just went off without warning when I was driving home" I said "did you push it to make it stop?" and she said "no, it just stopped by itself after a few seconds".
So I passed it off as one of those things that just happens every now and then but...
We came home this evening after being out and the Jeep was just sitting there in the driveway with the horn blaring away. I don't know how long it was doing it but it couldn't have been too long because the battery was fine and the neighbors weren't out in the street gawking and now cops.
It's a 95 with an all stock steering wheel and horn. Any ideas what would make it just go off? All I had to do to get it to stop was press the horn. It seemed to have plenty of play at the button and I took the cover off and couldn't see anything broke or amiss.
I am at a loss.
Any ideas?
-John-
johnboy68 is offline
post #2 of 11 Old 06-07-2010, 07:58 PM
E5E
Mine was doing the same thing. I took it apart and noticed one of the spokes on the steering wheel was cracked and causing it to flex and make contact.
E5E is offline
post #3 of 11 Old 06-07-2010, 09:04 PM
bc yj'er
Try hitting the steering wheel with your hands to make it shake, see if it goes off. I had a similar problem with my XJ, (under the horn cover) the three screws that held down the green plastic ring were loose, causing the metal dome (popper for lack of better term) to bounce around and ground out.
how many jeeps do you have to have to be considered a collector?
bc yj'er is offline
post #4 of 11 Old 06-09-2010, 10:30 AM
Brown Dog
Vendor
Brown Dog's Avatar
X3^^^^ Had the same problem with the same cause.
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
post #5 of 11 Old 06-09-2010, 10:51 AM
vadslram
my 90 had the same issue. I don't know what your steering wheel looks like but mine had a center button (no airbag) I pulled on it and found out the flat spring in the center of the steering wheel broke and the two contacts could touch given the right angle and phase of the moon. It was an easy fix.
vadslram is offline
post #6 of 11 Old 06-09-2010, 11:14 AM
bword
pull off the rubber cover and take out the 3 screws and youll see a little nub sticking out underthat is a small spacer and under that is a tiny spring. If u dont see the spring its possible that its bouncing around in there grounding itself out causing the horn to go off randomly.
Selling a Totaled XJ in Ct..PM me for details
bword is offline
post #7 of 11 Old 06-09-2010, 11:56 AM Thread Starter
johnboy68
HIP2BSQR
johnboy68's Avatar
I would say the look the same. IIRC air bags didn't come in until the 97 TJ's. I will take a look at this tonight.
Originally Posted by bword View Post
pull off the rubber cover and take out the 3 screws and you'll see a little nub sticking out under that is a small spacer and under that is a tiny spring. If u don't see the spring its possible that its bouncing around in there grounding itself out causing the horn to go off randomly.
I am not sure what spring you are referring to. Do you have a picture?
-John-
post #8 of 11 Old 06-09-2010, 12:51 PM
bword
ill try to get a pic tommorow
bword is offline
post #9 of 11 Old 06-09-2010, 01:52 PM
Fhajad
None of us had airbags, yo'.
Fhajad is offline
post #10 of 11 Old 06-09-2010, 03:54 PM
vadslram
I didn't think any YJs did. Just using the airbag thing as an size indicator. Never sat in anything yj newer than mine and didn't know if there were plastic covered spokes on the stock wheel .
vadslram is offline
post #11 of 11 Old 06-09-2010, 04:26 PM
Brown Dog
Vendor
Brown Dog's Avatar
Airbags were not standard on YJ's. Although they MIGHT have been an option in 95.
Brown Dog Offroad
91YJ 2.5
2" BL
4.5" Superlift SL
AA SYE
Best Top seats
"Family" roll bar
Rained and the horn blows woody45 TJ Wrangler Technical Forum 7 06-17-2011 09:15 PM
Horn wont work, relay and fuse ok and horn works if direct wired Redskin TJ Wrangler Technical Forum 5 01-02-2010 04:24 PM
Hooking up aftermarket horn to '94 YJ. . .OEM horn wiring diagram??? atomicjoe23 YJ Wrangler Technical Forum 14 07-21-2009 06:39 PM
TJ Horn only blows fuses '51plymouth TJ Wrangler Technical Forum 7 09-11-2007 07:56 PM
Horn Blows kejhart TJ Wrangler Technical Forum 6 09-08-2005 06:29 PM
