Hood latch stability - JeepForum.com
post #1 of 32 Old 02-08-2013, 12:50 AM Thread Starter
demonz0
I noticed that at any speed over 80 km/h (50 mph) the hood bounces around when it's catching wind. Now I am afraid somehow that the hood will release and cause some serious danger/damage. They're tight but obviously not tight enough if its moving around.
It has the skinny hood latches from the earlier model YJs. I know there are thicker ones because thy were on before but rusted out.
99 Cherokee 4.0L | 4.5in Lift | 33x12.5
94 YJ 4.0L | 4in RC Lift | 33x12.5
demonz0 is offline
post #2 of 32 Old 02-08-2013, 01:00 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
As long as the center is locked it should be just fine. Have you considered changing out to the rugged ridge replacement side latches? How are the rubber standoffs that the hood sits on?
Luck Favours The Prepared
Anticanman is offline
post #3 of 32 Old 02-08-2013, 01:24 AM Thread Starter
demonz0
Well the center lock release before when the hood latch failed and caused all the damage to the hood. I have not looked into other replacement latches yet but am considering it now. The standoffs are are all in good shape.
demonz0 is offline
post #4 of 32 Old 02-08-2013, 03:42 AM
timatoe
timatoe's Avatar
You need to replace the center latch, and I'll bet the rubber bumpers on top of the radiator support (that's what Anticanman was talking about) are less than half the original thickness. After replacing mine, I have to push down a bit on the center of the hood in order to get the center latch to move. They're cheap too like two bucks each or something.
timatoe is offline
post #5 of 32 Old 02-08-2013, 07:17 AM Thread Starter
demonz0
You are right because the centre hood latch grabs and holds but is loose. The hooks hold it down but it still moves like a inch or less. Basically watching your good dance at 65 mph is not fun at all... Lol
demonz0 is offline
post #6 of 32 Old 02-08-2013, 09:35 AM
jokerchief462
When I get to 75mph crazy things happen the hood dances and the speedo broke so now it has to be driven under 75 because I think that is where it will stay together. I notice mine dances a lot after the trucks pass but other than that it is OK. Maybe an adjustment I have never looked at the center mechanism closley.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #7 of 32 Old 02-08-2013, 10:19 AM
blown50
1987 YJ Wrangler
100+ mph in mine, only problem at that speed is the wipers lift off the windshield! Hood stays put
blown50 is offline
post #8 of 32 Old 02-08-2013, 11:30 AM
Randonexplosion
Deplorable
Randonexplosion's Avatar
Randonexplosion is online now
post #9 of 32 Old 02-08-2013, 12:18 PM
Rproject
1987 YJ Wrangler
I'd like to call BS on this one. I've never seen a Jeep, much less a YJ, go over 100mph with stock components and since the poster doesn't have an info listed about their vehicle. I'm calling it ----- BS.
My hood used to bounce until I replaced the rubber feet that cushion the hood to the fenders.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #10 of 32 Old 02-08-2013, 12:22 PM
sxysouthtx
My jeep can easily cruise 85 on a good flat road. But I have the 32RH.
Not much motion in the ocean, but I'm the captain.
sxysouthtx is offline
post #11 of 32 Old 02-08-2013, 12:27 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I hit 100 mph once. Stock 4.0. Stock ax-15. Massive tailwind.
post #12 of 32 Old 02-08-2013, 01:33 PM
Stingray427
Put some vents in your hood like I did to relieve the pressure:
Even lets some heat out.
Stingray427 is offline
post #13 of 32 Old 02-08-2013, 02:03 PM
roadyrob
1987 YJ Wrangler
those vents look just like mine, I mounted them farther back tho. picked them up at a junk yard off a 280z. they do let a lot of heat out.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #14 of 32 Old 02-08-2013, 02:05 PM
blown50
1987 YJ Wrangler
Mine is not stock, 287 CI stroker motor! Professionally tuned! U wanna drag?
blown50 is offline
post #15 of 32 Old 02-08-2013, 03:02 PM
Stingray427
These are the Pontiac Grand Prix vents, bet those Z vents look sweet! Post some pics.
I moved them forward on mine since I was more concerned about hood lift than heat. They have completely eliminated any hood flutter and I like the way they look towards the front following the lines of the raised hood section.
