Send Message Advertisers Vendors Announcements
Jeep Forum Classifieds JeepSpace Reviews Gallery Blogs Clubs Groups Videos Wiki Links Events Articles
Jeep Home Jeep Forum Jeep Classifieds Jeep Registry JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Wiki Jeep Links Jeep Events Jeep Articles
Moto Alliance Viper Elite 8,000lb Winch Giveaway!
Go Back   JeepForum.com > Models > Wrangler Forum Group > YJ Technical Forum
Jeep Registry Register FAQ Mark Forums Read Search Members
LinkBack (3) Thread Tools
Old 09-06-2009, 10:48 AM   #151
jeepcrack
Newb here to Jeeps and love the hell out of the 89 Islander that I got.
I read through this whole thread and others having to do with the posi-lok and I plan on tackling this home made posi lok project because mine is not working at the moment.
My question is: Did the 89 Islander come with a posi-lok switch under the dash in order to engage the 4WD? I thought it was simply a shift and go item because a previous owner added an after market vaccum switch under the dash that will not engage the 4WD at this time.
I was told that i should not have to do anything but shift into 4WD in order to have 4WD, and that the posi-lok was an add on in order to make the front wheels turn at the same time in 4 low.
Thanks and this is a great thread!
...said the joker to the thief.
jeepcrack is offline   Reply With Quote
Old 09-06-2009, 11:01 AM   #152
timatoe
Jello Puddin'
timatoe's Avatar
No YJ's came with a posilok switch. You are right about shift and go. You were mis-informed about the purpose, the posi lock is different than posi-traction. This mod ONLY replaces the factory vacuum actuated system with a manual actuated system. EVERYTHING else works the same as stock.
Originally Posted by Ares
I love my jeep that much....i lick it daily...:p
DO NOT BUY ANYTHING FROM
OffroadToyStore.com
Originally Posted by Benjamin Franklin
All that's necessary for evil to triumph is for good men to do nothing.
timatoe is online now   Reply With Quote
Old 09-29-2009, 10:08 PM   #153
jayj1988
hey guys, I have a question about this mod it may sound stupid but can I still ''shift on the fly'' with this mod??
jayj1988 is offline   Reply With Quote
Old 09-29-2009, 10:29 PM   #154
timatoe
Jello Puddin'
timatoe's Avatar
Yes you can.
OffroadToyStore.com
Old 09-30-2009, 12:12 AM   #155
dino22isg
im new at this and this may be a stupid question but I dont think I have a posi diff. If I I install this homemade posi lock will it work or do I need some other parts aside from the hardware listed?
Thanks
dino22isg is offline   Reply With Quote
Old 09-30-2009, 12:15 AM   #156
dino22isg
Hey man great write up. Im newat this and this might be a stupid question but if you don't have a posi diff and you install the home made posi lock will you need any other hardware aside from what is listed?
Thanks
Old 09-30-2009, 08:06 AM   #157
AuroraJeep
Thanks
This mod is only pertaining to the vacuum switch on your axle shafts, not "posi traction". The parts listed are to "lock" you passenger side axle shafts together manually, voiding the factory vacuum switch.
AuroraJeep is offline   Reply With Quote
Old 09-30-2009, 05:20 PM   #158
James750
1990 MJ Comanche
Send a message via AIM to James750
Thanks
TJ's do not have a vacuum actuated front axle. There is no way to do this mod to your wrangler, nor is there any reason to. Only YJ's, MJ's, and some older XJ's have the vac actuated front axle.
1990 mj,
Colorado Jeep Club #178
Originally Posted by Ubie View Post
Three words: Flying Spaghetti Monster
Originally Posted by War Eagle View Post
Praise be unto His Noodly Appendage.
James750 is offline   Reply With Quote
Old 10-02-2009, 12:36 PM   #159
speepdaedeesi
lookin for the trash pile
speepdaedeesi's Avatar
just got back from napa, got the locking cable and tap..
they didnt have/didnt know if they had -1/4" Compression Union
-5/8"x2-3/4" Compression Spring.
bummer. but... im halfway there on parts and spent less than 40 bucks lol.
1995 YJ-CHEV-EEP-Frame Off- 100% POR-15, rebuilt 350V8 Vortec, rebuilt 700R4,D30 Front,8.8 Rear, 4.11 gears, Custom np231C, SYE, SOA, 1" BL, 1.5" RE Springs, Bilstein shocks, TJ extended flairs, Procomp Rims, Procomp 35s, Fuel cell, RE 3pc belly skid, RE brake lines, locked front and rear, Much more.... BUILD THREAD - http://teamxtrm.hyperboards.com/index.php?action=view_topic&topic_id=543
speepdaedeesi is offline   Reply With Quote
Old 10-02-2009, 01:50 PM   #160
timatoe
Jello Puddin'
timatoe's Avatar
When I did mine, I got the other stuff from the local True Value.
OffroadToyStore.com
Old 10-03-2009, 08:29 AM   #161
AuroraJeep
I bought the compression spring from Auto Zone.
Old 10-03-2009, 10:30 AM   #162
Not-Bob
Cable options
Alot of the write in's on this topic were questions I had to search for also. I tried the lawnmower throttle cable and the NAPA throttle cable, but the best one I came across was a push button cable in a rubber housing to keep moisture out. I was told they use them for motorhome generators and other equipment like chippers, trailered air compressors and generators, and etc.. It was about $80 at a cable and splicing store.
Not-Bob is offline   Reply With Quote
Old 10-03-2009, 10:37 AM   #163
Not-Bob
Plus you gain the ability to use low range without 4 wheel drive to be able to manuever around a little easier.
Old 10-07-2009, 11:33 AM   #164
ncAndrew
mmmm, bacon....
ncAndrew's Avatar
I've got everything together, except I forgot the cable locks. :banghead:
What did you guys use for cable lube before assembling it all?
No, I'm not going to use WD-40.
... dude, most marriages don't end well. it's a given.
ncAndrew is offline   Reply With Quote
Old 10-07-2009, 11:41 AM   #165
ncAndrew
mmmm, bacon....
ncAndrew's Avatar
Originally Posted by plym49 View Post
I would use Loctite on those cable ends to help prevent the screw from backing out.
Shrink wrap is easily cut or abraded, so perhaps cover it with some fuel hose if you really want it abrasion/cut/oil/water resistant.
For waterproof cables go to your friendly local bike shop. You can get throttle cables or even a clutch cable if you want overkill. Motorcycle-grade cables are plenty strong, have ends that won't pull off (some get soldered on) and are waterproof. You can order cables in any length you want and the plain black ones are not expensive.
In any case lube that cable once in a while. You could coat the (inner) cable with grease the first time you put it together. Cable lube (in spray cans or oilers) works really well; it is designed to wick itself end-to-end.
I've got all kinds of grease. I guess I don't see why moly wouldn't work.
Home made posi lock questions RANGER_DANGER YJ Technical Forum 0 12-19-2006 10:19 AM
home made Posi-Lock Killrdanasurfer YJ Technical Forum 10 04-03-2006 01:44 PM
Home made Posi-lock MCJeeper YJ Technical Forum 23 02-28-2006 01:19 PM
Home-made Posi-Lock peltdrummer YJ Technical Forum 4 12-25-2003 01:27 PM
4x4 POSI-LOCK!(HOME-MADE??) BIG SEXY YJ Technical Forum 5 01-27-2003 07:59 AM
The time now is 02:59 AM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation.
JeepForum.com is not in any way associated with Jeep or the Chrysler Corp.
