Quantcast Homemade Jeep Snorkel w/pics - Page 4 - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Homemade Jeep Snorkel w/pics
Old 06-11-2009, 01:04 PM   #46
jdarg
Dude that is the BEST looking do-it-yourself snorkel I've ever seen - NICE JOB!
'94 YJ - 34x10.5 Super Swaper LTB "pizza cutters", 2.5L/AX5/231, D30/8.8 4.88, 63mm throttle body and manifold, electric fan, Dynomax exhaust, SYE/CV, SOA on stock springs, MORE traction bar, Teraflex tummy tuck, Milemarker 9500 hydraulic winch, various skids
'06 LJ Rubicon - 31" Trxus, OME 2.5", belly up, various skids
'75 CJ5 basketcase
brewcitycrawlers.com
jdarg is offline   Reply With Quote
Old 06-11-2009, 01:07 PM   #47
jdarg
Originally Posted by bigredcherokee View Post
No b/c he will hook it below the air filter on the stock air box. what accumulates will drain out the box.
A snorkel with drain holes in the air box is completely useless if you think about it.
There's no way enough rain will get in there to hurt anything, whether its running down the road or parked. I've been running one for years and never had a problem. And I agree with the guy above who said it looks better than an ARB.
So have ya tested it out in a deep hole yet?
'75 CJ5 basketcase
Old 06-11-2009, 01:21 PM   #48
yamaguy01
Ditto for best looking homemade snorkel!
That is very professional looking work there. I've been wanting a snorkel for my YJ also but for one, the ARB one is WAY overpriced. Two, the 3" pipe would be too restricting for my engine since my MAF is about 5" and I'm running a short 4" tube to the filter. I don't want to choke the engine anymore than that. I'd love to build one of these but the ARB top diameter would be too small I think. Maybe I should do a dual intake set-up Too bad no one makes a snorkel for a V8 swapped Jeep since it is a common thing to do.
Dave
NRA Life member
Square Headlights group member #222
Armed Forces Jeeps group member #65
United States Air Force group member #12
Guns and Jeeps group member #10
Ron Paul Jeepers group member #7
yamaguy01 is offline   Reply With Quote
Old 06-11-2009, 01:26 PM   #49
Allen52105
Are you worried about denting the exaust tube if you rub/hit a tree or something? I would imagine the arb plastic would bend back....but am not sure about that. yours looks clean though. I like the hood inlet
jason
Allen52105 is offline   Reply With Quote
Old 06-11-2009, 01:36 PM   #50
fyrdriver
Firefighters Jeep Club
http://groups.jeepforum.com/Firefighters_Jeep_Club
fyrdriver is offline   Reply With Quote
Old 06-11-2009, 01:41 PM   #51
fyrdriver
Dave
ARB has a 3 and a 3.5" top. Any 4 or 6 cyl will be fine with a 3" intake, even mild V8's, but I figured if I ever get around to a V8 I could run one on the other side to match.
Old 06-11-2009, 01:44 PM   #52
fyrdriver
You would be suprised how heavy the tubing is. Honestly I think if I hit something that hard it would shear the bolts holding it off first or bend the brackets. Where I ride thats not a problem either.
Old 06-12-2009, 09:28 PM   #53
hevybluzer
Throw a patent on it and start making them! From the response you could probably sell alot of them.............
hevybluzer is offline   Reply With Quote
Old 06-13-2009, 11:47 AM   #54
johnrezz
Great Job..... I have not been a big fan of snorkels but I really like the looks of this one....
Its always more fun to build your own.....
1989 YJ 258CI 4.2L with 4.0-HO(7120)5 angle head job, Comp-Cam 4x4 xtreme cam, Holley 4412 500CFM Carb, Clifford performance single Plenum intake, CRT HEI distributor, Rough country 4" lift, 33.5 tires, Ultra Polished Aluminium Rims, Warn Powerplant, Galaxy DX-979 w/ a little help-x-250, custom tire swingout rear bumper, quick disconnects, Posi-Loc, new paint.
My build thread: http://www.jeepforum.com/forum/f12/jeep-build-take-two-642379/
johnrezz is offline   Reply With Quote
Old 06-14-2009, 02:56 PM   #55
fyrdriver
OK, heres the update for those who were waiting to see the underhood connection.
Went to pepboys and got this 3" flexible intake tube (Spectre #8741), had a 90 degree gradual bend 2 inch ID PVC elbow. Cleaned up the edge on the elbow and siliconed it. It just barely fits into the stock airbox. The flex hose has a molded in 3" coupling and slips over the metal exhaust pipe perfectly. The other end I used silicone and a hose clamp to hold the end over the outside of the elbow.
I was going to run a hard line to the box, but it really needs a flexible connection for vibration. The airbox is designed to move so thats why I went this way.
Lastly, I plan on leaving the end at the exhaust pipe disconnected (because its very accessible)for normal driving and when I do plan to offroad it just hook it up.
Hopefully this helps!
Old 06-14-2009, 09:51 PM   #56
offroadterra
Junior Member
That is just sweet! Looks like it was a factory option.. Great job!
offroadterra is offline   Reply With Quote
Old 06-14-2009, 11:13 PM   #57
YJake
YJake's Avatar
Excellent write-up and pictures man, thanks a bunch!
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline   Reply With Quote
Old 06-15-2009, 01:32 AM   #58
tato1111
How would you go about hooking up a snorkle if you had a carbed engine? I dont even have an air box.
And wont your distributer get wet and kill the engine before you could get vary deep?
tato1111 is offline   Reply With Quote
Old 06-15-2009, 01:59 AM   #59
YJake
YJake's Avatar
Personally I routed a hose from the breather of mine to the top of the firewall and put electro-grease on all of the plugs/connectors and regular lube grease on the base of each plug to slow the water down.
/l , [____],
()_) ()_)==@=)_)
Old 06-15-2009, 03:21 AM   #60
Fogrunner
That's a great job and write-up!! Very clean and professional looking.
'92 YJ 4 Cylinder, AX5, SOA w 39.5 x 13.5 x 16 Super Swamper IROK Radials's, D44/8.8 Moser Shafts, Homemade front and rear bumper, flat fenders and rock sliders.Lotsa $#@% Rust!!
Fogrunner is offline   Reply With Quote
Glock Forum
