Hood scoops worth the money? - Page 3 - JeepForum.com
post #31 of 64 Old 11-20-2007, 07:03 PM
FunkSkunk
Sold my soul to JeepForum
FunkSkunk's Avatar
hmmmmmmmmmm.......
FunkSkunk is offline
post #32 of 64 Old 11-20-2007, 07:10 PM
FunkSkunk
FunkSkunk's Avatar
Well mine leaks all over the dang place! Not bad, but it is a pretty constant drip, especially when it's raining. I've replaced the windshield cowl and I just checked my hood vent thingy and hose and theres NOTHING in there! I was soooo hoping that there was going to be a bunch of sticks and leaves but there alas is nothing. ugh! I did notice something interesting though... The flap for the vent is in the under the hood grill and it is on the driver's side. Now the weird part was that when "closed" on the switch the vent door was still open about 1/2" or so, is that supposed to be like that or should it be tight closed?? I'm really curious if that is where the water is getting in. And if it was would it be leaking all along the bottom of the dash? HELP! I'm Tired of Weet shins and rusty floors!!
post #33 of 64 Old 11-20-2007, 07:30 PM
FunkSkunk
FunkSkunk's Avatar
Found the below quote in another post on here, thought it would be useful...
_______________________
Chances are pretty good that you should pull the heating system down, take it apart and reseal it.
There are 3 bolts that hold it on the firewall, you'll also have to disconnect the heater core, so drain about half your coolant first.
Taking out the passenger seat helps quite a bit with this.
Once you have it down on the floor, unscrew it, clean the halves well and then use generous amounts of black RTV between them. You'll notice that there is a hose that goes from a low spot on the heater assembly through the firewall and dumps out just under the battery tray on a YJ. If this is cracked, missing or cloged, you'll get water in your PASSENGER footwell.
If you're getting water everywhere, check to see if it's leaking out of the heater box, you'll see drips of water along the seam.
post #34 of 64 Old 11-20-2007, 08:09 PM
cosminciortan
cosminciortan's Avatar
Originally Posted by bestos
word, i am on it this week. I am growing tired of water in my floor mats everytime it rains!
same problem here. i pulled my carpets. still wet floor, pulled my plugs as well. works great
'95 2.5l red YJ. 35"BFG MTs on 4.5"SKYJACKER lift+ 5/8"Boomerangs, overhauled AX5 (still sucks)
smittybilt flares, bestop softtop and doors, double core aluminum radiator with Flexalite fan, new brakes allround, all poly bushings, armour
cosminciortan is offline
post #35 of 64 Old 11-20-2007, 10:11 PM
trailsnail
I did the water hose test on Sunday and believe that I have found the problem on mine. I ran water down the vent in the top of the hood and water ran through there with out issue. So I moved up higher on to the windshield and allowed water to run under the seal that covers the windshield at the bottom. After a minute water started to drip from under my dash. Don't have time to replace the seal right now so I got some RTV type sealant. I am going to give it a shot and see what happens.
2004 TJ Rubi
trailsnail is offline
post #36 of 64 Old 11-21-2007, 12:33 AM
FunkSkunk
FunkSkunk's Avatar
that bugs the Heck out of me because I have replaced that cowl seal and it's still leaking!? ugh
post #37 of 64 Old 12-05-2007, 06:58 PM
FunkSkunk
FunkSkunk's Avatar
OK - JUST bought the HOOD Scoop - I CANt run it backwards because the Windshield Washer squirters in the way. what did you guys do to get it on in the backwards position...??
I just purchased mine and I have the same dilemma, did you guys purchase the clear-ish smoke colored one from quadratec of did you get a different model? The smoke colored one I bought and it only attaches with adhesive sticker and no bolt holes. It actually goes around the vent grill not on top of it! WTF? I'm clueless, somebody clue me in so I can send back that scoop to Quadratec before it's too late.
*the only way I can see to run it backwards is to notch out the scoop base to fit around the windshield washers, but everyone else seems to have bolted their's on so I don't think I got the right one! HELP!
SO WHICH ONE???????
Mine --> http://www.quadratec.com/products/13006_11.htm
and the other one --> http://www.quadratec.com/products/13006_12.htm
THANKS GUYS!
post #38 of 64 Old 12-05-2007, 07:20 PM
swedishdwarf
swedishdwarf's Avatar
I have "the other one." It installed in ninety seconds right over top of the stock grill, facing backwards. It's invaluable if you don't have ac.
You can't teach an old dogma new tricks.
swedishdwarf is offline
post #39 of 64 Old 12-05-2007, 07:28 PM
FunkSkunk
FunkSkunk's Avatar
thanks!!!!!!!!!!!!!!!!!!
post #40 of 64 Old 12-05-2007, 07:35 PM
97MilitaryTJ
97MilitaryTJ's Avatar
Okey I'm too... Only problem is that I own a 97 TJ and they skip my year? What's up with that? Is there something different? Will another year work?
97MilitaryTJ is offline
post #41 of 64 Old 12-05-2007, 07:54 PM
Tritonman
2011 JK Wrangler
SO WHICH ONE???????
THANKS GUYS!
Same thing with me as well..im just going to notch it out carefully with a utility knife..not worth sending it back imo.
Tritonman is offline
post #42 of 64 Old 12-05-2007, 11:36 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
i did the same thing. brand new seal and it still leaked. after looking everywhere for where the water was getting in i said the hell with it and dropped the windshield again and RTV'ed the seal. I'd have sworn up and down that there was no way water could get by that seal, but i've been dry for months now. don't ask me why it wasn't sealing or how the water was getting around it, but it was, all along the bottom side of the seal where it meets the tub (the top half i RTV'ed from the outside). and yes, if it's leaking at the seal, the water will find its way to the bottom of the dash.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #43 of 64 Old 12-06-2007, 07:31 AM
muddy93
1987 FSJ Wagoneer
saw that this thread was still going, so I figured I'd show what I've done for a hood/cowl scoop.
I didn't want to spend the $$ to buy one, so I just made my own scoop.
I started by making a cardboard template of what I wanted, then cut the shape out of a scrap piece of stainless sheet metal that I had, and bent it using a couple blocks of wood and a hammer.
http://memimage.cardomain.net/member...74_47_full.jpg
I haven't had a chance to drive with it on yet, but we did get a couple inches of snow on Tuesday night, and the scoop seemed to do a prety good job of keeping the snow out of the cowl grill.
muddy93 is offline
post #44 of 64 Old 12-14-2007, 12:37 AM
Mumachog
[QUOTE=FunkSkunk]
SO WHICH ONE???????
and the other one --> http://www.quadratec.com/products/13006_12.htmQUOTE]
Yeah I got "the other one". I was skeptical of the idea of taping a part onto the jeep, and it fits facing the windshield without interfering with anything.
And to update, Had a few rainstorms since putting on the hard top this winter and not a drop of water inside (yet). still suspicous of the soft top channell holes...
93 YJ, 2.5L, 5spd, hard & soft tops, full doors, 2.5" procomp , 30" wal-mart ATs on AR tailgunners, 15-20 gas tank mod, CB (free), cheap front tube bumper , KC knockoff fog lights, tuffy console & trunk, badly done lined tub (PO)
Its all about cheap & free until I'm done with school.
Mumachog is offline
post #45 of 64 Old 12-14-2007, 08:48 AM
OneLung
OneLung's Avatar
I never thought about turning my hood scoop around to face the windshield (I'm blonde). Good idea. I'm going to go outside and turn mine around right now!
I knew there must be some practical reason I read this forum every morning!
OneLung is offline
Hood Scoops!! Yea Or Nae? DARRTILLM TJ Wrangler Technical Forum 48 02-10-2010 07:25 PM
Hood scoops uhohs YJ Wrangler Technical Forum 1 09-21-2009 03:13 PM
hood scoops ??? WHY-J YJ Wrangler Technical Forum 6 10-03-2005 07:28 PM
hood scoops NPerry05X TJ Wrangler Technical Forum 20 09-19-2005 10:46 AM
Hood scoops JBXdudeTJ TJ Wrangler Technical Forum 13 06-17-2005 05:50 PM
