Homemade High Steer Knuckle - JeepForum.com
post #1 of 37 Old 10-31-2008, 02:45 PM Thread Starter
_JEEP_
Hello guys. Ive got a good question. Is there a way to make a high steer knucle for an soa converison. My freind is giving me 2 dana 30 knuckles so now i have 4 dana 30 knucles and now i want to know is there any way to make a high steer knucle. Like cut the arm off and raise it then weld it back on?? Any ideas. Or should i just drop the whole idea?
Also what is the year the cherokee had the high steer knuckle on it? and is that knuckle bolt on for dana 30?
Thanks
_JEEP_ is offline
post #2 of 37 Old 10-31-2008, 03:17 PM
timatoe
timatoe's Avatar
I think the JB4X4 bracket would be a better option, and probably cheaper in the long run.
timatoe is offline
post #3 of 37 Old 10-31-2008, 03:43 PM
Tomb Raider
Addicted...
Tomb Raider's Avatar
I think if you decide to cut/weld cast knuckles.....you will regret it.
Tomb Raider is offline
post #4 of 37 Old 10-31-2008, 04:17 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Damn, between this post, and the other one where I said I use Fram oil filters, I am really out to get flamed big time! But, here goes.
I have these Rocky Road high steer adapters on my wife's '93 YJ. The are INCREDIBLY beefy, and actually a well thought out & well made part, IMHO.
They are (also IMHO) better than the JB4X4 setup, as it moves ALL of your steeing linkage up above the leafs on an SOA conversion. It's not cheap, but it's very heavy duty, and has 1-ton TRE's.
http://www.rocky-road.com/yjott.html
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #5 of 37 Old 10-31-2008, 04:25 PM
giixxer21
I used rocky mountain and it's great. never a problem.
[URL=http://imageshack.us][/URL
90' YJ 4.2L ,SOA 36' iroks, W/full cage
93' XJ stock
giixxer21 is offline
post #6 of 37 Old 10-31-2008, 05:11 PM
muddy93
1987 FSJ Wagoneer
I don't remember the year, but suposedly there is a cherokee/grand cherokee knuckle that you can swap, that has a raised arm on the passanger side knuckle. granted, it would only move the drag link up, but it might be an option for you.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #7 of 37 Old 10-31-2008, 05:39 PM
Jeepfreak81
Jeepfreak81's Avatar
Welded steering parts are not only unsafe, but illegal as well. Welding cast for steering is extremely unsafe.
If you want high steer on a D30, you need to buy a new knuckle, or use the bracket.
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
post #8 of 37 Old 10-31-2008, 06:56 PM
ghost183
the steering knuckle is cast steel.. if you weld it, it WILL snap under stress, so dont weld it
JB has the cheapest setup ive seen $150, cant go wrong
http://www.jb4x4.com/products.htm
youll notice its NOT welded onto the knuckle.. you drill and tap the knuckle an use bolts.. very stout setup
Important Notice:... DUE TO RECENT BUDGET CUTS, STOCK MARKET PERFORMANCE, RISING COST OF ELECTRICITY, GAS AND OIL... THE LIGHT AT THE END OF THE TUNNEL HAS BEEN TURNED OFF.... WE APOLOGIZE FOR THE INCONVENIENCE............ Regards:... THE GOVERNMENT
ghost183 is offline
post #9 of 37 Old 10-31-2008, 07:22 PM Thread Starter
_JEEP_
alright i wont weld! it was only a thought... but i like the idea ok the jb brakcet. I want to move the draglink over the suspension and not the tie rod. And I would love to have that year the cherokee had the high steer setup on it, Maybe somebody will chime in and help me out.
_JEEP_ is offline
post #10 of 37 Old 10-31-2008, 09:32 PM
bigsquat
i found a set of a grand cherokee for you for $50 bucks plus finders fee. http://fredericton.kijiji.ca/c-cars-...QAdIdZ74127248
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #11 of 37 Old 11-01-2008, 05:49 PM Thread Starter
_JEEP_
I wouldd love to buy those. But I am all that way up north in Quebec. Do you know the yAer of the Cherokee?
_JEEP_ is offline
post #12 of 37 Old 11-01-2008, 08:03 PM
TSEJEEPERS
I believe they were on the Grand Cherokees. Pretty much the same as the Tera Flex knuckle. Less $$$
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #13 of 37 Old 11-23-2010, 03:38 PM
rokkshocka
I'm bummed nobody was able to answer the GC high steer question. I've got a GC high steer knuckle sitting in my garage right now waiting for me to figure out which tie rod and drag link I need to use on it. Obviously the stock tie rod and drag link are too short, and if I knew the year of the GC that had this knuckle I could look at replacement parts under that year model. I'd rather not use the teraflex unit as I'd prefer steel that far forward and south...
Not Smart enough to keep them, not smart enough to stop buying more
rokkshocka is offline
post #14 of 37 Old 11-23-2010, 04:01 PM
timatoe
timatoe's Avatar
Use stock TRE's and have a new tie rod and draglink made up.
timatoe is offline
post #15 of 37 Old 11-23-2010, 04:06 PM
giggityjeeper
jumpins man Quebec is only a few hours from Fredericton, grew up in that area.......
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
WJ knuckle conversion/ High Steer teqmod YJ Wrangler Technical Forum 14 03-26-2014 09:11 AM
high steer deryk111 TJ Wrangler Technical Forum 5 02-16-2009 10:00 PM
Best way to remove high steer arm out of knuckle Fastbeeatch YJ Wrangler Technical Forum 1 07-29-2008 09:42 PM
High Steer Shrek TJ Wrangler Technical Forum 20 06-20-2007 10:59 AM
doing a SOA....what High steer kit? Jakesteads YJ Wrangler Technical Forum 14 09-12-2006 01:10 PM
