homemade lift shackles/steering issues? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > homemade lift shackles/steering issues?
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Poly Door Hinge BushingsStainless Steel Door Hinge Pins
Unread 02-07-2007, 03:44 PM   #1
kevin_saun
Im thinking about making my own lift shackles, just looking at a 1inch lift, I know that to get 1inch u need to go 2inches longer on the shackle, but as for the cross peice , does it only offset in the back and is it to the top or bottom? my second question is in going with a 1in lift shackle , will i notice it in my steering or my rear drive shaft angles? Any ideas on how long to make the cross peice, to get the proper width for the bushings? I have a rough idea but just looking for some opinions, any help greatly apreciated in advance.
kevin_saun is offline   Reply With Quote
Unread 02-07-2007, 04:13 PM   #2
jeepnguns
For the set I made I used a steel bushing spacer from a old set of springs. Just make sure it clears the spring on the bottom and hanger on the top. you have about a 50/50 chance of it affecting your steering.
88 Wrangler
350 Chevy engine vortec heads Holley Pro-Jection
Ford T-18 Tranny
Dana 44s Detroits w/ 5.89s
38" Swamper SX
Lots of other random things and dents
jeepnguns is offline   Reply With Quote
Unread 02-07-2007, 04:59 PM   #3
RockWoRM
don't fear the Jeeper
RockWoRM's Avatar
Crosspiece? who needs a crosspiece?
If ya want something simple... I just used 2"x1/2" straight flat stock. No need for cross pin... very beefy. Doubtful you'll ever bend 1/2" thick shackles. Been beating the crap out of 'em for years.
Unless your looking for a boom style, what I did works fine.
WoRM
'92 YJ, 4.0, 5sp, 8.8 w/ 4.56's locked F&R, Teralow 4-1, HD SYE, BDS 5" SUA lifted on 35 MTR's. PSE front trail cage kit, 1ton TRE flip, 1"shackles, 1"BL, 1" MM. <><
RockWoRM is offline   Reply With Quote
