Hood Bumpers - JeepForum.com
post #1 of 6 Old 10-01-2013, 04:36 PM Thread Starter
DustyGeneral
Hood Bumpers
Probably not the ones you guys are thinking of. Awhile back when I was installing some lights on my bumper and I was going in and out of the engine bay. Long story short the wind was blowing pretty good and when I opened the hood to rest in on the windshield the wind grabbed it from my hands and it slammed against the windshield metal. I said a few choice words and immediately put some clear coat where the paint chipped off.
Now there is a little bit of rust on hood where the paint chipped. I dont have a pic right now. If you look at your YJ hood there is that raised section that is on the hood. My chips are where that raised section would meet the windshield (one chip on pass side and the other on the driver side). I dont want to have to paint that section because I doubt I will be able to mix the exact color for that small job.
SOO what I was thinking was to clean up the rust, prime or clear coat it, then get some rubber stoppers and put them right over where the chips are.
That way it can double as a cover up and have the function of "isolating the hood from the windshield when i lay it back" lol. Anybody done this before?
DustyGeneral is offline
post #2 of 6 Old 10-01-2013, 07:25 PM
squarelite
Rubber cut to size/shape and an adhesive. Never seen it done before , but that is how is do it. You can also probably cut down a body mount puck or dock bumper and bolt it through the hood
squarelite is offline
post #3 of 6 Old 10-01-2013, 07:33 PM
kjg26
kjg26's Avatar
TJ hood bumper
http://pages.ebay.com/motors/link/?n...d=330952965678
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #4 of 6 Old 10-01-2013, 09:01 PM
jokerchief462
Poison spyder vented hood. Mount a light bar with a 24" led. I had the same problem only a little wrinkle no paint chips.
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #5 of 6 Old 10-01-2013, 09:33 PM
kjg26
kjg26's Avatar
Any pics?
kjg26 is offline
post #6 of 6 Old 10-01-2013, 09:46 PM
GrantYJ
If you opt for primer, use primer/sealer. Primer isn't a barrier finish (metal that has been primed will still rust).
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” ― Robert M. Pirsig, Zen And The Art Of Motorcycle Maintenance: An Inquiry Into Values
GrantYJ is offline
