Hood was shut over pin and latch is stuck. - JeepForum.com
post #1 of 6 Old 09-12-2011, 01:42 PM Thread Starter
eroc78
I am trying to help a friend that closed their hood and the pin was turned so the hood went over it. The latch is also jammed and looks to be off center. Any ideas of how I can fix it for them?
http://i84.photobucket.com/albums/k1...oods/jeep2.jpg
http://i84.photobucket.com/albums/k1...oods/jeep1.jpg
Thanks!
eroc78 is offline
post #2 of 6 Old 09-12-2011, 01:58 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
you "friend" needs to just work at it a while.
push it back center best you can and and work on that latch. If it's under pressure from the side it will be tough to so with out bending anything. Second option is to unbolt the hood then slide it over to release the pressure.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #3 of 6 Old 09-12-2011, 01:59 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
looking again, can you lift that side of the hood up enough to pull it out?h
Poke is offline
post #4 of 6 Old 09-12-2011, 02:16 PM Thread Starter
eroc78
thanks. Afraid the hood might bend if I try lifting it up to free up pin.
eroc78 is offline
post #5 of 6 Old 09-12-2011, 02:35 PM
HaskiE
HaskiE's Avatar
the Hood shouldn't bend, I've flexed mine as much as a foot from side to side lol. push real hard down on the center of the hood, and on the center latch (to your left) should pop open with enough force. Thats one shiny YJ you've got there!
#theneverendingaxe
HaskiE is offline
post #6 of 6 Old 09-12-2011, 04:24 PM
50rck
There are two little nuts holding that pin from under that fender. See if you can remove them, and maybe slide the pin out of the way.
1991 YJ, rebuilt 4.0L in spring 2009 at 234,000 miles, no lift yet, slightly offset wheels, 235/75/15 tires for now, rag top, sold the hard top. Over 35,000 miles on the rebuild and counting.
2006 Jeep Liberty. Nothing special, all stock.
50rck is offline
Hood Latch help LT1CJ7 TJ Wrangler Technical Forum 8 03-08-2010 03:09 PM
is this the right hood latch? vettefever5 TJ Wrangler Technical Forum 3 03-01-2010 12:27 PM
Hood latch stuck sonoran_Tj TJ Wrangler Technical Forum 3 04-07-2009 10:49 PM
Hood latch from a 97 ? YJames90 YJ Wrangler Technical Forum 4 10-21-2007 05:57 PM
TJ hood latch on YJ? asnbabyfce YJ Wrangler Technical Forum 4 08-29-2004 12:16 PM
