Homemade Posi Lock + Aussie Locker front = Selectable locker??? - JeepForum.com
post #1 of 21 Old 11-11-2008, 03:22 PM Thread Starter
Toms87
1987 YJ Wrangler
My vacuum lines were totally missing when I bought the jeep so I pretty much have to do this homemade posi lock mod
http://www.jeepforum.com/forum/f12/home-made-posi-lock-write-up-595515/
I've also got an aussie locker going up front. Since the posi lock only locks the passenger side axle, but technically (since i have the aussie) the whole front is locked, would i be able to:
A) Put into 4wd, pull lock cable, have locked front
AND
B) Put into 4wd, NOT pull lock cable, and have my setup behave like it's open?? (the passenger side axle would be disconnected)
This question has been killing me all day. I don't know much about this axle setup so any help is great!!!
Toms87 is offline
post #2 of 21 Old 11-11-2008, 03:31 PM
tippmann243
the drivers wheel is going to be spinning all the time.
since there is a locker up front its going to spin the DS axle and the PS INNER shaft. pull the posi lock and this will lock the intter to the outer giving you 4wd.
but remember when in 2wd the left wheel will still spin the axle and carrier and the front drive shaft.
89 blazer, L31/t56 28mpg.
blazer video,
1990 jeep, 4.2, 5speed.
tippmann243 is offline
post #3 of 21 Old 11-11-2008, 03:33 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
If I understand what your asking, I would think that option "B" would cause your front driveshaft to spin while (like TJ'S do) it while it would still "feel" like 2wd, I think.
Having a YJ front shaft spinning while driving on the street may cause some slight vibration, if the shaft isn't balanced.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 21 Old 11-11-2008, 03:35 PM Thread Starter
Toms87
1987 YJ Wrangler
I know it's all going to SPIN in 2wd, i'm not worried about that, unless for some strange reason it'd be locked in 4wd for all of eternity...
Anyway, I know about the inner and outer shaft stuff, i'm just wondering specifically about the question i asked.
Toms87 is offline
post #5 of 21 Old 11-11-2008, 03:37 PM
sprowley
Aussie lockers don't lock unless there's power being inputted into the differential. When you're in 2wd, it will act as if it is open. Aussies allow one wheel to spin faster than the other, but allow neither to spin slower than the drive input. When there is no input, there's no speed to keep up with.
92 YJ Islander Sold!
97 TJ Sport black on black with MT/R Kevlars and lots of new parts coming!
Canon EOS-1D Mark III, Canon EF 70-200mm f/2.8L USM, Canon EF 17-35/2.8L USM, Sigma 50mm f/2.8 EX USM
sprowley is offline
post #6 of 21 Old 11-11-2008, 03:40 PM Thread Starter
Toms87
1987 YJ Wrangler
Ok , i think i know what you're saying. Normally, the passenger side is the "drive" axle when in 4wd. Since i'll have a locker, it'll also be connecting to the driver side causing the drive shaft to spin, when ordinarily (stock) it wouldn't.
Couple questions about that if i have it correct...
Would this affect my steering in 2wd on road?
How hard is it to balance a drive shaft? (ie at a shop?)
What do you mean "feel" like 2wd? With a locked front and a disconnected axle, i would think that the driver side axle would be powered as well has the passenger side inner shaft. There would just be no power to the passenger side wheel. So essentially behaving like open.
And sprowley, I've already got front and rear aussies on my explorer so i know how they work, that's why i thought of this possibility.
Toms87 is offline
post #7 of 21 Old 11-11-2008, 03:40 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Your "question" is a bit unclear. If what you mean by "behave as if it were an open diff" concerns applying power to the ground via the front axle in scenario "B", I wouldn't think that it would.
I'm not sure what you're after.
Mean Max is offline
post #8 of 21 Old 11-11-2008, 03:42 PM Thread Starter
Toms87
1987 YJ Wrangler
Give me a minute to make a microsoft paint diagram of it.
Toms87 is offline
post #9 of 21 Old 11-11-2008, 03:50 PM Thread Starter
Toms87
1987 YJ Wrangler
is there something i'm missing??
Toms87 is offline
post #10 of 21 Old 11-11-2008, 04:06 PM
bigsquat
in scenario b when you gas it you better hold on to the steering wheel real good. i have this set up and its definitely not like an open diff. the drivers side will pull the jeep on way or the other ,so hold on.
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #11 of 21 Old 11-11-2008, 04:13 PM Thread Starter
Toms87
1987 YJ Wrangler
You are talking about only in 4wd right? And I just realized that the drivers rear wheel is the drive wheel, so I see what you mean, having one side of the vehicle spinning and the other side not powered.
And I should probably make myself more clear...The advantage I'm looking to gain is turning radius and possible snow handling. I've driven with a locked front in the snow and it's not the best.
Toms87 is offline
post #12 of 21 Old 11-11-2008, 04:20 PM
bigsquat
thats right.like in the diagram . I havent tried mine in the snow yet but im sure when in 4wd ill have wished for an air locker. Im sure it will push pretty bad, maybe with it not posi loced it might give you better turning ( 3 wheel drive)
bigsquat is offline
post #13 of 21 Old 11-11-2008, 04:23 PM
bigsquat
I just got back from the sand dunes and the rear aussie in 2 high would put me into a slid pretty easy, i can only wait for an off camber icey road!
bigsquat is offline
post #14 of 21 Old 11-11-2008, 04:24 PM
bigsquat
I wish the made a posi lock for the rear to0
bigsquat is offline
post #15 of 21 Old 11-11-2008, 04:24 PM Thread Starter
Toms87
1987 YJ Wrangler
With the posilock off, it'll be 2 wheel drive, both driver side wheels. I don't know how well that will work. And the rear doesn't have a posi lock option because there's no vacuum system there.
Well...it sounded cool at first. I'm definitely open for more discussion and suggestions though.
Toms87 is offline
leave the 8.8 open until i get a selectable locker or go ahead with an aussie or lock jeepin01tj TJ Wrangler Technical Forum 11 10-28-2009 06:30 PM
selectable vs. aussie locker up front?? Xaos88 TJ Wrangler Technical Forum 11 06-22-2009 08:29 AM
Aussie locker or Lock right? Plus other locker ?'s creepycrawly TJ Wrangler Technical Forum 22 08-13-2007 03:17 PM
True trac locker in rear and posi lock in front - Gear oil additive? olyjeep YJ Wrangler Technical Forum 5 03-15-2007 12:36 PM
Have a ? for those with a posi lok and an Aussie or any other locker deadlyjester YJ Wrangler Technical Forum 8 01-23-2005 03:05 PM
