Had one on my 90 YJ and it worked a bit better facing backward. Facing forward it would suck in snow etc. Didn't notice a big difference in temp of heat BUT, I did have alot more air come in. Also, prolly due to the lack of snow and ice in the vent.
all the holes match up if you run it backwards. You get alot more air flow a speed with it facing backwards, and you dont have the water and stuff comming in.
Open your hood and look just to the left of the engine on the fire wall. You'll see a black rubber hose connected to the firewall. Its about a 2 inch hose about 18 inches long just hanging down. Take it off clean it out and re-install, Dry feet for awhile! This is the air box drain that you are talking about putting the hood scoop over and it clogs with leaves and crap. When it clogs you get wet carpets.
The scoop mounted with opening towards windshield is great. Huge increase in airflow.
Well, after all the helpful insight, I decided to get one. I had $100 on a Q-Tec gift certificate, and I spent $99.96 (t-case shifter knob, Skyjacker steering stabilizer and the hood scoop), with shipping included. So, if someone needs 4 cents applied to an upcoming order, let me know :thumbsup:
My question is this. Today I was driving home in the rain, and my left shin was getting wet. Is this a common thing? Is that where the water is initially coming from?
It's not from any problem that a hood scoop will fix. Probably a leak in the weatherstripping around the windshield or in the vent hose that has been mentioned a bunch of times in this thread.
I wasn't getting a hood scoop to keep water off me, I just wanted a little more wind with my heat in the winter...
My leak ended up being the cowl seal when I had that problem. I found it by running a hose over every metal to metal seam, starting at the bottom and slowly working my way up until water started running in. Since my Jeep is black, I bought some roofing sealer, the stuff they put around flashing and plumbing vent tubes. I ran a bead along the entire cowl seal (after cleaning it out really well) and ran my finger over it to smoothen it out. No more leak.
I park most of the time under a huge cherry tree - lots of leaves, stems and pits to clog the vent. I too have been thinking about picking up this scoop.
Curious as to how well paint adheres to this material. Any one know 1st or 2nd hand? Anyone know a good spray paint match for jeep's red?
Could also use an improvement in air flow which this is supposed to enhance.
i have cleaned the rubber tube, and a small amount of water is still there. my weatherstripping is old. I want the scoop for airfolw and to keep the 18" tube clean as well.
where would i get new weatherstriping? is there a thread on putting that on?
you mean the cowl seal? quadratec or 4wd hardware.
to do it right you'll need to flip the windshield down (disconnect sport bars) and put the seal on... it attaches to the body via small screws. when installed the windshield being upright squeezes the seal for a tight fit. the hardest part i've found is getting the sports bar close enough to the windshield to screw the torx bolts in and snug everything up.
OK - JUST bought the HOOD Scoop - I CANt run it backwards because the Windshield Washer squirters in the way. what did you guys do to get it on in the backwards position...??
Here's what ya do...using either 320 grit sandpaper wet, or red Scotchbrite dry, put some tooth on that plastic. Trot yourself down to your local auto body supply store, get either a rattle can or a pint/quart of Bulldog (if you are using HVLP equipment). This stuff is a flex/adhesion enhancer, works REAL well on plastic, flares, or when you shoot your hardtop. After you get good tooth, use a tack rag LIGHTLY and tack off the surface, then spray on a coupla decent coats of Bulldog...two coats are all that are necessary. Then shoot your color over that.
Now, about matching that paint...you're gonna have your new friends at the auto body supply store help you with that one...find the paint code on the vehicle...provide it to them and they can get you matching paint. Ya gotta keep in mind that new paint will never match aged paint, although there are some painters and paint mixers that can come within about 10%...
If you can't find the paint code, a lotta those supply stores can use their computer to shoot the surface your vehicle and it will come back with the proper code...failing that, the store will have a color chip book, and you can match the paint up to the year and make of your vehicle, and from there to the color chip.
Red is the worst of all colors in terms of fading, oxidyzing, and just plain wearing out. Don't expect miracles...also, it may be that your vehicle has been repainted previously and then all bets are off, you'll have to resort to the computer matching, or guess.
Many, but not all, autobody paint suppliers can package the proper color in rattle cans...BUT not just one, you're gonna have to buy multiple cans...which ain't a bad idea anyway, really..
Good luck
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
