#1 | |
Home made Posi-lock
I was wondering who has made the home made posi lock and how well it has held up so far the only write up for it that i have found is from http://home.earthlink.net/~stevenschreiber/cabledis.htm does anybody have any other write ups on something similar???
Thanks
92 YJ 4.0 I6 01 Suby 2.5RS |
#2 |
All I've got left to do is make a handle for the cable and I'll have all the peices I need.
Going to weld up a handle tommorow at work time permiting. Mine does differ a bit from that write up, but not much. As far as wuality goes, I'm going to have to wait and see, but in all honesty, it can't be worse than dealing with the vac system that I keep having problems with. |
#3 |
I just made a posilock for my jeep a couple of weeks ago.. For the handle I used a Toyota pick up emergency brake handle (The ratcheting kind) and mounted it right under my speedo.
http://i36.photobucket.com/albums/e40/Bret93YJ/100_02041.jpg http://i36.photobucket.com/albums/e40/Bret93YJ/100_02031.jpg Let me know if you need any help...
Bret Buchanan '93 4-Banger, RE 4" lift, 33" x 10.50s (soon) |
#4 |
MCJeeper,
I put a post for my project done on my jeep. Unfortunately I lost my jeep by accident before I complete the operator's side (lever at drivers seat), but I tried to explain as detail as possible to work on shifter housing. Mine was 87 4cylinder YJ. Here is a link.. Good luck. http://www.jeepforum.com/forum/f12/my-home-made-posi-lok-part1-144459/ http://www.jeepforum.com/forum/f12/my-home-made-posi-lok-part2-144461/ |
#5 |
I'm interested to see how this works out for you guys. I bought one of the kits and it is really heavy duty. After shifting it in and out a few times I'm not sure that a bike cable is going to hold up
88 4 banger, cooper STT on American Racing rims. 4.5 RE XD, 4.88 Yukon gears, Tom Wood's shaft CV shaft, lockright, limited slip rear, SYE, posi lock engagement, a to z fab rear bumper 2005 Rubicon 3" lift, 33 MTZs, Superwinch, A to Z bumper and rock rails |
#6 |
black 87 that looks good so far what parts did you use to make it. Also what levers have people used for the posi lock.
#7 |
(just in case you missed it) The Toyota E-brake handle was perfect for mine. When you pull it out, it ratchets and locks in the out position (4WD engaged). then to disengage, you just twist the handle and push back in. Mine cost 15 bucks from a junk yard and it is much more sturdy than the el cheapo handles that I found in auto parts stores.
#8 |
How long did this take for you to make? I'm looking at having to do mine soon.
#9 |
I made mine before winter using the locking choke cable from napa, the cable is plenty srong.all the other parts stores had cheap cables and handles. I have used it all winter in wisconsin so it gets quite a bit of use. Reliablity is awesome. when I first installed it I didnt attach the cable well enough to the shoft fork and it pulled out one icy evening. I went home and reattached the cable through the shift fork more securely and havent had a problem since.
RUSTY RED 92 YJ 4.0 with a billion miles 4 inch Rough Country Lift, 2 inch lift shackles, home made posi lock,see through floor, and much more. 33x12.50x15 Wild Country RVT on Cragar 15x10's The Gone- 97 ZJ Laredo 5.2L 94 YJ 2.5L |
#10 | |
92 YJ 4.0 I6 01 Suby 2.5RS Last edited by MCJeeper; 02-09-2006 at 02:54 PM.. |
#11 |
Jeepaholic
I built one of these using the how to for my 93 YJ, worked great....never had a bit of trouble. Another nice thing is being able to use 2wd low range
04 Ram 2500 5.9L 24v HO Cummins My Attempt at a Wrangler YJ Unlimited Past builds: Unwrecking a Rubicon My Rusty Wrangler Project |
#12 |
I'm thinking I might have mine adjusted wrong. I have to really give it a pull and often times slowly go forward before it will pull all the way out and engage.
Is this how yours are working too?
#13 |
Mine took a few evenings after work to from start to finish. I had a lot of trial and error that made it take a little longer. What took the longest was the mods I had to make to the handle I used so that it would fit where I wanted it.
As far as attaching the cable to the shift fork... You need to buy a cable stop at the hardware store. They slide onto the end of the cable and crimp on the end so that it doesn't slide through the hole. Buy a few of them because you may need to make some cable adjustments to fine tune. 1. drill a hole into the inboard side of the shift motor cover. 2. drill a hole into the center of the shift fork. (Just big enough for the cable to thread through.) 3. thread the cable through the motor cover, then through the spring, then through the fork and crimp a cable stop to the end of the cable so that it can't slide back through. Check out this link...it gives pretty good pics and descriptions... http://home.earthlink.net/~stevenschreiber/cabledis.htm keep us posted on progress...
#14 |
This seems pretty easy. What does the store bought Posi-loc offer that the homemade one doesn't as far as performance goes.
#15 |
A higher price tag...
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
