| Support JF - Equipment Drive and Future Downtime |
| Register | FAQ | Mark Forums Read | Search Members |
LinkBack (3) | Thread Tools |
#1 | |||
Registered User Join Date: May 2008 Location: Aurora, IL Posts: 322 | Home made POSI LOCK write up
__________________ Dana 60 swap!. Check out the Build:http://www.jeepforum.com/forum/f22/91-yj-d60-swap-build-thread-829459/ Last edited by AuroraJeep : 08-19-2008 at 09:10 AM. | ||
| #2 | |
Registered User Join Date: Jul 2008 Location: Lancaster, PA Posts: 723 | wow. Very detailed |
| #3 | |
Registered User | If I didn't already have a Posi-Lock I'd definitely try this. Hey Mods... I think he deserves a membership for the write up! ![]() __________________ Never attribute to malice that which can be adequately explained by stupidity. Unless its Nancy Pelosi - then its a safe bet that both apply. |
| #4 | |
Will Work for Parts Join Date: Jul 2007 Location: Fayette County West Virginia Posts: 222 | AuroraJeep, Thanks for the write up!!!! I'm all over this. I'm doing a rebuilt at the moment and have been contemplating something like this in the back of my head since the start of my project. Especially since my vacuum hoses didn't come of "clean" when I was working on the front end. Did you get your compression union and spring from Lowes/Home Depot? __________________ |
| #5 | ||
Registered User Join Date: Feb 2006 Location: Kernersville, NC Posts: 1,816 | nice write up! it's about time someone did another complete one. Quote:
| #6 | |
Registered User | Nice work! __________________ 1991 Jeep Wrangler 2.5L, 5 speed 2003 SVT Cobra Supercharged 32V 4.6L, 6 speed |
| #7 | |
Registered User Join Date: May 2008 Location: Aurora, IL Posts: 322 | I bought the compression union from auto zone actually, but you can get from anywhere. I saw some at NAPA. __________________ Dana 60 swap!. Check out the Build:http://www.jeepforum.com/forum/showthread.php?t=829459 |
| #8 | |||
Jello Puddin' Join Date: Aug 2006 Location: Nevada City California Posts: 7,058 | Nice write up. Like the cable .......... ![]() __________________ Quote:
DO NOT BUY ANYTHING FROM OffroadToyStore.com Quote:
| #9 | |
Registered User Join Date: May 2008 Location: Aurora, IL Posts: 322 | Ok have to give credit were credit is due, I stole that from you. __________________ Dana 60 swap!. Check out the Build:http://www.jeepforum.com/forum/showthread.php?t=829459 Last edited by AuroraJeep : 08-18-2008 at 10:08 PM. |
| #10 | ||
Registered User Join Date: Mar 2006 Location: Monaca, Pa. 15061 Posts: 1,543 | Quote:
Great thread. Doug __________________ Wise men speak because they have something to say; Fools because they have to say something. Plato | |
| #11 | |
Member Join Date: Jun 2007 Location: Fuquay North Carolina Posts: 286 | ive been considering this mod seriously, but it seems like a lot of people say its not worth it. How reliable are the posi lok setups. __________________ Soon to be SOA with 14 Bolt SF rear, D44 front and 38's Early YJ Club, Member # 33 |
| #12 | |
Web Wheeler Join Date: Dec 2002 Location: Massachusetts Posts: 2,076 | The POSI-LOK's are fairly rugged in construction and should hold up no problem. This particular DIY setup appears to be a very good one also. Needless to say the weak link(s) in a DIY set up will always be how you attach it to the fork and how robust is the cable itself. Using a brake cable for a bicycle would be asking for trouble, IMHO, as an example. |
| #13 | |
Registered User Join Date: May 2008 Location: Aurora, IL Posts: 322 | The way I see it, is that it took seriously like 1 minute to pull that whole assembly out, if the cable slips off the fork it's an easy trail fix. Still half the cost of a new vacuum unit that is also prone to breakage. I plan on running a d44 soon, so this was a cheap, easy, and easily serviceable mod that fixed a problem. This NAPA cable wire was real thick, I am confident in it. __________________ Dana 60 swap!. Check out the Build:http://www.jeepforum.com/forum/showthread.php?t=829459 |
| #14 | ||
Will Work for Parts Join Date: Jul 2007 Location: Fayette County West Virginia Posts: 222 | Out of curiosity and not seeing the cable, how did you attach it to the fork? Maybe if I had the cable it would be self explanatory... Quote:
__________________ | |
| #15 | ||||
Jello Puddin' Join Date: Aug 2006 Location: Nevada City California Posts: 7,058 | Quote:
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| Home made posi lock questions | RANGER_DANGER | YJ Technical Forum | 0 | 12-19-2006 11:19 AM |
| home made Posi-Lock | Killrdanasurfer | YJ Technical Forum | 10 | 04-03-2006 02:44 PM |
| Home made Posi-lock | MCJeeper | YJ Technical Forum | 23 | 02-28-2006 02:19 PM |
| Home-made Posi-Lock | peltdrummer | YJ Technical Forum | 4 | 12-25-2003 02:27 PM |
| 4x4 POSI-LOCK!(HOME-MADE??) | BIG SEXY | YJ Technical Forum | 5 | 01-27-2003 08:59 AM |
Previous Thread
Next Thread
