#91 | |
i'm making a snorkel like the orignal one! it looks crazyyy good! i've been looking for a really nice one, and hell, i ofund it! thanks dudeee!
Nj Surfer; 83 CJ7 Scrambler; 00 2 door XJ (Stock for now) DD; 93 YJ (had 4 inch lift and 33's now its gone); 94 XJ (stock-gone); 89 XJ (stok-gone) |
#92 | |
/l , [____], l---L--[]lllllll[]-_ ()_) ()_)==@=)_) |
#93 |
i like k&n for years and years,but the stock air filter flows real good when its getting more air than it needs also..i will try a k&n sometime this year for the heck of it..i drug my snorkel thru so much crap and trees yesterday that its all scratched up and looking abused,haha...
even if you got some mist of water in the snorkel it would just give it more grunt in my opinion..long as its hitting the filter first to break down the molocules... there used to be water injection back in the day... |
#94 |
Just to let everyone know I have pulled mine apart twice after driving in the rain and due to the ARB top design I have found no water at all in the system. Also the way the flex tubing is placed the water would collect there first. Then if you collected that much water to actually bypass that area you would have to fill the volume of the airbox to the level of the exit tube to the TB. I'm guessing but I think you would have to take in about 4 gallons of water, not going to happen...
-------------------------------------------------- Firefighters Jeep Club http://groups.jeepforum.com/Firefighters_Jeep_Club |
#95 | |
i agree..as with my homemade one,id have to take in a few gallons for it to reach my filter, as water seeks its own level.. |
#96 |
I finally got mine done to the point that it is functional(I still need to pull it back off and paint it).
I've only driven in the rain one time, but there was verry minimal water that made it to the air box(probably only a few drops worth of moisture). and as already mentioned, I think you'd have to almost fill the air box to cause a problem. another advantage that I noticed was how clean the filter is staying. I was on some really dusty trails this weekned, that would normally left me with a verry dirty filter, and when I got back home, the filter was still spotless. ![]() ![]()
maroon 1987 Grand Wagoneer. stock for now... Last edited by muddy93; 08-10-2009 at 10:45 AM.. |
#97 |
nothing wrong with that muddy...the top turned out nice,kinda looks more like the arb top..very cool..will look great when it gets some paint,john
#98 |
making that top was a little tricky, it's all one piece of sheet metal. I cut it out, bent it into shape, and then only had two seams to weld. here's a pic of the cardboard template I made, and another pic looking down on the top(notice that I changed the origional design a bit). oh, and the aluminum screen is just temporary untill I can pick up some expanded steel and weld it in.
maroon 1987 Grand Wagoneer. stock for now... |
#99 |
lost in the woods
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 . For those who have not figured this out I'm old school but can handle the new too. |
#100 |
Muddy I like the top just keep an eye out for water though(rain). I think the reason mine stays dry is the arb top, because it sheds the water to the outside of the pipe.
#101 |
If rain which runs down the snorkle drains through the airbox below the intake... What's the point of the snorkle? If water can drain out the air box can't it get IN as well in deep water?
#102 | |
have you ever seen the bottom side of an ATV air box? they have a little one way valve(some are a diaphram/flapper type, others resemble the cowl vent drain tube on YJ's), that will allow water to drain out, but will not let it come in. I'm still looking for one, but I plan to put one in the bottom of my air box to let rain water drain out.
#103 |
hey i really like what you did with the snorkel but was wondering how you hooked it up to the carb. i have 1988 yj jeep wrangler 4.2 engine some pics would help thanks
nick |
#104 | |
it's not much to look at... but it's mine. http://www.jeepforum.com/forum/f22/military-94-yj-now-more-tons-hummer-junk-990191/ |
#105 |
i like the arb top. the only downside to it is paying for the name
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
