Quantcast Home made POSI LOCK write up - Page 9 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Home made POSI LOCK write up
Old 02-19-2009, 04:50 PM   #121
choeyreplied
Awesome write up. Will this work with TJs?
choeyreplied is offline   Reply With Quote
Old 02-19-2009, 05:12 PM   #122
plaidfro
Huh? Ummm, am I wrong or do TJ's not have a shift motor housing and the split axles? So there is no need for a Posi-lok in a TJ, right?
plaidfro is offline   Reply With Quote
Old 02-19-2009, 06:17 PM   #123
warbuk
hellfire
warbuk's Avatar
this thread has been very helpful. thanks to everyone that provided the much needed info.
i'm new here but not new to forums. hope you guy's don't mind me joining.
on my 2nd xj cherokee. the vacuum front axle is what led me here. seems to be some nice helpful folks around these parts.
thanks again guy's.
Calvin
warbuk is offline   Reply With Quote
Old 02-19-2009, 08:22 PM   #124
bigsquat
FORMELY BIGPIMPIN
bigsquat's Avatar
this thread helped me do mine to. and as people do theirs they post up variations that can make it better as it evolves. welcome to the forum, you will find the yj guy's are the smartest.
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD: http://www.jeepforum.com/forum/showthread.php?t=613943see
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline   Reply With Quote
Old 02-19-2009, 11:37 PM   #125
timatoe
Jello Puddin'
timatoe's Avatar
Originally Posted by bigsquat View Post
...... you will find the yj guy's are the smartest.
Shhh, before you know it we'll have TJ guys in here too.
timatoe is offline   Reply With Quote
Old 02-20-2009, 03:59 PM   #126
MrBuick
1990 XJ Cherokee
I just went to NAPA, and got the cable, and was talking with my grandpa about this. I need to go get the union for it. I just found a tension sping laying around in his basement, and Pulled it apart so now it is a compression spring. Looks to be about the same size.
I thought about the cable, and that when it bends, it spreads open. Which lets water in. And SALT... which we have alot of in this area in the winter. I'm going to run my cable inside a 1/4"-5/16" rubber fuel line, or vacuum line. From the housing, all the way in the cab. We have a bunch of rolls of it in my garage, since you never know when you might need to replace a hose.
Hopefully I get around to it this weekend.
EDIT: Just read thru page 3, and I see somebody else was thinking like me.
~Cory Magner "My name is Cory, and I'm an addict."
95 Maroon Buick Roadmaster.
180k, Headers, Catback, 3.73's, 3000 stall... yea... It's FAST.
90 White Cherokee - Traded a 96 Caprice for it.
140k, Rusted body, Bald tires, & non-working 4wd mods. Summit Turbo Muffler. Aussie D30/D35 & posi-lock, waiting to go on.
MrBuick is offline   Reply With Quote
Old 02-20-2009, 06:58 PM   #127
warbuk
hellfire
warbuk's Avatar
thanks for the welcome!
i got this done today, i mounted the pull switch beside the 4x4 lever thru the floor. i could have used the 5' cable this way lol. i put the cable in a plastic tubing from work (i work in a waste water lab) fit perfect. i cut the bladder housing off and covered the end with a plastic cap (again from work), works great.
the only thing i screwed up on was i put the fork in backwards lol. got that straight and tried it out.
wish i could post pics, done some good mudding today. a guy that was stuck took some great pics, waiting on the email.
i got some pics at the house of the cherokee. thanks guy's
95' ZJ grand cherokee
91' XJ cherokee
http://www.youtube.com/watch?v=Z09x_m-Z_Uk
Old 02-24-2009, 05:36 PM   #128
warbuk
hellfire
warbuk's Avatar
just an update.
the posi-lock works fine but my low range doesn't work. anybody know something, please pm me.
91' XJ cherokee
Old 02-24-2009, 06:40 PM   #129
Dmax5er
Originally Posted by warbuk View Post
just an update.
if you have a body lift make sure the shifter isnt hitting the body. if thats not it, get some one to shift if while you get under and see if it going in all the way, may be a linkage problem..not running of course...
What Day is it?
Firefighters Jeep Club- Administrator
http://groups.jeepforum.com/Firefighters_Jeep_Club
Dmax5er is offline   Reply With Quote
Old 02-24-2009, 08:23 PM   #130
CSCmrwizard
1982 CJ5
hope they dont try this mod
Jeeps dont FLOAT!!!!!!
93 YJ
82 CJ5
CSCmrwizard is offline   Reply With Quote
Old 02-25-2009, 09:18 AM   #131
Blazin Den
White YJ
Blazin Den's Avatar
i posted these links in another thread but they may be helpful to other people looking at this thread. These a links to other posi lock writeups.
http://www.jeepforum.com/forum/f12/home-made-posi-lock-write-up-595515/
http://homepage.mac.com/jlg/posi-lok/
http://www.jeepforum.com/forum/f11/homemade-posi-lok-pics-518530/#post4800595
http://www.4x4wire.com/jeep/projects/comanche/posilok/
http://www.mn-jeep.com/forum/showthread.php?t=4771
http://www.pavementsucks.com/forums/...+own+posi+lock
http://www.gljt.org/modules.php?name...wtopic&t=10033
http://www.bc4x4.com/tech/2002/d30shiftmotor/
www.geocities.com/tonysmudbog/Posi_Lock.doc (word doc but has pics)
http://www.finishlinewest.com/posi_lock.htm
95 White YJ 2.5L/AX-5 Stock on 31s. Ground Pounder Fab (BESRK) Front Bumper, Herculined Interior, Windshield/Front Bumper Mounted Lights, Uniden PRO 520XL Cb,Hidden Hitch Trailer Hitch, Bestop Supertop, Modified CJ7 Hardtop and CJ7 Twist Handle Full Doors (winter)
Blazin Den is offline   Reply With Quote
Old 03-09-2009, 03:45 PM   #132
warbuk
hellfire
warbuk's Avatar
thanks man, i don't have a body lift, but i'll try the linkage out. altho it appeared to be fine when i swapped the engine-tranny over.
i have the transfer case from the 91,(had the vacuum). will it work on the 92' setup i'm running? (no vacuum)
engine and tranny are the same, the transfer cases were different.
or point me in the rite direction, if there are write ups on this.
thanks for the help.
Calvin
91' XJ cherokee
Old 03-09-2009, 08:40 PM   #133
Dmax5er
Thats good you put that up here, it will help someone in the future, i wish i would have had it before i done mine.. If i had it to do over again i would but the kit to do it instead of all the running around looking for parts, made 3 trips back and forth just finding the right spring , spring too heavy - hard to pull...too light and it wont go back...
thanks for the links...
What Day is it?
Old 03-11-2009, 06:07 PM   #134
cbman
Nicely done!
http://www.twospoke.com
"Tech Jeepers" member #2
cbman is offline   Reply With Quote
Old 03-16-2009, 11:25 AM   #135
scbasspro
I am goingto get the parts!!!!!
Question: Do you have to remove the fork to drill the hole for the cable?
scbasspro is offline   Reply With Quote
Glock Forum
