#211 | |
I bought it at a small local parts store. The cable is a( pto )cable. there website is buyersproducts.com part number is above on earler post. on the installation instructions say it is the 3100/4100 series and it is called a vernier adjustable locking control cable. hope this helps
#212 |
the cable was 15 foot long and i cut it down with a die grinder, cutters would not cut it. its a good cable.
#213 |
A cable that strong may snap when you try to bend it for your loop into your second hole...
94 YJ: 4" lift. 32-11.5-15's. |
#214 |
I took some that I cut off and bent it alot and it still has not broke.dont know what its made out of but I like!
#215 |
Good deal!
#216 |
i got my cable off a seach of buyers cable they make diff. lenghts so i got a 10' and a 15' cable for my two jeep. the place has stuff for dump bed they are in ohio.....i will se if i can find the web site eztruckaccessories.com/3100-series-vernier-adjustable-loc...
#217 | |
Click here to see all of my different albums on Photobucket. Choose any album to see all of my pics! Mean Max is setting up his Jeep shop! Picture history of my progress here. Quote:
There is no situation that cannot be improved with a small but well-placed explosive.
#218 |
home made posi-loc
I modified mine but its real hard to pull and doesnt engage. works great when off axle.its like the two axles are rotate differently so the slide gear doesnt connect them. any suggestions?
#219 | |
Jello Puddin'
Try pulling it when you're slowly rolling forward so the the shafts and the collar can get lined up.
#220 |
Try going 5MPH and turning your steering wheel while applying some pressure on the cable. Turning you wheel usually gets both axles lined up. It doesn't take much turning either.
"If we cannot afford to take care of Veterans, then we should stop making them." David C. Wilker Jr. USAF (RET) Life is not what it's supposed to be. It's what it is. The way you cope with it is what makes the difference. I think we should place all of our elderly in prisons. They will get a shower a day, video surveillance in case of any problems, three hot well balanced tailor made meals a day respecting their religious beliefs and nutritional needs, access to a library, computers, TVs, gym. Put criminals in nursing homes. They will have cold meals, lights off at 7pm, one bath a week, live in a smaller room AND will be forced to pay $4,000- $8,000 a month! It's pretty damn sad that we treat prisoners better than the elderly. |
#221 |
Did you remove the vacuum connections from the flying saucer? If you didn't and it's clogged you're going to have difficulty shifting the fork.
91 YJ 98 XJ 2 door love The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain. |
#222 |
does the 4WD indicator in the dash still work with this mod?
#223 |
FORMELY BIGPIMPIN
mine does. mine has a limit switch on the shft motor housing, it will light when you pull the cable and the fork shaft hits the limit switch. it will not livght when you put the tc in 4x4 and not have engaged the cable.
older models used a diferent set up. i think the switching of the light worked on a vac switch on the tc.
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD: http://www.jeepforum.com/forum/showthread.php?t=613943see Two fish swim into a concrete wall. One turns to the other and says 'Dam!' |
#224 |
I have 95. Should be the same as your right?
#225 |
FORMELY BIGPIMPIN
it should be,just look and see if the switch is on the axle disco. cant miss it
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
