Quantcast Home made front axle disconnect - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Home made front axle disconnect
Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at BasIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 02-26-2008, 08:18 AM   #1
WNCwheeler
I’m trying to do the home made front axle disconnect or posilock, whatever you want to call it. I drive a 95 I-4 Wrangler. I took the vacuum motor off yesterday and some fluid ran out so I put it back on because I have to drive it and didn’t have all the stuff ready to complete the job. I’m guessing that is just axle fluid but I don’t know what kind or how much it holds when I have to refill it? Also, is there a gasket on the housing that I’m going to need to replace when I do this?
WNCwheeler is offline   Reply With Quote
Old 02-26-2008, 09:02 AM   #2
SEZARO21
I mad my own homemede Posi-lok. All the materials cost me $20.00. Best thing I ever did. The only problem I have is that I need a better lever to activate it. I love the fact that it's so easy and you know for sure when it's on. I also love that my 4WD light still comes on when it's activated. Piece of mind.
1991 2.5L YJ, 4" R.E. lift kit, 1-1/4" Lift shackles, K&N CAI, 4.0 TB w/ bored out intake, 5.0L Ford Mustang fuel injectors, 117A alternator, Ford Taurus electric fan, Rancho steering stabilizer, 8.8 Ford axle, 35x12.5x15 Dunlop Mud Rovers, Smittybuilt Titanium side steps, Smittybilt SRC Front Grille Guard Bumper, Smittybilt Stereo Center console, PIAA 520 Series fog lights, Sylvania Silverstar headlights, 20 gallon fuel tank upgrade & Herculined tub.
SEZARO21 is offline   Reply With Quote
Old 02-26-2008, 01:07 PM   #3
1995_4.5L Jeep
http://home.earthlink.net/~stevenschreiber/jeep/tech/cabledis.htm
1995 Wrangler 4.5L
8.8 Ford rear
4.11 gears
ax-15 trans
4" lift 33" tires
1995_4.5L Jeep is offline   Reply With Quote
Old 02-26-2008, 03:16 PM   #4
NJscott
I just did this last weekend. i followed the instructions posted in the link above but i used a push mower throttle kit that I got from lowes. Also the gasket is apparently nonexistent, i had to make one out of some gasket paper and RTV. Good luck.
90 islander ( de-stickered)
webber 32/34
ford dist. cap & rotor
daystar 1" bl
1.25" booms
NJscott is offline   Reply With Quote
Old 02-26-2008, 10:16 PM   #5
schizm99
http://www.aircraftspruce.com/catalog/appages/a750.php
This is what I used pricey but never fails and doesnt slip out!
89 YJ 4"rough country lift.
32-11.50-15 swampers
8000# black mountain winch
front lunch box lockers w/posi-lok
uniden cb, gt steering wheel, 4.10 gears
and anything else homemade
schizm99 is offline   Reply With Quote
Old 02-27-2008, 05:44 AM   #6
sgtcherokee
I'm running this one , it works great and it's cheap
http://www.awdirect.com/finditem.cfm?itemid=8746
94 YJ , comp cut , 8.8 , 102" WB , XJ rear springs , and a few other things here and there
sgtcherokee is offline   Reply With Quote
Old 02-27-2008, 06:38 AM   #7
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
SIDE NOTE, you need to open the fill plug on the diff and fill it till fluid runs out with gear old. Any 80 weight will do, you just need to get that filled before you are driving around in it after loosing fluid.
THIS NEEDS TO HAPPEN ASAP!!!!!!!!!!!
http://i131.photobucket.com/albums/p...k_banner-1.gif
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote
Old 02-27-2008, 09:32 AM   #8
nic99007
That is what i have and it's GREAT
nic99007 is offline   Reply With Quote
Old 02-27-2008, 07:40 PM   #9
timatoe
Jello Puddin'
timatoe's Avatar
Originally Posted by 1995_4.5L Jeep View Post
I used these instructions with only minor modifications.
I used one very similar, I bought it at the local Napa in the HELP section, it was listed as a 9' locking choke cable (about $17). Looks like this one functions the same as mine.
This is where I mounted mine....
timatoe is offline   Reply With Quote
Old 03-12-2008, 03:01 PM   #10
WNCwheeler
Thanks for all the help everybody, finally got around to doing this yesterday and completed today. Works great, I'm glad I decided to go with this route instead of buying expensive replacement parts. The only question I have now is what am I supposed to do with the vacuum system? Should I leave the vacuum lines plugged up to my vacuum motor or should I unlplug it? Should I plug these vacuum lines altogether?
Thanks again, Travis
Old 03-12-2008, 03:13 PM   #11
rustywrangler
Plug em up. You need to do it at the tcase, and where it connects into the manifold vac system on the engine. Your gonna loose your 4wd light in the process though.
Old 03-13-2008, 03:57 AM   #12
sgtcherokee
the light should still function as normal , it is not vac. operated . The electrical plug on the disco is for the light , leave it plugged in just remove the vac. lines or plug them .
Old 03-13-2008, 05:33 AM   #13
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
Mines vac actuated.
Richmond88yj is offline   Reply With Quote
Old 03-13-2008, 04:20 PM   #14
SEZARO21
My light still works and the hoses are disconnected.
Old 03-13-2008, 07:18 PM   #15
Kid_Kool_Aid
This is more of a rhetorical post but this is essentially the same thing as the 4X4 posi lock that quadratec has for 220 bucks? This is amazing that some figured it out for 20 bucks. Just want to say way to go.
Kid_Kool_Aid is offline   Reply With Quote
Glock Forum
