Quantcast Home made POSI LOCK write up - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Home made POSI LOCK write up
Old 10-05-2008, 10:21 PM   #61
timatoe
Jello Puddin'
timatoe's Avatar
Originally Posted by bigsquat View Post
As for water proofing, I noticed nobody addressed the cable itself.
I coated about the first 6 to 8 inches of the exterior of the cable with some black RTV, haven't had any leak problems.
One could also brush on some Plasti-Dip, that would probably work pretty good too.
timatoe is online now   Reply With Quote
Old 10-05-2008, 10:37 PM   #62
bigsquat
FORMELY BIGPIMPIN
bigsquat's Avatar
yeah, i was also thinking of the plasti-dip, but since i had some fuel line laying around im using that. one note though its starts going in easy but hangs up 3/4 of the way threw. i had to pull it out and grease it ,then it slid right in. the shrink tube might be better because it would be thiner ,liter, and look better and finish off better at the fitting. I havent pulled mine out yet ,but i will see if i can eliminate the vacum diaphram housing altogther,and just use the shaft.
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD: http://www.jeepforum.com/forum/showthread.php?t=613943see
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline   Reply With Quote
Old 11-02-2008, 06:50 PM   #63
tippmann243
i just stared on my posi lock
i got 100 feet of 1/4" heat shirink tubing off ebay and i put it on the entire length of the cable for two reason. the first being to keep water out and the second being that a shiny metal cable looks out of place in a dark dirty engine bay. with it covered in the black tubing it looks like an oem vac line.
89 blazer, L31/t56 28mpg.
blazer video, http://s29.photobucket.com/albums/c279/tippmann243/?action=view&current=1204091507-02.flv
1990 jeep, 4.2, 5speed.
tippmann243 is offline   Reply With Quote
Old 11-02-2008, 11:06 PM   #64
bigsquat
FORMELY BIGPIMPIN
bigsquat's Avatar
i finished mine and was able to get rid of the round diaphram housing all together.I cut the shaft done and took of the small seal on the shaft . when the seal was on it would cause a vacum behind it and it wouldnt slide. I soldered a 1/2 copper pipe fitting to end where the old diaphram was. the spring i used was out of a wheel cylinder.
Old 11-03-2008, 04:47 PM   #65
tippmann243
i have a question about the shift fork housing.
can i use one from a cherokee D30. did they have a vac disconnect from like 84-91? im assuming it would be the same since its still a d30
i dont like messing up oem parts. especially since this is my daily right now. it would be easier to get a shift fork hosing from the junkyard so that was if something is janky i can put it back to stock.
another thing im curious about is that on everyone elses shift fork housing there is a sensor, im assuming thats for the 4wd light? my 90 is not setup that way. what years came with that setup beacuse i would like to get one to get my 4wd light to work, because if im not mistaken on my 90 its a vacuumswitch of some sort that controls it.
Old 11-03-2008, 09:05 PM   #66
bigsquat
FORMELY BIGPIMPIN
bigsquat's Avatar
i didnt know that there were different styles. mine as u can see has the limit switch built in,which is the best way to go. It wont lite unless the shaft slides, then u know your in 4x4 . If it uses a vacum switch at the transfercase or at some other location ,then you wouldnt know for sure that its engaged all the way.
Old 11-03-2008, 09:08 PM   #67
tippmann243
i didnt know that there were different styles. mine as u can see has the limit switch built in,which is the best way to go. It wont lite unless the shaft slides, then u know your in 4x4 . If it uses a vacum switch at the transfercase or at some other location ,then you wouldnt know for sore that its engaged all the way.
the vacuum switch that turns the light on is on the fire wall.
it would be easy to rewire it to work with the other system. just wanna be 100% sure that the cherokee stuff will in fact work
Old 11-03-2008, 09:25 PM   #68
bigsquat
FORMELY BIGPIMPIN
bigsquat's Avatar
just take yours off when you go to the wrecker and compare it before u buy
Old 11-03-2008, 09:32 PM   #69
tippmann243
i gotta drive my jeep there though.
im fairly confident that it will work, i called the yard i go to and they told me the part would be 10 bucks so if it dont work im not out a ton of money.
i could go look at my buddies 89 cherokee and do some comparison :scratcheshead:
Old 11-11-2008, 03:37 PM   #70
tippmann243
cherokees did not get the style with a limit switch
oh well got me an extra housing. got it all cleaned up not i just gotta find the time to finish modding it. maybe i can find the switch some where and just add it to this housing.
anyone know what that switch is called and where i can get it? im comming up dry
Old 11-11-2008, 05:43 PM   #71
Dmax5er
Thanks for the thread, i got mine installed this past saturday and it works great, only thing i done different was cut the cable to length needed and covered it with shrink tubing.
What Day is it?
Firefighters Jeep Club- Administrator
http://groups.jeepforum.com/Firefighters_Jeep_Club
Dmax5er is offline   Reply With Quote
Old 11-11-2008, 08:54 PM   #72
tippmann243
i did that too. now i just need to finish the rest of it
Old 11-12-2008, 12:54 PM   #73
tippmann243
here is my setup.
i didnt have any locktite on hand so i smeared the threads with RTV and threaded it in.
trying to show the holes i drilled into the fork.
napa cable covered in heat shrink tubing
Old 11-12-2008, 01:23 PM   #74
timatoe
Jello Puddin'
timatoe's Avatar
I really like the way that looks with the heat shrink, I shoulda done that.
Old 11-12-2008, 04:28 PM   #75
tippmann243
it turned out REALLY good.
plus i got 100' off ebay for ~15 shipped
Glock Forum
