Quantcast Home made POSI LOCK write up - Page 16 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Home made POSI LOCK write up
Old 12-20-2009, 06:30 PM   #226
Bfraley
OK cool. Thanks. as soon as I get some extra cash I'm gonna do this
Bfraley is offline   Reply With Quote
Old 12-20-2009, 10:21 PM   #227
Bfraley
Do i have to do anything with the vacuum lines? Mine got cut while replacing floor pans hence why i am going to do this mod. Can i just leave them connected to the housing or do i have to cap them at the vacuum source and remove them?
Old 12-21-2009, 09:16 AM   #228
laybackman
laybackman's Avatar
Vacuum source has to be capped or you lose all vacuum. Things like the MAP sensor would not work.
"If we cannot afford to take care of Veterans, then we should stop making them."
David C. Wilker Jr. USAF (RET)
Life is not what it's supposed to be. It's what it is. The way you cope with it is what makes the difference.
I think we should place all of our elderly in prisons. They will get a shower a day, video surveillance in case of any problems, three hot well balanced tailor made meals a day respecting their religious beliefs and nutritional needs, access to a library, computers, TVs, gym.
Put criminals in nursing homes. They will have cold meals, lights off at 7pm, one bath a week, live in a smaller room AND will be forced to pay $4,000- $8,000 a month!
It's pretty damn sad that we treat prisoners better than the elderly.
laybackman is offline   Reply With Quote
Old 01-06-2010, 09:16 AM   #229
parkerm26
air locking instead of cable
has anyone tried this with OBA? ive been thinking about it wen i put onboard air in soon. i have fittings, valves, guages, and a pneumatic piston that travels about 1.5-2 inches. could you apply the same concept?
btw the parts were free so theres no loss if it wouldnt work.
93' YJ 5in w/33's. Narrowed front 60 in progress of rebuilding, 14bolt in progress of rebuilding. End Result= 8in w/ 38s
parkerm26 is offline   Reply With Quote
Old 01-06-2010, 09:58 AM   #230
laybackman
laybackman's Avatar
I think that using a small piston and air pressure (unless regulated to a very low maximum PSI) would be too powerful that is why Jeep used vacuum to move the sliding collar only about 1".
Old 01-06-2010, 10:26 AM   #231
HUNTER_DENTON07
Nice write-up
DRIVE IT LIKE YOU STOLE IT
HUNTER_DENTON07 is offline   Reply With Quote
Old 01-07-2010, 01:34 PM   #232
parkerm26
damn there goes that project
Old 01-13-2010, 11:41 AM   #233
Ragnorox
If I have an Aussie locker up front and Install this posi lock then essentially I would have a poor mans selectable locker up front, right?
Ragnorox is offline   Reply With Quote
Old 01-13-2010, 05:23 PM   #234
timatoe
Jello Puddin'
timatoe's Avatar
To some degree but not really. I mean you're not engaging the Aussie only the passenger side shaft.
timatoe is offline   Reply With Quote
Old 01-13-2010, 06:16 PM   #235
Ragnorox
What I am saying is, when in 4wd i am engaging both differentials, with an Aussie up front and a posi lock installed I can engage both axles or I can disengage the passenger side axle and thus have a "poor mans locker" because the driver side is still engaged because of the locker.
Old 01-14-2010, 12:02 AM   #236
bigsquat
FORMELY BIGPIMPIN
bigsquat's Avatar
more like a poor handling jeep, i was really disappointed in mine. on solid ground it will lunge to one side under acceleration when disengaged. on icy conditions when you let up on the gas the jeep will do a 360! it only helps a little while turning on a granite slab to have it disengaged
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD: http://www.jeepforum.com/forum/showthread.php?t=613943see
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline   Reply With Quote
Old 01-14-2010, 01:08 AM   #237
Ragnorox
How do you like your Aussie out front?
Old 01-14-2010, 01:16 AM   #238
bigsquat
FORMELY BIGPIMPIN
bigsquat's Avatar
it has worked great so far. the rear however is a different story. the spring and pins wore out in less than a year. the replacement parts were free but the diagnosis and replacing was a pain. its working as good as it can for now. rear auto lockers can be dangerous
Old 01-14-2010, 10:09 AM   #239
540i
Sure it would work fine, the only reason jeep used vacumum is because that's what they had.
540i is offline   Reply With Quote
Old 02-13-2010, 05:00 PM   #240
Red91xj26
Ruby The Red XJ
Red91xj26's Avatar
1991 XJ Cherokee
This is great I hate the vacuum setup its garbage
91 jeep cherokee laredo My Build Thread http://www.jeepforum.com/forum/f22/my-91-jeep-xj-laredo-998423/
Red91xj26 is offline   Reply With Quote
Glock Forum
