Quantcast Homemade Jeep Snorkel w/pics - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Homemade Jeep Snorkel w/pics
Old 06-10-2009, 07:36 AM   #31
fyrdriver
OK I'll try to answer all the above questions.
Snorkel top here, $77.50
http://www.torasport.com/store/product.php?productid=558&cat=0&page=2
Not sure on the TJ but I don't know why the hood style wouldn't work. I did like the JK hood style and like I stated before my hood was toast anyways so it seemed logical. I had to use the drivers side because my antenna would have interfered. In following the body lines, removing it would have left a hole.
I will post a pic of the windsheild bracket tomm.(on duty today).
As far as the pipe goes, I did not pick stainless because of welding concerns. But the pipe I used is aluminized steel. I have an aluminized flowmaster exhaust on my 69 Camaro that shows not a speck of rust after about 8 years. I also painted the inside as far as the sprayer would go and the outside is the same krylon I used on my homemade bumpers. It seems to hold up pretty well. I'm sure the rest of the Jeep will fall apart before this does.
Lastly someone asked about water inside. The good thing about the ARB top is the design allows the water to drain out the top not run down the snorkel. The pipe extends up into the top so when water gets in it runs to the outside of the pipe and out little drain holes in the plastic.
Firefighters Jeep Club
http://groups.jeepforum.com/Firefighters_Jeep_Club
fyrdriver is offline   Reply With Quote
Old 06-10-2009, 07:41 AM   #32
fyrdriver
Summit racing U bend
http://www.summitracing.com/parts/SUM-622005/
Straight pipe
http://www.summitracing.com/parts/SUM-640030/
Looks like they are both 16 gauge.
Old 06-10-2009, 08:24 AM   #33
Edstu234
Do you have a way to quick disconnect it when you need to open the hood ?
Edstu234 is offline   Reply With Quote
Old 06-10-2009, 09:33 AM   #34
91rebel
looks great fyrdriver. looks professionally done even though its homemade. even the hood looks pro. great job man
91 yj, 4.0, sound-bar, custom axe/shovel setup, hardtop, 15x7 steelies
91rebel is offline   Reply With Quote
Old 06-10-2009, 12:15 PM   #35
timatoe
Jello Puddin'
timatoe's Avatar
I think you need to look at the pics again. The hood is notched and closes over the tube, the tube doesn't run through the hood.
Originally Posted by fyrdriver View Post
timatoe is online now   Reply With Quote
Old 06-10-2009, 01:49 PM   #36
YeepieJeepie
Looks great! Nice job.
All I have left to do is connect it to my stock airbox with some dryer vent tube from Home Depot and some additional waterproofing under the hood.
Can you relocate the air box to the drivers side and run the pipe straight into it?
I'd do smooth wall tubing throughout. That dryer vent stuff probably isn't going to flow too well because of the corrugation. You'll pick up a few HP due to the cool air effect, you might as well make it flow good too.
YeepieJeepie is offline   Reply With Quote
Old 06-10-2009, 05:41 PM   #37
fyrdriver
Good idea, tommorrow I'm going to home depot to see what type of tubing I can get. Obviously I'm limited to something that uses a 3"ID because my snorkel pipe is 3"OD. With whatever I go with, the good news is where the 90 is that goes into the hood its not even a foot away, if I use the drivers side of the airbox and plug the stock inlet. I doubt it will matter to my 4 banger. lol
Old 06-10-2009, 06:16 PM   #38
jreed80
Junior Member
best homemade one ive seen too. To the question about the catching water you can turn it around it will still suck in the air just no bugs or water being forced in.
jreed80 is offline   Reply With Quote
Old 06-10-2009, 10:23 PM   #39
YeepieJeepie
Not necessarily. I did a CAI on a car that used PVC pipe. I was able to joint two pieces with a 3" OD by using a rubber join that had a 3" ID.
Came out pretty nice actually. I was able to scuff it good with 600 grit, prime and paint with Krylon and the finish looked good for years.
Old 06-11-2009, 12:37 AM   #40
YJake
YJake's Avatar
I'm sitting here geting ready to hit the "confirm order" button on the websites to order the supplies for this mod but need the rest of the pictures so I can make sure I do it right.
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline   Reply With Quote
Old 06-11-2009, 07:31 AM   #41
pkjeepyj
that looks awesome keep up the good work.
pkjeepyj is offline   Reply With Quote
Old 06-11-2009, 08:26 AM   #42
fyrdriver
OK, OK, keep your pants on! JK
Heres the bracket to windshield. Simply a piece of flat stock cut to the shape of the factory hinge then drilled. I would use longer screws though the factory ones were a little short to really crank down on. I had these stainless ones left over from some old mirror relocation kit I pulled off.
Heres one of the turn in, there is an L bracket on the backside to the inner fenderwell.
Also you can see here where I had to notch the top lip of the fender.(not really visible when the hood is closed) And the pics are deceiving the snorkel does not touch the body in any place but the two mounts, although its only about 1/8 inch away, so there is no worry about vibration or noise.
As far as the underhood goes I heading over to home depot to see what they have but this is what I found so far. The stock inlet will fit a 2" pvc pipe EXACTLY. I got this gradual bent one. I know some people will say this is a restriction but remember how small the restricters were in your airbox. Mine seemed about an inch maybe an inch and a half. If I can plumb it using 3" all the way I might just go that route...
Stay tuned.
Old 06-11-2009, 11:43 AM   #43
cosmo_j
i know what im doing this summer!!thats friggen awesome!
cosmo_j is offline   Reply With Quote
Old 06-11-2009, 11:58 AM   #44
halfleft
wow man nice job, my snorkel is a home depot job but dont look nearly as good, i looked around home depot and all i could find to hook to the air box was the 3 in dryer vent stuff works good tho cause its so flexible,
heres a pic of mine
halfleft is offline   Reply With Quote
Old 06-11-2009, 12:09 PM   #45
Tom95YJ
It's Only Rock Rash......
Tom95YJ's Avatar
I accually like that better than my ARB
'98 TJ Built Sold
'95 YJ Built Sold
'99 XJ 3" on 31's Build Thread
Utah Jeep Crew Member #109
Tom95YJ is offline   Reply With Quote
Glock Forum
