#1 | |
homemade snorkel
i am thinkin about makin a snorkel and could use some help. so if anyone could give me some ideas on how to do it,what to use and possibly some pics, it would be much appreciated
#2 |
BUILT. NOT BOUGHT.
go to lowe's plumbing dept, get creative... you'll spend $60 or so on everything including all couplers, hole saw or jig saw, piping, clamps, grommets, filter, etc by the time you find deals on everything...
or spend $250 on a bolt on snorkel that looks great, fits great, and will take you less than an hour to install as opposed to the day you'll spend moaking one my opinion.... not worth the time to make one when you can buy one that works great for not all that much money. -Erik <---- made one for my friend's grand cherokee... it worked great, but looked too homemade
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS! |
#3 |
Head Brewmaster
heres a link to a write up i did on mine
http://www.jeepaholics.com/support/topic.asp?TOPIC_ID=45640
92 YJ. High Output 4.0L Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods My RigRater Score: 682RRv1.0 with a BOA of 13.47 I'm now doing custom bumpers and lift installs in So-cal |
#4 |
what companies offer bolt on snorkels?
#5 |
ARB! i plan on getting one soon. can get one from them for $300
93 YJ- SOA, R.E 1.5" Leafs, Custom paint, 35x16 Boggers,15x10 97 series rockcrawlers. Diamond plated interior and exterior, Tera SYE/CV DS, Herculined Tub, Bestop, Warn Bumpers w/ 9.5ti, 8.8" rear, D30 front, both ARB's with 4:88's, Super 88, Posi-Lok, Alpine Stereo, Tuffy Security, Hella Fogs, ProComp Spots, and much more. 07 2500HD D-Max CC LB Black Ranchhand Bumpers, MBRP 5" Straight Piped Exhaust, Edge Evo, N-fabs, 305/65/18 BFGs on Black Motos, much more soon to come! (Sold)03 Z71- 33x12 BFG Muds, American Racing Victor Teflons, K&N intake, Gibson Exhaust, Ranchand bumpers, Hypertech programmed, Hella Spots, 12" JL sub, and much more. |
#6 |
How come you want a snorkle? Are you going to be forging deep water often? I personally, I would save my $300 (that is if your going to buy one). I would focus more on "water-proofing" your jeep. Many do not do this, get all jacked up in water, and don't know why. They assumed they were okay because they had a snorkel.
Try to get some dielectric grease and cover any exposed electrical contacts including the bottom of your distributor cap, in the boots of your plugs, etc. I hear vaseline does the same exact thing, but I've yet to try it. I'm pretty sure its true though. If you are set on getting a snokel save some money and do it yourself, it really isn't too hard. Some good examples can be found by doing a search on the entire forum. Honestly, it doesn't matter if the snorkel idea is from an XJ, TJ, etc., you can use the same principals ya know? I know there was a set up that I'm going to do that envolved cutting a hole through the firewall into the cowl vent area having a filter in there and a tube coming from the filter into the tb. Put a scoop on it and you have ram air. Everything you need is in a cheap 91-94 (i think) civic cai kit.
'94 Wrangler - Traded '87 Trans Am - SOLD '99 Cherokee Classic Last edited by bokey; 06-07-2006 at 11:06 PM.. |
#7 |
i've allready started waterproofing everything else(using grease,works great) i just don't like where my intake sits, and we do go through a lot of water.
#8 |
Head Brewmaster
A snorkel has other benefits besides water crossings. out here we have issues with dust. the dust will clog an air filter in no time. by using a snorkel, you keep the air intake up higher, this helps cut down on the amount of dust getting sucked into the filter so it clogs less
#9 |
quick question... explain more about water proofing. I have a small sub box and amp in the rear and I'm afraid it will get shorted or spark if its too wet. other then complete enclosures, what should I do for things like that?
'93 Wrangler...close to stock... |
#10 |
im wanting the arb snorkel mostly for the look..... but another reason i want to get one is just like green said, to help out with dust and they can get better air to ur airbox sometimes giving alittle extra power.
#11 |
LUKSI----all u need to do is put grease, or vasoline, over all of ur exposed electrical connections, and around the base of ur distributer cap. it should work for ur amp and subs also. well at least the connections i don't know how "waterproof" ur subs and amp are.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
