Quantcast home made Posi-Lock - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > home made Posi-Lock
Old 04-01-2006, 09:18 PM   #1
Killrdanasurfer
home made Posi-Lock
my 4wd won't egage and i want to get rid of the whole vac line system controling the d30... i was wondering if there are any directions on making your own posi-lock instead of buying one for two hundred... it appears to be nuthing more than a brake line off a bicycle...
89 White Islander at, stock for now but hopefully running 35's by summer... Sold...
[COLOR="Blue"]surfin jeep club #1[/COLOR]
Killrdanasurfer is offline   Reply With Quote
Old 04-01-2006, 09:29 PM   #2
bobbert350
u could do the cheap way the lincoln locker and just weild it together but i have no clue how to build one... i would just buy it if i were u
bobbert350 is offline   Reply With Quote
Old 04-01-2006, 09:55 PM   #3
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
I haven't done this, but may need to in the future. Since there is no search button anymore, I Googled this in jeepforum using the phrase "posi lock,jeepforum"
http://home.earthlink.net/~stevenschreiber/cabledis.htm
Let us know how it turns out if you do it.
White '94 YJ 2.5L 5 speed, 33" BFGs MTs, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio
Member #94 White Jeep Club
My Jeep
'89 XJ Laredo Bone Stock
KB6NQT
Everyone is Welcome
www.rubiconramblers.com
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline   Reply With Quote
Old 04-02-2006, 09:21 AM   #4
atakrator
I recently tried that method, but it doesn't work that well. I can't get the fork to slide back and forth very well, and it sticks at either end.
I am think about payin the @200 for the system.
atakrator is offline   Reply With Quote
Old 04-02-2006, 09:40 AM   #5
jeep loser
Is it a vac line that's the problem? if so why not just fix that? Because if the shift fork is screwd you'll be buying a new one anyway
5 % of people make things happen
65% of people let things happen
30% of people say "what happened?"
jeep loser is offline   Reply With Quote
Old 04-02-2006, 06:46 PM   #6
Killrdanasurfer
No i was stupid and when i replaced my carter with the mc2100 i disconected something i shouldnt have... so now im just gonna do posi-lock... Thanks i'll check out that write up!
Old 04-02-2006, 08:54 PM   #7
atakrator
I recommend going to a professional lawnmower place (weingartz) and getting a "locking throttle". The bike cable won't work - too weak.
Plus, the locking one, you can twist, and it locks in place.
Old 04-03-2006, 12:17 AM   #8
Slapahoe
Registered Jerk
Slapahoe's Avatar
www.4x4posi-lok.com has a system for sale for $60 or so. Of course they have the $200 which I bought but they also have the cheap route.
93 YJ 4.0HO
'03 KJ Renegade
Slapahoe is offline   Reply With Quote
Old 04-03-2006, 12:53 PM   #9
dominiakrulz
i ended up using a locking choke cable from napa. I can't find a link to it, but i had the problem finding a cable that works. heres sumthing to keep in mind:
the cable has to lock in the out position
must be strong
like 8-9 feet long
luckily that cable fit everything.
dominiakrulz is offline   Reply With Quote
Old 04-03-2006, 02:23 PM   #10
laybackman
laybackman's Avatar
You may be able to use a brake cable from a motorcycle they are fairly stout. But cost may be high, and length may be an issue also. The cable has to go through the firewall at a convenient location, travel over the steering shaft, under the air intake box then make a gradual sweep around the front of the engine under the water pump to the front axle housing. So we are talking ~6' or so.
laybackman is offline   Reply With Quote
Old 04-03-2006, 02:44 PM   #11
dell2028
You could also swap in a one peice axle like a TJ. Or even make your 2 peice into a 1 peice but making the colar stay over the 2 axle peices. I have done the later using a heavy duty bolt to hold the fork/collar in place. I haven't noticed a change in MPG or had problems with my D30 locker (Aussie).
My Build Up
95 YJ, D30/8.8 w/ 4.88s, SOA, 35x14.50x16.5 Pit Bull Mud Dawgs, 101" Wheelbase, Custom Front Bumper, Winch, Custom Rear Tow Points, Traction Bar, Aussie Locker in front, 20 Gal. Gas Tank modification, Hurculiner Tub, Custom Rear Bumper, SYE and CV shaft, BTF Cross-over Steering, RCI 2191 fuel cell, BTF Rockers, RE 1.5" SOA springs up front and XJ springs in the rear
Down the line a bit...engine swap, the list goes on.
dell2028 is offline   Reply With Quote
Glock Forum
