#106 | |
2 c-clips on the inside on the shaft.. make sure you take note of how it comes apart......excuse me 3 clips...
What Day is it? Firefighters Jeep Club- Administrator http://groups.jeepforum.com/Firefighters_Jeep_Club Last edited by Dmax5er; 01-23-2009 at 02:06 PM.. |
#107 |
Pull the 3 C clips off of the shaft
#108 |
I would use Loctite on those cable ends to help prevent the screw from backing out.
Shrink wrap is easily cut or abraded, so perhaps cover it with some fuel hose if you really want it abrasion/cut/oil/water resistant. For waterproof cables go to your friendly local bike shop. You can get throttle cables or even a clutch cable if you want overkill. Motorcycle-grade cables are plenty strong, have ends that won't pull off (some get soldered on) and are waterproof. You can order cables in any length you want and the plain black ones are not expensive. In any case lube that cable once in a while. You could coat the (inner) cable with grease the first time you put it together. Cable lube (in spray cans or oilers) works really well; it is designed to wick itself end-to-end. |
#109 |
wow, took me awhile to find this Locking Push Pull part. Part number search could not find it.
http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=BK&PartNumber=7 311104&Description=Control+Cable+%2f+Push-Pull
~Cory Magner "My name is Cory, and I'm an addict." 95 Maroon Buick Roadmaster. 180k, Headers, Catback, 3.73's, 3000 stall... yea... It's FAST. 90 White Cherokee - Traded a 96 Caprice for it. 140k, Rusted body, Bald tires, & non-working 4wd mods. Summit Turbo Muffler. Aussie D30/D35 & posi-lock, waiting to go on. |
#110 |
I bet thi is what wrong with mine... it seamed like it was slow before it all of the sudden quit going in. the light keeps popping on every now and then while in 4wd.
#111 | |
#112 |
sorry to be a newb but how does this work. what are the pros i can do all of this at my house but i just dont get it.
daily driver srt 4............ 1995 yj in progress |
#113 |
does this mod llet you have both tires spin at the same time or wat exactly does it do? NOOB question i know
.:Frank-You:. 94 YJ 2.5L 97 TJ 2.5L |
#114 | |||
The supposed "benefits" of having a CAD system were to keep the front driveshaft from spinning while driving in 2WD, thereby providing better fuel & reduced wear on some driveline components. The results were negligible at best, so for Wranglers this practice was discontinued with the introduction of the TJ in 1997. The TJ uses a 1 piece right side axle, which this mod mimics. The reason this mod exists is because the vacuum system can be problematic. The vacuum switch on the T-case can fail, the vacuum lines can become brittle & break from age, or they can be snagged by debris & be pulled loose, the diaphragm in the vacuum actuator motor on the front axle tube can fail, the shift fork can bind, bend, break and the lock collar may not fully engage. Any of these problems will cause a loss of drive front the front axle. Performing this mod will eliminate these possible scenarios. However, there's no such thing as a "free lunch" and so there are some considerations. Your front driveshaft will now spin all the time, and the YJ's front driveshafts were not balanced from the factory (TJ's are) because they weren't designed to be spinning all the time. You may, or may not have a vibration issue after doing this mod, but if you do you can get your driveshaft rebalanced at a local driveshaft shop. If you have installed an automatic "lunchbox" style locker in the front, you may experience some clicking (ratcheting) of the locker while turning. I have not performed this mod on either of our YJ's because our vacuum systems have always worked. If I have any problems with either of our vacuum systems, I will consider doing this mod. Hope this helps! ![]()
Click here to see all of my different albums on Photobucket. Choose any album to see all of my pics! Mean Max is setting up his Jeep shop! Picture history of my progress here. Quote:
There is no situation that cannot be improved with a small but well-placed explosive.
#115 |
so this mod makes u maually lock or open the gear. instead of having a vacuum system do it for u. and when people say open lockers that means they are open all the time and it is 4wd all the time???? thanks again^^^^^ u have been awesome help
#116 | ||
This mod just prevents the loss of front axle power due to a faulty CAD component. An "open" differential is the stock setup. It means that the spider gears in the differential will allow power to either side, and when there's no traction on one tire (in mud, tire in the air, etc.) ALL the power goes to that wheel, so you will effectively lose the use of that axle. A "locked" axle means that BOTH tires will spin at the same speed, no matter what. This is accomplished by a manual (selectable) locker, or a "spool" type carrier. In addition to those, an "automatic" locker will allow 1 tire to spin faster if need be, but not slower than the powered wheel. Clear as mud? ![]() ![]()
#117 |
okay i get it. i will just pm u if i have any questions ha ha ah
#118 | ||
#119 | |
#120 | ||
I hope it is completely accurate. If there's any mis-information in it, I would appreciate somebody pointing it out for clarification. ![]() ![]()
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
