#16 | ||
![]() ![]() Your set up looks to be as reliable as what posi-lok offers IMHO. If you had set this up and wrote about it before I did mine I would have put one together just like yours, it looks stout and reliable trust me
#17 |
was just thinking about looking for a write up for this!! and with pictures too thanks!!
#18 |
Will the 4wd indicator light in the dash still work with this DIY modification? Yeah, timatoe it's like the choke cable clamp on my 1953 Ford pickup. A small barrell with a hole for the wire to go thru and a set screw to tighten down on the wire. Outstanding write up,AuroraJeep.
#19 |
Honestly I kind of tied the wire, like balled it up. I know it sounds cheesy but it doesn't take much force to move the fork. If it fails then I will add one of the ends. My concern with an end thing is if that fall out and some how gets into the carrier thats worse than a failed posi lock. But thats just my opinion.
Dana 60 swap!.
Check out the Build:http://www.jeepforum.com/forum/f22/91-yj-d60-swap-build-thread-829459/ |
#20 |
Cable stops are cheap. On mine i have 2 holes drilled in the fork, run cable through one and back through the other, then attach cable stop (like timatoe posted)-- this keeps the cable attached to the fork with no worries
#21 |
Omnis Cedo Domus...
#22 |
Ever think of mayve putting the spring on the opposed end, that way there if it fails it fails engauged. And do most napa stores have this particular choke cable in stock?
#23 |
I just gave the part number and they brought it up.
Dana 60 swap!.
Check out the Build:http://www.jeepforum.com/forum/showthread.php?t=829459 |
#24 | |
me too
not a bad idea, BUT then generally on the street you'd be driving around with the cable LOCKED to have the axle disconnected. and Unlocked to have it connected.... I guess either way would work, though. |
#25 |
Will Work for Parts
I just stopped at my Friendly Neighborhood NAPA Store and they didn't have the locking cable in stock. They will have the 9' locking cable tomorrow for $30.
I like it |
#26 |
OLD RED NECK!!!
Thanks
I was just fixing to buy one and poor folks need all the help they can get THANKS
LIVE EVERY DAY LIKE IS WAS YOUR LAST... /_|__\___\ [n___n_[*lllll*] (o) )-(o) )-*-) ) 88 YJ, Smittybilt SRC Front, Side, and Rear Armor, Family Roll Bars, TJ Flares, and Half Doors 4"Leaf, 2"Body, and 1"Leaf Lift, 4.10 Geared Dana 30 Posi with Cable Engage, Ford 8.8 Posi, With 33s BFGs MT KM2 Everything "Black" Inner, Under, and outer "Black" on the Body is "Bed Linered" and I will be Thru the day that I Die!
#27 |
Will Work for Parts
I noticed in the "regretted Mods" thread that a few people regretted either buying a posi-lock or making one.
I wonder why? It seems like a good solution to me. Especially if you aren't off the road every weekend. Any thoughts here before I spend the $50 to do it? |
#28 | ||
Jello Puddin'
#29 | |
Will Work for Parts
I'm not ready for an axle shaft swap, so I will stick with my original plan and give this a try. |
#30 | |
X2 - I've had my cable stop pop off the end several times . I ended up doing the same thing and drilling another hole in the fork and feeding it back through . so far it has not pulled out. Just a note ... the first time I set mine up I just " balled up the cable " and it did not last long. It straightened the cable and pulled out. Great write up ! I never seem to stop and take pictures when I'm working on the Jeep ![]()
94 YJ , comp cut , 8.8 , 102" WB , XJ rear springs , and a few other things here and there |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
