Homemade High Steer Knuckle - Page 3 - JeepForum.com
post #31 of 37 Old 02-21-2011, 11:15 AM
giggityjeeper
Originally Posted by plaidfro View Post
I asked my father in law his opinion about it last night. He's not a jeeper at all but is very mechanically inclined. He said "I think you could just bend your draglink into an S curve to get it to clear your leaf"...
I will keep reviewing my options
http://www.powerblocktv.com/video/?ep_show=XT
watch this vid, a good explanation of WHY NOT to do this is around the 13:20 mark....
they are doing a SAS on a full size blazer with a SOA application
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #32 of 37 Old 02-21-2011, 12:17 PM
jayhhaynes
heres mine...
jayhhaynes is offline
post #33 of 37 Old 09-27-2011, 11:32 PM
coneal30
Originally Posted by Jeepsr4me View Post
http://128.83.80.200/taco/scarysteering.html
Never a better time to post the silliness of how people can "improve" their steering all on their on. below is just a tiny example from the link above. I wish the guy would add more to his site ....
wow.. really?
coneal30 is offline
post #34 of 37 Old 09-28-2011, 03:35 AM
oldtime_ironman
Originally Posted by MoparFreak69 View Post
This statement couldnt be more WRONG. Cast STEEL is very easily welded and will provide a very safe weld when welded with sufficent heat. You are thinking of cast IRON which is very brittle and cannot be welded easily and if done improperly will be quite unsafe. I wouldn't hesitate to cut and weld on a cast steel part, I am however an experienced welder and I know what it takes to get a properly penetrated weld with the strength required for the stresses the part will be placed under. Ask any old time farmer the difference. They will know the whats and hows.
^^^^ x2 on this.
BTW it really bugs me how people can't tell the difference between forged and cast parts. There are so many myths out there about fabrication. Its easy to tell - just by looking at the part. Mine are forged on my D30 - I just went and checked. Look close at the "parting line". This is where the 2 halves of the mold came together on a cast part, on a forged part its where the 2 halves of the forging dies came together. I fine thin line is cast. A wider line (say about 1/4") is forged. Usually a forged part also shows grinding marks where they cleaned off the extra flashing. You also have to use some freakin common sense here, people! Highly stressed parts such as steering and engine connecting rods are almost *always* forged, for strength.
I wouldn't weld a knuckle that is going to be driven on the road unless I did it very carefully. And like MoparFreak69 says, I actually *do* have 20 yrs experience plus trade school and certification. IMHO the knuckle would have to be annealed and heat-treated afterwards, and then completely re-machined. This will lessen the chances of cracking due to different properties of wrought vs cast and having to deal with the grain of the steel enlarging. This requires a industrial controlled oven and machine shop, etc... prolly at about 1100 F for a few hours. I actually could do this at work but certainly not at home. Definitely use low-hydrogen or MIG or TIG and be generous on the heat and bevel the edges.
oldtime_ironman is offline
post #35 of 37 Old 09-28-2011, 08:24 AM
SirChiefton
Get the JB bracket. I just did this to mine. Take your time drilling the holes and tapping them. It took me about 4 hours, mainly because I rushed and snapped a 3/8" bit. The bracket works perfectly, my steering is way better. I'm SOA with stock springs.
Watch out about the dropped pitman arm though. I bet if it is long a drop it will make your bar hit the leaf spring. Mine has about a 1/2" clearance. I think I remember reading somewhere on her about this issue someone had.
SirChiefton is offline
post #36 of 37 Old 10-03-2011, 02:17 AM
lionrenegade
I do not have soa. my lift kit is 4.5'' rubicon express E.D. and I use the sistem from http://www.goferitoffroad.com/ and is very good
lionrenegade is offline
post #37 of 37 Old 10-03-2011, 10:53 AM
timatoe
timatoe's Avatar
Won't work SOA, the Tie Rods will hit the springs.
timatoe is offline
WJ knuckle conversion/ High Steer teqmod YJ Wrangler Technical Forum 14 03-26-2014 09:11 AM
high steer deryk111 TJ Wrangler Technical Forum 5 02-16-2009 10:00 PM
Best way to remove high steer arm out of knuckle Fastbeeatch YJ Wrangler Technical Forum 1 07-29-2008 09:42 PM
High Steer Shrek TJ Wrangler Technical Forum 20 06-20-2007 10:59 AM
doing a SOA....what High steer kit? Jakesteads YJ Wrangler Technical Forum 14 09-12-2006 01:10 PM
