Quantcast Hooking up aftermarket horn to '94 YJ. . .OEM horn wiring diagram??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Hooking up aftermarket horn to '94 YJ. . .OEM horn wiring diagram???
Old 02-26-2009, 07:42 PM   #1
atomicjoe23
The horn wiring circuit is not in the service manuals. . .and I'm trying to hook an aftermarket horn up on my '94 YJ. . .should be really straight forward except for the air compressor for the horn doesn't get enough power using the OEM hook-up (ground and switched 12V+). . .so I have to hook it up to the YJ using the relay that came with the horn. . .but I don't want a second horn switch. . .I want to use the stock horn switch.
I'm supposed to hook the compressor negative to chassis ground (done), hook the compressor positive up to relay post #87 (done), hook relay post #86 to relay post #30 along with running a wire from post #30 to the battery with an inline 20A fuse, and finally hook relay post #85 to the provided horn switch. . .and then ground the horn switch
. . .so if I wanna hook this up to my stock horn switch what do I need to do??? I know that the stock horn uses a 10A fuse located in the power distribution center behind the battery. . .other than that I'm not sure because I don't have a wiring diagram of what is going on. . .
. . .does the stock horn switch have a separate ground like the aftermarket switch or does it use the gound that the OEM horn uses. . .if it uses a separate ground then I'm good there and I can keep it that way. . .which would lead me to believe that I could hook the OEM 12V wire from the horn up to Relay post #85 and either run a wire to the battery with the inline 20A fuse or I just need to replace the stock OEM 10A fuse with a 20A and all should be good. . .right?
atomicjoe23 is offline   Reply With Quote
Old 02-26-2009, 07:55 PM   #2
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Ok, here is a breakdown of what I did for mine.
pin 30 12V power from batt, fused 20 amps.
pin 85 ground (I actually used the relay mount screw as my ground for the pump and relay)
pin 87 to compressor
pin 86 Stock horn wire
That is all you need to do.
http://i131.photobucket.com/albums/p...k_banner-1.gif
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote
Old 02-26-2009, 09:30 PM   #3
JFranko
JFranko's Avatar
^I did the same thing, with the same extremely high pitched horn
1992 YJ Wrangler 4.0L, NV3550, 2.5" suspension lift, 32" BFG M/Ts, lots of other cool stuff
RED JEEP CLUB MEMBER #494
JFranko is offline   Reply With Quote
Old 02-26-2009, 09:31 PM   #4
rustywrangler
Still trying to figure out how to lower the pitch just a little.
Old 02-26-2009, 09:31 PM   #5
Douglas S.
1987 YJ Wrangler
mmn, getting one of those this weekend!
1991 Land Cruiser HDJ81- 1HD-T Turbo Diesel, Factory F/R Selectable Lockers, Warn M8274, Webasto Thermo 90S
1987 YJ Laredo
Douglas S. is offline   Reply With Quote
Old 02-26-2009, 09:41 PM   #6
YJake
YJake's Avatar
Oooo I like it!
Does it make an obnoxiously loud scream?
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline   Reply With Quote
Old 02-26-2009, 09:44 PM   #7
Tompatt
1987 YJ Wrangler
It sound like mine??
[YT]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/_v6uUWM85wk&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/_v6uUWM85wk&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/YT]
Thomas
-1987 YJ
Jeep Build
Tompatt is offline   Reply With Quote
Old 02-26-2009, 10:03 PM   #8
YJake
YJake's Avatar
Wow that is high pitched. Better than the stock one I guess.
Sure wish I had an old Willy in any of it's forms so I could put in an Aoooga horn.
/l , [____],
()_) ()_)==@=)_)
Old 02-27-2009, 11:42 AM   #9
atomicjoe23
RustyWrangler. . .thanks for posting. . .that's what I was planning on doing, but I just wanted to make sure before I did it since I didn't have a wiring diagram with a complete horn circuit on it.
Old 02-27-2009, 01:50 PM   #10
JFranko
JFranko's Avatar
no, higher It's pretty goofy sounding, especially in a lifted Jeep, but it is loud as hell, which is a good thing, except when the horn button sticks and you have to jump out and pull the positive wire off of the compressor.
Old 02-27-2009, 03:25 PM   #11
Tompatt
1987 YJ Wrangler
yea. tell me about it.. but it is a chick magnet.. i honked it once and all the hot girls came over to honk it..
Thomas
-1987 YJ
Jeep Build
Old 06-04-2009, 11:58 AM   #12
jeep350chevy
1987 YJ Wrangler
old post i know, but where did you get the horn kit ?
jeep350chevy is offline   Reply With Quote
Old 06-04-2009, 02:05 PM   #13
schitzangiggles
King of Mac-istan
schitzangiggles's Avatar
Checker, AutoZone or even Walmart...
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline   Reply With Quote
Old 06-04-2009, 02:22 PM   #14
JFranko
JFranko's Avatar
mine was $40 at 4wd hardware, you could probably find it cheaper though.
Old 07-21-2009, 07:39 PM   #15
lewes2
Hey Rustry Wrangler - thanks for the nice, simple write up. You confirmed what I was going to do. However, I'm going old timey with an Ahooogggaaah horn. See:
http://secure.countywebsite.com/victorylane/product_info.php?cPath=104&products_id=816
[FONT="Verdana"][B][SIZE="2"]Chuck[/SIZE][/B][/FONT]
[FONT="Arial Black"][COLOR="DarkOrange"][B][SIZE="4"]
Member of the Impact Orange Jeep Group[/SIZE][/B][/COLOR][/FONT]
lewes2 is offline   Reply With Quote
Glock Forum
