Homemade Rockers - JeepForum.com
post #1 of 20 Old 02-20-2012, 04:44 PM Thread Starter
WJRhoAds
Homemade Rockers
My brother and I made these rockers for his 87' YJ.
First we started by tearing off the stock plastic runners and the metal step.
That consisted of unbolting/cutting/drilling/grinding out all the bolts.
We had some 1/4" plate laying around the house that we cut in half to get two 4"x50" pieces. We cut the angle in the plate to match the back fenders.
Then we cut 1" pipe to 49" for the top two rails and 1 1/4" pipe to 48 1/4" for the bottom rail (that was also laying around the house). We cut both of the back ends to match the angle of the plate's back end. For the 1" pipe we centered and welded it to the plate. For the bottom (1 1/4") pipe its kind tough to explain so bear with me... We layed the plate and the bottom pipe flat on the table. Then we placed the pipe against the plate so that once welded it would sit flush on the back side, side that goes against the jeep. Sorry we don't have pictures of the actual process but you can see the end result in a few of the pictures later on.
Then we drilled the holes for the 1/2" bolts, putting them pretty much where ever they would go. We first drilled the holes into the plate, clamped it on the jeep where we wanted it, and drilled the holes into the jeep sheet metal.
To protect the body we placed it on the Jeep so that we had about 1/2" that extended below.
Then came the task of making the cross pieces out of more 1" pipe. Four top (2 per side) Six bottoms (3 per side). We cut the saddles by using a hole saw, drill press, cutting oil, and about 4 of hours of work...we really wish we had a torch... The top we cut to 1 1/2" and the bottom to 2 1/2".
We squared up the two top cross pieces and started welding.
Then on went the 1" pipe...
Then the bottom cross pieces...Sorry no pictures of that.
We painted it with Rustoleum Bedliner. And after all that the final result is this!
WJRhoAds is offline
post #2 of 20 Old 02-20-2012, 07:50 PM
40dog
looks good but maybe you should sweep the open ends on the top in to help avoid hanging up on things such as brush and garden gnomes. Best part about fabricating at home is possibilities are endless.
40dog is offline
post #3 of 20 Old 02-20-2012, 09:11 PM
jode
Quick question - is there anything that goes under the lip of the body? Or is it just the plate part bolted on to the outside of the body?
I'm mulling over my own homebrew designs so it is interesting to see what you have done. Cool that yours looks like it is pretty stout.
Hung like Einstein and smart as a horse...
90 YJ, 2.5L, 5-speed
jode is offline
post #4 of 20 Old 02-20-2012, 09:45 PM
40dog
Good question .They appear tough . Design that could go many different directions.
40dog is offline
post #5 of 20 Old 02-20-2012, 10:45 PM Thread Starter
WJRhoAds
40dog we plan on making custom fenders in the future and tying the rockers and fenders together, so we decided to leave them unfinished for now. Although we had totally forgotten about the dangers of lawn nomes...now we may have to address that sooner than later haha
WJRhoAds is offline
post #6 of 20 Old 02-20-2012, 11:01 PM Thread Starter
WJRhoAds
Jode it's not connected to anything other than the sheet metal. We thought about placing another plate on the inside and bolt it all together. Make a plate-sheet metal-plate sandwich to disperse the weight more evenly. But as you can see from the HighLift picture it seems to take the weight very well, no bulging of the sheet metal or anything like that.
WJRhoAds is offline
post #7 of 20 Old 02-21-2012, 08:12 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
I think that's a pretty neat home brew project. I think you need to do something to each end, bend them in to meet, just so that far one isnt sticking out so much.
I'd put a set of those on my crawler.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #8 of 20 Old 02-21-2012, 08:14 AM
Louie4
Looks cool to me. I also think you should have the outer bar bend in to meet the inside and try to cap the tubes to seal out water, dirt, etc.
Good job.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #9 of 20 Old 02-21-2012, 10:08 AM
ohio79
2011 JK Wrangler
Looks good. Whats the material cost for the sliders
ohio79 is offline
post #10 of 20 Old 02-21-2012, 10:28 AM
vadslram
Nice Job
Did you consider angling in the front and back? seems like the open pipe is going to collect mud etc and rust plus Mr. Murphy and his law are sure to strike with you hooking a sapling between the two tubes.
vadslram is offline
post #11 of 20 Old 02-21-2012, 10:58 AM Thread Starter
WJRhoAds
Thanks for input guys! Like I told 40dog we plan on making some custom fenders and tying it all together, so for now we left them somewhat "unfinished". But it would be a good idea to at least plug the ends in the meantime...
If in the future we made a pair for another Jeep (or used a similar design for when we make rockers for my WJ) we may do something along the lines of bending the ends in. I think it would look pretty tough. We would just have to get our hands on a pipe bender.
WJRhoAds is offline
post #12 of 20 Old 02-21-2012, 11:00 AM Thread Starter
WJRhoAds
Material cost us very little as most of the stuff was found around the house. Bolts and paint are really the only thing we bought.
WJRhoAds is offline
post #13 of 20 Old 02-21-2012, 11:07 AM
vadslram
PIPE BENDER!?
you doan need no stinking bender. Heat and beat.
Done right you only lose a little wall thickness and a little bit of impact resistance but unless it is your race cage or it's transporting nuke coolant I don't think it will be terminal.
vadslram is offline
post #14 of 20 Old 02-21-2012, 11:07 AM
Cassafrass
Nice. Came out pretty good. They look better than the rockers we made for my YJ.
Cassafrass is offline
post #15 of 20 Old 02-21-2012, 11:36 AM
Deezz22
very nice sir!!!
I'd rock them rockers for sure!!!
1990 Jeep Wrangler YJ 4" Leaf spring lift; 33" Cooper Discover; Dick Cepek DC IIs; "modified" stock bumper
2012 Wrangler JK Gecko Green 3.25" Rustys Lift, 35" Mickey Thompson MTZ, 20" Fuel Octane Wheels, Stubby Bumper caps
Deezz22 is offline
custom , rock sliders , rockers , side body armor , side step
homemade aluminum rockers pics mikesbeachhut TJ Wrangler Technical Forum 3 07-26-2009 08:32 PM
Someone with A to Z rockers help me out! creepycrawly TJ Wrangler Technical Forum 5 04-07-2008 08:10 PM
Homemade: Light bar, Rockers, Roof Rack tmwoodall TJ Wrangler Technical Forum 12 01-12-2007 04:35 PM
New Rockers from PSC..... Difranco TJ Wrangler Technical Forum 205 01-15-2006 10:03 AM
My new Rockers Cheyenne TJ Wrangler Technical Forum 5 12-20-2003 05:44 AM
