#91 | ||
FORMELY BIGPIMPIN
it gets lubed from the diff oil. any oil that you would put in there would drain into the diff and visa versa. just oil it up when you install it. on another note, some people attach the inner cable to the fork with one hole, i used two holes. pushed it thru then back thru the fork. then put the cable clamp on. this was suggested to me by someone here and i followed there advice. with one hole there is a chance of pulling the clamp off.
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD: http://www.jeepforum.com/forum/showthread.php?t=613943see Two fish swim into a concrete wall. One turns to the other and says 'Dam!' |
#92 | |
What Day is it? Firefighters Jeep Club- Administrator http://groups.jeepforum.com/Firefighters_Jeep_Club |
#93 |
Ok guys, I got it all put together and I got the compression union tightened on the cable. It appears to work, but needs some tweaking. When I take it off next time, I am going to do the two hole deal with the wire stop.
I still need to take care of the old vacuum system. Can I take a small piece of vinyl tubing and connect the two little male adapters on the round thing (diaphragm?)? I have a bunch of pictures, I'll host them tomorrow. Thanks for the help so far. ![]() |
#94 | |
Jello Puddin'
I capped mine all off with vacuum caps, about $2 for a package of various sizes. You can sorta see them here...
#95 | |
#96 |
Ole Ironhead
since your not using the vacuum lines anymore..why not eliminate the lines all together and cap it off at the intake manifold? By the way,I'm thinking of this mod,while i was just up in central Pa mountains visiting family playing around in the snow, mine wouldnt lock in due to frozen vacuum lines I'm assuming from having moisture in them or the switch at the transfer case was froze,i had to get a peice of spare vacuum hose to carry with me when it froze up so i could hook it directly from the intake manifold to the front differential to lock it in |
#97 |
FORMELY BIGPIMPIN
if you just plug the lines on the diaphragm housing, and the diaphragm is still intact, then it might hinder the movement of the rod. if your set on leaving that housing there, then just put a single loop of vac um line jumped between the 2 ports. that way the as the diaphragm pushes air in on direction it will equalize and not cause a vac um lock. does that make sense?
if you want to eliminate the incoming lines all together it wouldn't effect the 4x4 light if you have the type that is operated by a limit switch that is on the housing. if you have the type that is controlled by vac um ,then that's a different story,some of the lines will still be used.
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD: http://www.jeepforum.com/forum/showthread.php?t=613943see Two fish swim into a concrete wall. One turns to the other and says 'Dam!' Last edited by bigsquat; 01-16-2009 at 02:52 AM.. |
#98 | ||
#99 |
Ok. I got a piece of 3/16" tubing and stuck it on either ends. It was really hard the first pull, but is fine now. The return spring isn't strong enough to be reliable, though. I bought two at the time (one strong and one soft) so I'm going to install the stronger one.
One more thing...I bought the tubing and went to the gym right after, where I popped the tubing on. I tested it out in the parking lot (it works) and drove home. I took it out of 4WD on the T-case and I un "locked" the fork. It took a couple seconds for the spring to kick in, but eventually came back out of 4WD. On the way home, I noticed a high pitched whine coming from the jeep. It almost sounds like the fork didn't make it all the way home. If I keep it "locked" in 4WD, but keep the t-case in 2HI, both drive shafts will spin, will only the rear axle with spin? FWIW, I gotta go to work, which is about 15 miles, with 5 of them light highway. |
#100 |
is there another name for a compression fitting?
or a way i can explain it when i go to Ace harware tomorrow?
^^^thats a lie. |
#101 | |
http://www.acehardware.com/product/index.jsp?productId=1292677&cp=2568454.2632222.263 2247.2632261&parentPage=family
^^^thats a lie. |
#102 | |
Jello Puddin'
No, take your cable into the local hardware store, go to the plumbing department and ask for a compression fitting. They'll be able to help you out.
#103 |
some call it a union.........
#104 |
thanks. plumbing department helps the most. and i meant to put union, i was looking at all kinds of stuff and put fiting, but i guess either will work.
thanks guys
^^^thats a lie. |
#105 |
how do you get the fork out to drill the hole? im stuck.
^^^thats a lie. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
